[Ovmsdev] esp-idf release 3.0 / master
Fri May 11 23:13:01 HKT 2018
There are two possibilities:
1) The size of the 32-bit heap region may have been reduced because
there is more code stored in RAM (perhaps for flash manipulation).
2) If the extra 32-bit RAM has been allocated from the heap, then
"module memory" would show it under "no task".
On Fri, 11 May 2018, Michael Balzer wrote:
> Update:
> Am 11.05.2018 um 09:52 schrieb Michael Balzer:
> > According to the task monitor the new 32 bit allocations account to the NetMan task:
> Nope, the 32 bit usage of the NetMan task is the same as before. So the additional usage is outside the scope of our memory tracking, so must be a system
> component -- correct, Steve?
