[Ovmsdev] 3.1.005
Wed May 2 04:26:56 HKT 2018
On Tue, 1 May 2018, Stephen Casner wrote:
> On Tue, 1 May 2018, Mark Webb-Johnson wrote:
> > OK. v3.1.005 is built and out (in both edge and main).
> While running 3.1.003, I just did flash from web, letting it default
> to the latest release.  What I got was another copy of 3.1.003, not
> 3.1.005.
Oh, perhaps this result was because I have a v3.0 hardware module
rather than v3.1?  My second attempt was to go to the
api.openvehicles.com/node/211 announcement of the v3.1.005 update and
clicked on the "Latest Firmware" link.  When I put the ovms3.bin file
on my SD card and inserted it the software failed to boot up all the
way, continuously looping to produce the output attached below.
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 156795334, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4584
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:13184
entry 0x40078d38
Guru Meditation Error: Core  0 panic'ed (IllegalInstruction)
. Exception was unhandled.
Core 0 register dump:
PC      : 0x400e05d4  PS      : 0x00060530  A0      : 0x800ddf7f  A1      : 0x3ffe3bd0
0x400e05d4: heap_bubble_down at /Users/casner/src/github/esp-idf/components/log/./log.c:299
A2      : 0x00000001  A3      : 0x00000001  A4      : 0x88000070  A5      : 0x3ff133fc
A6      : 0x3ff00044  A7      : 0x00000080  A8      : 0x80084330  A9      : 0x3ff49050
A10     : 0x3ffe3bd0  A11     : 0x000000e1  A12     : 0x0ffd114c  A13     : 0x00000000
A14     : 0x000000ff  A15     : 0x00000001  SAR     : 0x00000017  EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000  LBEG    : 0x40098a6c  LEND    : 0x40098a77  LCOUNT  : 0x00000000
Backtrace: 0x400e05d4:0x3ffe3bd0 0x400ddf7c:0x3ffe3c00 0x40081602:0x3ffe3c20 0x40078aca:0x3ffe3c40 0x40078b7d:0x3ffe3c70 0x40078d11:0x3ffe3cb0 0x40078e5a:0x3ffe3e70 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20
0x400ddf7c: heap_caps_check_integrity_all at /Users/casner/src/github/esp-idf/components/heap/./heap_caps.c:409
0x40081602: timer_insert at /Users/casner/src/github/esp-idf/components/esp32/./esp_timer.c:400
Rebooting...
ets Jun  8 2016 00:22:57
configsip: 156795334, SPIWP:0x00
load:0x3fff0008,len:8
load:0x3fff1150,len:3472
load:0x4147c154,len:273751932
1162 mmu set 00010000, pos 00010000
1162 mmu set 00020000, pos 00020000
1162 mmu set 00030000, pos 00030000
1162 mmu set 00040000, pos 00040000
1162 mmu set 00050000, pos 00050000
1162 mmu set 00060000, pos 00060000
1162 mmu set 00070000, pos 00070000
1162 mmu set 00080000, pos 00080000
1162 mmu set 00090000, pos 00090000
1162 mmu set 000a0000, pos 000a0000
1162 mmu set 000b0000, pos 000b0000
1162 mmu set 000c0000, pos 000c0000
1162 mmu set 000d0000, pos 000d0000
1162 mmu set 000e0000, pos 000e0000
1162 mmu set 000f0000, pos 000f0000
1162 mmu set 00100000, pos 00100000
1162 mmu set 00110000, pos 00110000
1162 mmu set 00120000, pos 00120000
1162 mmu set 00130000, pos 00130000
1162 mmu set 00140000, pos 00140000
1162 mmu set 00150000, pos 00150000
1162 mmu set 00160000, pos 00160000
1162 mmu set 00170000, pos 00170000
1162 mmu set 00180000, pos 00180000
1162 mmu set 00190000, pos 00190000
1162 mmu set 001a0000, pos 001a0000
1162 mmu set 001b0000, pos 001b0000
1162 mmu set 001c0000, pos 001c0000
1162 mmu set 001d0000, pos 001d0000
1162 mmu set 001e0000, pos 001e0000
1162 mmu set 001f0000, pos 001f0000
1162 mmu seets Jun  8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
ho 12 tail 0 room 4
entry 0x40078d38
A14     : 0x000008ff  A15     : 0x00000001  SAR     : 0x00000017  EXCCAUSE: 0x00000000
Rebooting...
