[Ovmsdev] Webserver "status" crash
Fri Mar 30 15:46:41 HKT 2018
Greg,
I just realized your crash like my latest one also had that STA disconnect reason 200 entry. So maybe that's not memory related.
I can't get a usable addr2line output from your backtrace, I think my .elf file is too different from yours (lots of excluded components here).
Can you provide that using your build?
Thanks,
Am 27.03.2018 um 04:23 schrieb Greg D.:
> Hi folks,
> The module has been sitting on my desk, simply minding its own business.  During dinner I thought I'd poke at the webserver a bit, connecting to the module
> via the home wifi network (i.e. not the AP side).  That's usually pretty reliable.  Wasn't this time...
> The "failed to allocate socket" message suggests the crash was a down-stream result of being out of memory, but posting here to verify that.  Wonder if the
> error's recovery is possible, or do we simply need the extra memory so it doesn't happen in the first place.
> Greg
> I (81600417) housekeeping: Local time: Tue Mar 27 00:39:37 2018
> I (81692297) webserver: HTTP GET /
> I (81692327) webserver: HTTP GET /assets/style.css
> I (81692337) webserver: HTTP GET /assets/script.js
> I (81692337) webserver: HTTP GET /apple-touch-icon.png
> I (81693477) webserver: HTTP GET /home
> I (81693477) webserver: HTTP GET /apple-touch-icon.png
> I (81710387) webserver: HTTP GET /
> I (81710427) webserver: HTTP GET /assets/style.css
> I (81710577) webserver: HTTP GET /home
> I (81716207) webserver: HTTP GET /status
> W (81716357) net: Error: Failed to allocate socket
> I (81722557) wifi: bcn_timout,ap_probe_send_start
> I (81725057) wifi: ap_probe_send over, resett wifi status to disassoc
> I (81725067) wifi: state: run -> init (1)
> I (81725067) wifi: n:6 0, o:6 0, ap:6 2, sta:6 0, prof:6
> I (81725067) netmanager: Interface priority is pp3 (10.170.146.142/255.255.255.255 <http://10.170.146.142/255.255.255.255> gateway 10.64.64.64)
> I (81725067) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
> I (81725067) time: Network was reconfigured: restarting SNTP client
> I (81725077) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
> I (81725077) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
> *I (81725077) esp32wifi: STA disconnected with reason 200*
> I (81725127) ovms-server-v2: Status: Disconnected
> I (81744417) ovms-server-v2: Connection is tmc.openvehicles.com:6867 <http://tmc.openvehicles.com:6867> ROADSTER_834
> I (81744417) ovms-server-v2: Status: Connecting...
> OVMS> Guru Meditation Error: Core  1 panic'ed (StoreProhibited)
> . Exception was unhandled.
> Core 1 register dump:
> PC      : 0x400f8a9a  PS      : 0x00060a30  A0      : 0x800f8c3c  A1      : 0x3ffeafa0
> A2      : 0x3fffb1d4  A3      : 0x3fffbd04  A4      : 0x00000001  A5      : 0x00000000
> A6      : 0x00000014  A7      : 0x3ffb10b8  A8      : 0x000000a2  A9      : 0x3ffeaf80
> A10     : 0x3ffeafa0  A11     : 0x00000040  A12     : 0x3f40cb7c  A13     : 0x8c860000
> A14     : 0x16f35000  A15     : 0x00000000  SAR     : 0x00000001  EXCCAUSE: 0x0000001d
> EXCVADDR: 0x0000000a  LBEG    : 0x40147a40  LEND    : 0x40147a5f  LCOUNT  : 0x00000000
> Backtrace: 0x400f8a9a:0x3ffeafa0 0x400f8c39:0x3ffeafd0 0x400f6ac3:0x3ffeb010 0x400f6d86:0x3ffeb040 0x400f8065:0x3ffeb070 0x400f8311:0x3ffeb0b0
> 0x400f4af1:0x3ffeb100 0x400e735a:0x3ffeb120 0x400e7399:0x3ffeb170
> Rebooting..
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180330/3af49010/attachment.htm>
