[Ovmsdev] Setup wizard
Tue May 8 08:27:09 HKT 2018
From what I can see, WPS support is fairly trivial if we want it.
https://github.com/espressif/esp-idf/tree/master/examples/wifi/wps
Literally just two calls, and handle the appropriate events.
But I suggest we get the new wifi driver working correctly first.
> On 8 May 2018, at 7:36 AM, Greg D. <gregd2350 at gmail.com> wrote:
> WPS isn't a good idea from a security perspective. It is (should be)
> one of the first things disabled when one sets up a new WiFi router at
> home, no? We did have (at least) one support ticket logged about not
> being able to get connected to the AP, but don't recall the root cause.
> Will moving away from the serial number-based passphrase solve that?
> Greg
> Michael Balzer wrote:
>> Btw, I've seen a WPS API, do you think we can use that?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180508/f7f46e40/attachment.html>
