[Ovmsdev] webserver (?) crash
Tue Mar 20 15:29:41 HKT 2018
I mostly get it when using AP + CLIENT + MODEM, and everything transmitting.
> On 20 Mar 2018, at 3:21 PM, Greg D. <gregd2350 at gmail.com> wrote:
> Ha, interesting. I've been running the module mostly from the high
> power port on my laptop, with 12v applied only when I was driving the
> external CAN bus dongle things. I don't recall framing errors being a
> problem in the past, but I connected the 12v and it appears that the
> framing errors have stopped. I'll let it run the night, and see what
> happens by morning.
> Greg
> Mark Webb-Johnson wrote:
>> Framing errors would be indicative of a mux issue, not really RF
>> signal. Are you sure the modem is not browning out from lack of power?
>> Are you seeing any ..START.. messages in the log (which is a modem
>> restart)? I was getting a lot of these until I switched to a powered
>> USB hub. How are you powering this - 5v usb or 12v?
