[Ovmsdev] Memory leak
Mon Mar 19 19:20:27 HKT 2018
Steve,
I've seen some allocations looking like memory leaks but getting freed after a minute or two. I assume those are mongoose buffers or LWIP socket
structs getting freed after some timeout.
But if I remember right, those were accounted for on the TCP/IP task and/or the NetManTask, not on dynamic tasks.
I start dynamic tasks primarily for web command execution in streaming mode. The "vfs tail" command also runs as a dynamic task.
If you had the mDNS component still active, that could also be the cause.
Am 19.03.2018 um 06:37 schrieb Stephen Casner:
> I see there are a couple of tasks that allocated memory but did not
> free it. These are the tasks identified by TCB address in the module
> memory listing:
> OVMS# mo m
> Free 8-bit 32968/283136, 32-bit 27588/55864, SPIRAM 0/0
> --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM
> no task 5276 0 0 0 +5276 +0 +0 +0
> esp_timer 55300 0 644 0 +55300 +0 +644 +0
> main 40072 0 0 0 +40072 +0 +0 +0
> ipc0 10848 0 0 0 +10848 +0 +0 +0
> Housekeeping 17588 44112 0 0 +17588 +44112 +0 +0
> ipc1 12 0 0 0 +12 +0 +0 +0
> tiT 136 1676 0 0 +136 +1676 +0 +0
> NetManTask 8 2196 0 0 +8 +2196 +0 +0
> wifi 0 1600 0 0 +0 +1600 +0 +0
> eventTask 0 12960 0 0 +0 +12960 +0 +0
> 3FFE3E78 0 1396 0 0 +0 +1396 +0 +0
> Tmr Svc 0 27808 0 0 +0 +27808 +0 +0
> 3FFEAFE4 0 88 0 0 +0 +88 +0 +0
> AsyncConsole 0 20 27488 0 +0 +20 +27488 +0
> OVMS# mo t
> Number of Tasks = 16 Stack: Now Max Total Heap 32-bit SPIRAM
> Task 3FFAFAB0 1 esp_timer 0 61770 65278 55300 644 0
> Task 3FFBDFC4 2 eventTask 0 63886 65278 12960 0 0
> Task 3FFC6630 3 CanRxTask 0 61610 65278 0 0 0
> Task 3FFCDA54 4 ipc0 0 64702 65278 10848 0 0
> Task 3FFCE054 5 ipc1 0 64702 65278 12 0 0
> Task 3FFCFE7C 8 IDLE 0 64742 65278 0 0 0
> Task 3FFD0410 9 IDLE 0 64746 65278 0 0 0
> Task 3FFD1DA4 10 Tmr Svc 0 61678 65278 27808 0 0
> Task 3FFD9DC8 14 Housekeeping 0 62478 65278 61700 0 0
> Task 3FFCE2C0 16 tiT 0 63506 65278 1812 0 0
> Task 3FFE327C 17 SIMCOMTask 0 61638 65278 0 0 0
> Task 3FFF0654 22 AsyncConsole 0 62510 65278 20 27488 0
> Task 3FFE8464 25 wifi 0 63474 65278 1600 0 0
> Task 3FFF1828 26 pmT 0 64398 65278 0 0 0
> Task 3FFE82CC 29 NetManTask 0 60254 65278 2204 0 0
> Task 3FFEC408 30 mdns 0 62906 65278 0 0 0
> OVMS#
> -- Steve
