[Ovmsdev] Time spent in ticker event handlers / new use for housekeeping task
    Fri Mar 30 22:18:31 HKT 2018
> If you exceed 1 second, the monotonictime will start to jump and lose sync with real time.
There is actually a way around that (increment monotonictime in the timer handler, not in housekeeping task). The ticker.* calls still won’t go, but monotonictime will at least still increase at a reasonably accurate rate.
> On 29 Mar 2018, at 11:46 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> thanks, that's even better. We can also reduce the timer task stack now. 6K is the current size, I think we should now be able to set this to 1K, maybe 1.5. I'll try running it at 1K and report.
> For other ticker users: you may now use blocking calls (i.e. semaphore or queue waits) and do longer processing in ticker event handlers. Up to 1 second total time should be possible now (but not recommended). If you exceed 1 second, the monotonictime will start to jump and lose sync with real time.
> Am 29.03.2018 um 03:09 schrieb Mark Webb-Johnson:
>> Done, and committed. Seems ok.
>>> On 29 Mar 2018, at 8:39 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>> Michael,
>>> Yes, this is nasty and really not the correct way of doing things. The housekeeping task is wasted, and moving the ticker signals into that would make much more sense.
>>> I’ll handle this. Shouldn’t take me long, and I can commit in the next hour or so.
>>>> On 29 Mar 2018, at 2:50 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>> A question to the FreeRTOS gurus:
>>>> How much time may we spend in a ticker event handler, or generally a software timer callback, without risking system stability?
>>>> The FreeRTOS manual explicitly warns about using any kind of blocking calls within the timer service task, as all software timer callbacks are executed in that context:
>>>> https://freertos.org/RTOS-software-timer.html <https://freertos.org/RTOS-software-timer.html>
>>>> "Timer callback functions execute in the context of the timer service task. It is therefore essential that timer callback functions never attempt to block. For example, a timer callback function must not call vTaskDelay(), vTaskDelayUntil(), or specify a non zero block time when accessing a queue or a semaphore."
>>>> The timer service queue currently has 10 slots. That's tunable, but I'm also worried about other system components possibly relying on regular timer periods of higher frequency.
>>>> My specific issue: I'm producing the notifications from my  ticker1 handler. I now found out a simple standard info notification needs already around 10 ms, and my battery status update (15 data messages) needs 60-70 ms. I thought these would run faster, not sure where the time is spent. I'm using the command notifications, nice to use but with quite some                           overhead of course.
>>>> So if for example the wifi or bluetooth stack needs a 50 ms timer, that may already be a problem. But do system components use software timers for time critical tasks?
>>>> The solution would be moving the notification generator to a separate task. A new task would need RAM, but there's also the housekeeping task, which could generally be made available for such needs. It's basically idle after the init process and already has a large stack. I think about adding a callback execution queue to it, so my ticker handler would simply queue the notification generator call there.
>>>> Thanks,
>>>> Michael
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180330/a85e1cbc/attachment.htm>
