[Ovmsdev] esp-idf release 3.0 / master
Fri May 11 15:52:39 HKT 2018
There are lots of valuable fixes in release 3.0, some may be especially relevant for us, i.e. heap allocation and wifi.
https://github.com/espressif/esp-idf/releases
…and the master is already nearly 1000 commits ahead of that.
I've merged the current upstream/master locally and am now running the new build on my module.
So far this update has been seamless. I've kept the defaults for all new sdkconfig options, got no build issues, flashed & rebooted fine, no crashes up to now.
Firmware: 3.1.005-63-g0d5cc93/ota_0/edge (build idf ovms-3.1.005-527-g9d8e44e0 May 11 2018 08:59:12)
Things I've noticed so far:
Ping response times are on average much higher than before and much less consistent. I had 1-2 ms before on an idle module, now 1-120 ms with average ~50
ms. The release notes say "Refactor ICMP ping functionality", so that supposedly is no indicator of network performance, but I've also got the impression
web pages now load slightly slower than before and ssh output also seems to be slightly slower.
More RAM is allocated from the 32 bit pool than before. After startup, free 32 bit memory is down to 1.5 kB (was 23.6 kB before). Right after boot it's 17.1
kB, so it's not a new system component but also applies to our allocations. According to the task monitor the new 32 bit allocations account to the NetMan task:
o OVMS# mo m
Free 8-bit 47860/280828, 32-bit 1572/17828, SPIRAM 4113844/4194252
o OVMS# mo t
Number of Tasks = 19 Stack: Now Max Total Heap 32-bit SPIRAM
3FFAFB48 1 Blk esp_timer 388 644 4096 41220 644 24456
3FFBE340 2 Blk eventTask 444 1772 4608 0 0 0
3FFC053C 3 Blk OVMS Events 440 3960 7168 102236 0 11268
3FFC55B0 4 Blk OVMS CanRx 428 540 1024 0 0 0
3FFC9ED8 5 Blk ipc0 388 436 1024 7776 0 0
3FFCA4D8 6 Blk ipc1 388 436 1024 12 0 0
3FFCC300 9 Rdy IDLE 364 492 1024 0 0 0
3FFCC894 10 Rdy IDLE 368 496 1024 0 0 0
3FFCD628 11 Blk Tmr Svc 388 1812 3072 0 0 0
3FFCA8EC 16 Blk tiT 488 2024 3072 1780 0 9872
3FFD87C0 17 Blk OVMS SIMCOM 460 2492 4096 3992 0 0
3FFDA8AC 18 Blk wifi 424 2312 4096 1792 0 5204
3FFDE6D8 19 Blk OVMS Vehicle 452 2004 4096 0 0 0
3FFE20A4 20 Blk OVMS COrx 464 592 4096 0 0 0
3FFE3254 21 Blk OVMS COwrk 544 544 3072 0 0 0
3FFE8934 22 Blk OVMS Console 560 1728 6144 20 0 0
3FFEA828 23 Blk OVMS NetMan 1060 5828 7168 16492 *15488* 18056
3FFEBD50 24 Blk mdns 412 1732 4096 108 0 4
3FFF2CD8 43 Rdy mo t 696 1928 5120 0 0 72
Sadly, the SD filesystem is as slow as before.
Anything I should test / investigate?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180511/f759994b/attachment.html>
