[Ovmsdev] New web setup
Fri May 11 23:49:31 HKT 2018
I tried a restart. Here is what I get:
Firmware: 3.1.005-72-g8cd4d07/ota_0/main
Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
I (1465) webserver: Launching Web Server
I (1465) ssh: Launching SSH Server
I (4185) wifi: ap channel adjust o:1,1 n:6,2
I (4185) wifi: n:6 0, o:1 0, ap:6 2, sta:6 0, prof:1
I (4945) wifi: state: init -> auth (b0)
I (4945) wifi: state: auth -> assoc (0)
I (4955) wifi: state: assoc -> run (10)
I (5055) wifi: connected with HIGHWAYS, channel 6
I (5375) sdcard: SD CARD has been inserted
I (5465) sdcard: mount done
I (6025) wpa: PTK has been installed, it may be an attack, ignor it.
I (6025) wpa: GTK has been installed, it may be an attack, ignor it.
I (8515) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6
I (8515) wifi: station: cc:44:63:89:b2:f4 join, AID=1, g, 20
I (8525) esp32wifi: AP station connected: id: 1, MAC: cc:44:63:89:b2:f4
I (9455) event: sta ip: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
I (9455) netmanager: Interface priority is st1 (10.10.41.203/255.255.248.0 gateway 10.10.40.64)
I (9455) netmanager: Set DNS#0 10.10.40.64
I (9455) netmanager: Set DNS#1 0.0.0.0
I (9455) netmanager: Set DNS#2 0.0.0.0
I (9455) netmanager: WIFI client up (with MODEM down): starting network with WIFI client
I (9455) esp32wifi: STA got IP with SSID: HIGHWAYS, MAC: 30:ae:a4:43:92:c4, IP: 10.10.41.203, mask: 255.255.248.0, gw: 10.10.40.64
I (9455) time: Starting SNTP client
I (10375) housekeeping: System considered stable (RAM: 8b=106112-106940 32b=23608)
I (13565) webserver: HTTP GET /
I (13575) webserver: HTTP GET /cfg/init
I (14825) webserver: HTTP GET /
I (15135) webserver: HTTP GET /cfg/init
I (15375) simcom: State timeout, transition to 13
I (15375) simcom: State: Enter PoweredOff state
I (15375) gsm-mux: Stop MUX
I (16695) webserver: HTTP GET /
I (16705) webserver: HTTP GET /cfg/init
I (16735) webserver: HTTP GET /apple-touch-icon.png
I (16905) webserver: HTTP GET /assets/style.css
I (16905) webserver: HTTP GET /assets/script.js
I (17345) webserver: HTTP GET /cfg/init
I (28045) webserver: HTTP POST /cfg/init
I (28045) webserver: HandleLogin: 'admin' logged in, sid 98faaa06ed8f1574
I (28085) webserver: HTTP GET /cfg/init
I (28085) webserver: CfgInit enter 2.test.connect
I (28085) webserver: HTTP GET /menu
I (40025) webserver: HTTP GET /
I (40035) webserver: HTTP GET /cfg/init
I (40035) webserver: CfgInit enter 2.test.connect
I (40045) webserver: HTTP GET /
I (40075) webserver: HTTP GET /apple-touch-icon.png
I (40085) webserver: HTTP GET /assets/style.css
I (40185) webserver: HTTP GET /assets/script.js
I (40355) webserver: HTTP GET /cfg/init
I (40355) webserver: CfgInit enter 2.test.connect
OVMS> enable
Password:
Secure mode
I (50425) webserver: HTTP GET /
I (50425) webserver: HTTP GET /cfg/init
I (50425) webserver: CfgInit enter 2.test.connect
I (50465) webserver: HTTP GET /apple-touch-icon.png
I (50475) webserver: HTTP GET /assets/style.css
I (50555) webserver: HTTP GET /assets/script.js
I (50675) webserver: HTTP GET /cfg/init
I (50675) webserver: CfgInit enter 2.test.connect
OVMS# ota status
Running partition: ota_0
Boot partition: ota_0
Firmware: 3.1.005-72-g8cd4d07/ota_0/main (build idf v3.1-dev-454-gdaef4b5c May 11 2018 20:00:05)
Server Available: 3.1.005
OTA release providing minor improvements and fixes.
- Vehicle: 12V battery monitoring
vehicle [12v.alert] = 1.6 Voltage drop alert threshold in V vs. reference
- OTA: automatic daily firmware updates (wifi only)
auto [ota] = yes Enable/disable
ota [auto.hour] = 2 Hour for daily check
- Logging: persistent configuration, file cycling, web config UI:
log [file.enable] = no Enable/disable file logging
log [file.maxsize] = 1024 Max log file size in kB, 0 = no cycling
log [file.path] = "" Log path, if on /sd watches sd.mounted
log [level] Default level
log [level.<tag>] Component levels
- Reverse Engineering Tools enhancements
- Tesla Roadster CAC support
- Miscellaneous bug fixes and enhancements
I (61705) webserver: HTTP GET /
I (61715) webserver: HTTP GET /cfg/init
I (61715) webserver: CfgInit enter 2.test.connect
I (61745) webserver: HTTP GET /apple-touch-icon.png
I (61755) webserver: HTTP GET /assets/style.css
I (61845) webserver: HTTP GET /assets/script.js
I (61965) webserver: HTTP GET /cfg/init
I (61965) webserver: CfgInit enter 2.test.connect
I (72035) webserver: HTTP GET /
I (72045) webserver: HTTP GET /cfg/init
I (72045) webserver: CfgInit enter 2.test.connect
I (72085) webserver: HTTP GET /apple-touch-icon.png
I (72095) webserver: HTTP GET /assets/style.css
I (72175) webserver: HTTP GET /assets/script.js
I (73485) webserver: HTTP GET /cfg/init
I (73495) webserver: CfgInit enter 2.test.connect
OVMS# config list auto
auto (readable writeable)
wifi.mode: apclient
wifi.ssid.ap: DEVBENCH
wifi.ssid.client: HIGHWAYS
OVMS# config list module
module (readable writeable)
init: 2.test.connect
> On 11 May 2018, at 10:42 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Do you have the earlier log, especially of the CfgInit ticker messages?
> Is the auto config correct and matching the "HIGHWAY" network?
> Please try a reboot. The ticker should take on step "2.test.connect" and proceed.
> Am 11.05.2018 um 16:28 schrieb Mark Webb-Johnson:
>> Trying the new web setup, but not getting very far…
>> I (503580) webserver: HTTP GET /
>> I (503590) webserver: HTTP GET /cfg/init
>> I (503590) webserver: CfgInit enter 2.test.connect
>> I (503610) webserver: HTTP GET /apple-touch-icon.png
>> I (503610) webserver: HTTP GET /assets/style.css
>> I (503730) webserver: HTTP GET /assets/script.js
>> I (503880) webserver: HTTP GET /cfg/init
>> I (503880) webserver: CfgInit enter 2.test.connect
>> I (513960) webserver: HTTP GET /cfg/init
>> I (513960) webserver: CfgInit enter 2.test.connect
>> I (514000) webserver: HTTP GET /apple-touch-icon.png
>> I (514000) webserver: HTTP GET /assets/style.css
>> I (514090) webserver: HTTP GET /assets/script.js
>> I (514220) webserver: HTTP GET /cfg/init
>> I (514220) webserver: CfgInit enter 2.test.connect
>> I (524280) webserver: HTTP GET /
>> I (524290) webserver: HTTP GET /cfg/init
>> I (524290) webserver: CfgInit enter 2.test.connect
>> I (524320) webserver: HTTP GET /apple-touch-icon.png
>> I (524340) webserver: HTTP GET /assets/style.css
>> I (524420) webserver: HTTP GET /assets/script.js
>> I (524590) webserver: HTTP GET /cfg/init
>> I (524590) webserver: CfgInit enter 2.test.connect
>> I (534620) webserver: HTTP GET /
>> I (534630) webserver: HTTP GET /cfg/init
>> I (534630) webserver: CfgInit enter 2.test.connect
>> I (534660) webserver: HTTP GET /apple-touch-icon.png
>> I (534660) webserver: HTTP GET /assets/style.css
>> I (534760) webserver: HTTP GET /assets/script.js
>> I (534890) webserver: HTTP GET /cfg/init
>> I (534890) webserver: CfgInit enter 2.test.connect
>> I (544940) webserver: HTTP GET /
>> I (544950) webserver: HTTP GET /cfg/init
>> I (544950) webserver: CfgInit enter 2.test.connect
>> I (544980) webserver: HTTP GET /assets/style.css
>> I (544990) webserver: HTTP GET /apple-touch-icon.png
>> I (545080) webserver: HTTP GET /assets/script.js
>> I (545250) webserver: HTTP GET /cfg/init
>> I (545250) webserver: CfgInit enter 2.test.connect
>> OVMS# wifi status
>> WiFi
>> Power: on
>> Mode: Access-Point + Client mode
>> STA SSID: HIGHWAYS
>> IP: 10.10.41.203/255.255.248.0
>> GW: 10.10.40.64
>> AP SSID: DEVBENCH
>> MAC: 30:ae:a4:43:92:c5
>> IP: 192.168.4.1
>> AP Stations: 1
>> 1: MAC: cc:44:63:89:b2:f4, IP: 192.168.4.2
>> OVMS# ota status
>> I (1141850) webserver: HTTP GET /
>> I (1141860) webserver: HTTP GET /cfg/init
>> I (1141860) webserver: CfgInit enter 2.test.connect
>> I (1141890) webserver: HTTP GET /apple-touch-icon.png
>> I (1141890) webserver: HTTP GET /assets/style.css
>> I (1141990) webserver: HTTP GET /assets/script.js
>> I (1142120) webserver: HTTP GET /cfg/init
>> I (1142120) webserver: CfgInit enter 2.test.connect
>> Can’t get out of that 2.test.connect.
>> Any ideas?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180511/587899af/attachment-0001.html>
