[Ovmsdev] Duktape handling of blank metrics?
Greg D.
gregd2350 at gmail.com
Thu Mar 29 09:44:38 HKT 2018
So, now it's failing at my desk, too. Good - a lot easier to grab a
backtrace... But, it's also happening whether the metrics are set or
not. I've updated the code to the current (including your housekeeping
changes); not sure if that made a difference.
OVMS> vfs cat /store/obd2ecu/10
ret1=OvmsMetricFloat("v.p.speed");
ret2=OvmsMetricFloat("v.b.power");
out = 0.0;
if(ret1 > 0) { out=ret2/ret1; }
out;
OVMS> obdii ecu list
PID Type Value Metric
0 (0x00) internal 0.000000
4 (0x04) internal 0.000000 v.b.soc
5 (0x05) metric 0.000000 v.e.temp
***ERROR*** A stack overflow in task AsyncConsole has been detected.
abort() was called at PC 0x4008ecc4 on core 1
Backtrace: 0x4008ead4:0x3fff2f50 0x4008ecab:0x3fff2f70
0x4008ecc4:0x3fff2f90 0x4008ab6b:0x3fff2fb0 0x4008cd94:0x3fff2fd0
0x4008cd4a:0x3fff600c
Rebooting...
Mark Webb-Johnson wrote:
> Need to see a backtrace. Perhaps you are just on the borderline of stack usage, or something going crazy?
> Looking at DukOvmsMetricFloat(), it just return the metric AsFloat(), and for float type metrics that should just be zero if not defined.
>> On 29 Mar 2018, at 8:58 AM, Greg D. <gregd2350 at gmail.com> wrote:
>> Hi folks,
>> Does anyone know how DukTape scripting handles math with a metric that
>> hasn't been updated yet?
>> I have a short example script in the OBDII ECU documentation which
>> (should) calculate a power-per-speed metric for display on a HUD. Seems
>> like it would be a useful example, and wanted to verify that it actually
>> works.
>> out = 0.0;
>> out;
>> I have the module in the my Roadster, and the v.p.speed metric comes up
>> as 0 kph (that's good - it's parked), but the power metric isn't
>> provided by the car, so is blank when listing the metrics. I expected
>> the code to return zero.
>> Instead, executing the script by asking for 'obdii ecu list' causes an
>> immediate crash with a stack overflow in task AsyncConsole. If I
>> initialize the power metric by hand (metric set v.b.power 0), the script
>> runs just fine, returning 0 for the metric.
>> Oddly, when I first set it up on the desk (sans vehicle), so both of the
>> metrics were blank, executing the script didn't cause crash.
>> Is there a way to make the code "Roadster safe", without dummying up the
>> metric in, say, a startup script? Better, is there a fix for DukTape to
>> handle this, or should I just increase the stack size in AsyncConsole?
>> Thanks,
>> Greg
