[Ovmsdev] Issue #99, Can't turn off SIMCOM power
Thu May 3 13:53:01 HKT 2018
A simple one. Fix committed now.
> On 3 May 2018, at 1:30 PM, Stephen Casner <casner at acm.org> wrote:
> Well, it may not be quite so simple.  Unconfiguring MAX7317 then
> results in a compilation error:
> /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/ovms_webserver/src/web_cfg.cpp: In static member function 'static void OvmsWebServer::HandleCfgFirmware(PageEntry_t&, PageContext_t&)':
> /Users/casner/src/github/ovms/vehicle/OVMS.V3/components/ovms_webserver/src/web_cfg.cpp:1459:7: error: 'netif_default' was not declared in this scope
>   if (netif_default) {
> make[1]: *** [src/web_cfg.o] Error 1
> make: *** [component-ovms_webserver-build] Error 2
> On Thu, 3 May 2018, Mark Webb-Johnson wrote:
>> Steve,
>> Makes sense. I've added it to the Kconfig.
>>> On 3 May 2018, at 5:27 AM, Stephen Casner <casner at acm.org> wrote:
>>> As I commented on Issue #99, I created the problem with SIMCOM not
>>> powering off because I had excluded CONFIG_OVMS_COMP_MAX7317 from the
>>> config and the power to the SIMCOM is controlled through the MAX7317
>>> chip.
>>> Would it make sense in Kconfig for config OVMS_COMP_MODEM_SIMCOM
>>> to depend upon OVMS_COMP_MAX7317?
>>>                                                       -- Steve
