[Ovmsdev] 3.1.005
Wed May 2 05:19:38 HKT 2018
The continuing saga...  No, this illegal instruction reboot loop is
_not_ a consequence of the 3.1.005 ovms3.bin file being inappropriate
for my v3.0 hardware.  When I "git pull" and build with my own
sdkconfig as before I get the same result.  I'll try going back to an
earlier commit to verify if some code change caused this behavior.
> > On Tue, 1 May 2018, Mark Webb-Johnson wrote:
> > > OK. v3.1.005 is built and out (in both edge and main).
> > While running 3.1.003, I just did flash from web, letting it default
> > to the latest release.  What I got was another copy of 3.1.003, not
> > 3.1.005.
> Oh, perhaps this result was because I have a v3.0 hardware module
> rather than v3.1?  My second attempt was to go to the
> api.openvehicles.com/node/211 announcement of the v3.1.005 update and
> clicked on the "Latest Firmware" link.  When I put the ovms3.bin file
> on my SD card and inserted it the software failed to boot up all the
> way, continuously looping to produce the output attached below.
> rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
> configsip: 156795334, SPIWP:0xee
> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
> mode:DIO, clock div:2
> load:0x3fff0018,len:4
> load:0x3fff001c,len:4584
> load:0x40078000,len:0
> ho 12 tail 0 room 4
> load:0x40078000,len:13184
> entry 0x40078d38
> Guru Meditation Error: Core  0 panic'ed (IllegalInstruction)
> . Exception was unhandled.
> Core 0 register dump:
> PC      : 0x400e05d4  PS      : 0x00060530  A0      : 0x800ddf7f  A1      : 0x3ffe3bd0
> 0x400e05d4: heap_bubble_down at /Users/casner/src/github/esp-idf/components/log/./log.c:299
> A2      : 0x00000001  A3      : 0x00000001  A4      : 0x88000070  A5      : 0x3ff133fc
> A6      : 0x3ff00044  A7      : 0x00000080  A8      : 0x80084330  A9      : 0x3ff49050
> A10     : 0x3ffe3bd0  A11     : 0x000000e1  A12     : 0x0ffd114c  A13     : 0x00000000
> A14     : 0x000000ff  A15     : 0x00000001  SAR     : 0x00000017  EXCCAUSE: 0x00000000
> EXCVADDR: 0x00000000  LBEG    : 0x40098a6c  LEND    : 0x40098a77  LCOUNT  : 0x00000000
> Backtrace: 0x400e05d4:0x3ffe3bd0 0x400ddf7c:0x3ffe3c00 0x40081602:0x3ffe3c20 0x40078aca:0x3ffe3c40 0x40078b7d:0x3ffe3c70 0x40078d11:0x3ffe3cb0 0x40078e5a:0x3ffe3e70 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20
> 0x400ddf7c: heap_caps_check_integrity_all at /Users/casner/src/github/esp-idf/components/heap/./heap_caps.c:409
> 0x40081602: timer_insert at /Users/casner/src/github/esp-idf/components/esp32/./esp_timer.c:400
> Rebooting...
> ets Jun  8 2016 00:22:57
> configsip: 156795334, SPIWP:0x00
> load:0x3fff0008,len:8
> load:0x3fff1150,len:3472
> load:0x4147c154,len:273751932
> 1162 mmu set 00010000, pos 00010000
> 1162 mmu set 00020000, pos 00020000
> 1162 mmu set 00030000, pos 00030000
> 1162 mmu set 00040000, pos 00040000
> 1162 mmu set 00050000, pos 00050000
> 1162 mmu set 00060000, pos 00060000
> 1162 mmu set 00070000, pos 00070000
> 1162 mmu set 00080000, pos 00080000
> 1162 mmu set 00090000, pos 00090000
> 1162 mmu set 000a0000, pos 000a0000
> 1162 mmu set 000b0000, pos 000b0000
> 1162 mmu set 000c0000, pos 000c0000
> 1162 mmu set 000d0000, pos 000d0000
> 1162 mmu set 000e0000, pos 000e0000
> 1162 mmu set 000f0000, pos 000f0000
> 1162 mmu set 00100000, pos 00100000
> 1162 mmu set 00110000, pos 00110000
> 1162 mmu set 00120000, pos 00120000
> 1162 mmu set 00130000, pos 00130000
> 1162 mmu set 00140000, pos 00140000
> 1162 mmu set 00150000, pos 00150000
> 1162 mmu set 00160000, pos 00160000
> 1162 mmu set 00170000, pos 00170000
> 1162 mmu set 00180000, pos 00180000
> 1162 mmu set 00190000, pos 00190000
> 1162 mmu set 001a0000, pos 001a0000
> 1162 mmu set 001b0000, pos 001b0000
> 1162 mmu set 001c0000, pos 001c0000
> 1162 mmu set 001d0000, pos 001d0000
> 1162 mmu set 001e0000, pos 001e0000
> 1162 mmu set 001f0000, pos 001f0000
> 1162 mmu seets Jun  8 2016 00:22:57
> rst:0x10 (RTCWDT_RTC_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
> ho 12 tail 0 room 4
> entry 0x40078d38
> A14     : 0x000008ff  A15     : 0x00000001  SAR     : 0x00000017  EXCCAUSE: 0x00000000
> Rebooting...
