[Ovmsdev] [ovms:213] Problems with disconnecting OVMS and losing KIA SOUL EV data
Geir Øyvind Vælidalo
geir at validalo.net
Wed May 9 01:35:27 HKT 2018
Mark,
Please forward the email address.
Best regards,
Geir
> 8. mai 2018 kl. 08:43 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> Attn: Kia Soul EV developers
> FYI: The attached feedback message arrived in a support ticket. I responded:
> I will pass on your message to the Kia Soul EV module developers. I think that some of the behaviour is intentional (for example the left blinker only while locking), but don't know enough about that particular vehicle support module to be certain.
> In general, if you see bugs in the firmware, the best place is to raise them directly on GitHub here:
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues>
> This support ticket system is only for general usage issues.
> If you would like to correspond directly with the user, let me know and I will forward email address.
>> From: help at openvehicles.com <mailto:help at openvehicles.com>
>> Subject: [ovms:213] Problems with disconnecting OVMS and losing KIA SOUL EV data
>> Date: 8 May 2018 at 2:06:12 PM HKT
>> rwk1501 has created the ticket 'Problems with disconnecting OVMS and losing
>> KIA SOUL EV data':
>> Ticket text:
>> Good day.
>> My vehicle configuration is KIA SOUL EV year of manufacture 2004 Vehicle ID:
>> <REDACTED>, OVMS Firmware: Server 2.1.1 -20121216, Car: 3.1.005 /
>> ota_1 /, App 3.12.4. Operator 4G-Tmobile. GPS and GSM antenna original OVMS.
>> OBD II connector new version left side also original OVMS. I found more
>> problems that are not working on this configuration and Android app as they
>> should. When I close my car with the original key, OVMS shuts down and no
>> longer auto-opens with the OVMS app and loses application data such as
>> mileage and vehicle status or is locked or unlocked. When the vehicle is
>> locked through the application, only the left side of the hazard warning
>> lights flashes and not all of them still close when the key is closed. After
>> four hours of OVMS, the tire pressure and battery temperature data are lost.
>> Reading the tire pressure values is always correct or almost always
>> does not correctly load one of the wheels. The app is not displayed at all
>> when the passenger's rear door is open and even when the charging port door
>> is open. The problem is even when the OVMS unit is unplugged, so when you
>> reconnect, it will lose the connection data on the vehicle and then you can
>> not log in to the vehicle and have to reconfigure it. In the OVMS
>> application, the CAC shows me a value of 52.72 Ah sometimes, even though a 50
>> Ah battery is installed in the vehicle. and SOH is 110% Wakeup car is not
>> working. Is it planned to add the air conditioning and heating function of
>> the vehicle, as well as heating and cooling the seats and possibly also
>> heating the plant? It would increase the comfort of using such a vehicle.
>> Thank you in advance for answer. Sincerely, Peter Kravec
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180508/2a3fa3dc/attachment.html>
