Tom Parker
tom at carrott.org
Sun Mar 25 03:39:32 HKT 2018
On 25/03/18 02:41, Mark Webb-Johnson wrote:
> What do you mean by ‘disable and reactivate the SIM card’? How are you doing that?
I have access to Spark's m2m service which allows customers to
deactivate and reactivate simcards. The deactivation is immediate, I can
see the simcom reports it is disconnected and the ovms starts trying to
reconnect. Last time I tried, when I reactivated, the simcom reconnected
to the cell phone network but the ovms never re-established a ppp
connection. I can send it sms messages and see them show up in the
simcom logging so I know some things are working. I last tried this a
couple of weeks ago, I'll try again tomorrow.
I have a range of devices on this service and some of the reconnect
while other don't, so the ovms isn't the only one having trouble.
> The issue I was having was some task (I suspect lwip) gets messed up. Stopping the modem, trying to connect wifi, etc, all just locked up the async console. I think you had the same?
I've certainly had situations where doing simcom power off causes the
async console to freeze, but I've only tried to do that after the
cellular is has stopped working.
> Cellular connectivity should be a different issue. Maybe just can’t connect to the signal - but the logs should tell us more info. We can also directly issue AT commands when the modem is in that state to try to find out why.
Any advice on which commands to try when it's not connected?
