[Ovmsdev] wifi not coming all the way up?
Julien “JaXX” Banchet jaxx at jaxx.org
Mon Mar 19 16:56:57 HKT 2018
Having the same,
Actually, I have to stick to client or apclient mode (otherwise it crash reboots), it doesn’t like an empty or non set wifi.ssid.client neither in auto.
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 156795334, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4572
load:0x40078000,len:0
load:0x40078000,len:13184
entry 0x40078d38
I (33) ovms_main: Set default logging level for * to WARN
E (34) boot: Crash #6 detected
E (727) esp32wifi: AutoInit: Wifi client SSID must be specified in wifi.ssid.client
OVMS > en
Password:
Secure mode
OVMS # config set auto wifi.ssid.client JaXX <— here I very quickly set wifi.ssid.client before the next crash
OVMS # ***ERROR*** A stack overflow in task tiT has been detected.
abort() was called at PC 0x4008efb0 on core 1
0x4008efb0: vApplicationStackOverflowHook at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648
Backtrace: 0x4008edc0:0x3ffca860 0x4008ef97:0x3ffca880 0x4008efb0:0x3ffca8a0 0x4008b470:0x3ffca8c0 0x4008d390:0x3ffca8e0 0x4008d346:0x00000002
0x4008edc0: invoke_abort at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648
0x4008ef97: abort at /Users/jaxx/Projects/esp-idf/components/esp32/./panic.c:648
0x4008b470: vTaskSwitchContext at /Users/jaxx/Projects/esp-idf/components/freertos/./tasks.c:4837
0x4008d390: _frxt_dispatch at /Users/jaxx/Projects/esp-idf/components/freertos/./portasm.S:406
0x4008d346: _frxt_int_exit at /Users/jaxx/Projects/esp-idf/components/freertos/./portasm.S:206
Rebooting...
ets Jun  8 2016 00:22:57
As soon as the modem arrives in RegisteredHom/NetMode, usually under a minute, wifi (pings && web server) becomes mute and ovmsv2 server (using dexters’ won’t refresh).
OVMS > simcom
SIMCOM
  Network Registration: RegisteredHome
  State: NetMode
  Ticker: 2
  User Data: 0
  Mux
    Status: up
    Open Channels: 4
    Framing Errors: 0
    Last RX frame: 1 sec(s) ago
    RX frames: 52
    TX frames: 15
  PPP
    Not Connected
    Last Error: Undefined
  GPS
    Status: enabled, required
    Time: enabled, required
    NMEA: GPS/GLONASS Connected on channel: #1
OVMS > network
Interface#3: pp3 (ifup=1 linkup=1)
  IPv4: 10.238.244.249/255.255.255.255 gateway 10.64.64.64
Interface#2: ap2 (ifup=1 linkup=1)
  IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
Interface#1: st1 (ifup=1 linkup=1)
  IPv4: 10.33.92.20/255.255.255.0 gateway 10.33.92.1
Interface#0: lo0 (ifup=1 linkup=1)
  IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
DNS: 212.27.40.240 212.27.40.241
Default Interface: st1 (10.33.92.20/255.255.255.0 gateway 10.33.92.1)
OVMS >
(Home being 10.33.92.0/24)
JaXX,
sorry for not being around btw./.
On 19 Mar 2018 at 04:39 +0100, Greg D. <gregd2350 at gmail.com>, wrote:
> For what it's worth, I have the default log level at Info, and have no
> trouble getting WiFi to connect (with IP).
> That said, my module is currently in a state where both wifi and modem
> have IP addresses, but the server can't (or won't) connect. Stopping /
> starting the V2 server hangs the module (no prompt returned). Repeated
> the test, and the bad state seems to occur just after the modem gets its
> IP address. Wifi connected or not, that's the last the module will talk
> to anything else.
> Greg
> Stephen Casner wrote:
> > Hmmm, I just did a config change for the default log level from WARN
> > to INFO so I could see more of the timing of wifi and MDNS starting,
> > etc. Now the wifi does get an address and the status looks good.
> > Perhaps some subtle timing sensitivity?
> > -- Steve
> > On Mon, 19 Mar 2018, Mark Webb-Johnson wrote:
> > > Very bizarre. Nothing in auto should affect this.
> > > You've tried resetting the module?
> > > Can you paste the output of 'wifi scan', so we can see the APs in range?
> > > Regards, Mark.
> > > > On 19 Mar 2018, at 9:11 AM, Stephen Casner <casner at acm.org> wrote:
> > > > Here's my wifi status:
> > > > OVMS # wifi mode client Revelstoke
> > > > Starting WIFI as a client to Revelstoke...
> > > > I (316264) wifi: wifi firmware version: ebd3e5d
> > > > I (316264) wifi: config NVS flash: enabled
> > > > I (316264) wifi: config nano formating: disabled
> > > > I (316264) wifi: Init dynamic tx buffer num: 16
> > > > I (316264) wifi: Init data frame dynamic rx buffer num: 16
> > > > I (316264) wifi: Init management frame dynamic rx buffer num: 16
> > > > I (316264) wifi: wifi driver task: 3ffe8390, prio:23, stack:4096
> > > > I (316264) wifi: Init static rx buffer num: 4
> > > > I (316264) wifi: Init dynamic rx buffer num: 16
> > > > I (316264) wifi: wifi power manager task: 0x3ffef838 prio: 21 stack: 2560
> > > > I (316274) wifi: mode : sta (30:ae:a4:37:1b:84)
> > > > I (318694) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
> > > > I (319344) wifi: state: init -> auth (b0)
> > > > I (319354) wifi: state: auth -> assoc (0)
> > > > I (319364) wifi: state: assoc -> run (10)
> > > > I (319394) wifi: connected with Revelstoke, channel 1
> > > > I (322364) wifi: pm start, type:0
> > > > OVMS # wifi status
> > > > WiFi
> > > > Power: on
> > > > Mode: Client mode
> > > > STA SSID: Revelstoke
> > > > MAC: 00:00:00:00:00:00
> > > > IP: 0.0.0.0/0.0.0.0
> > > > GW: 0.0.0.0
> > > > OVMS # net
> > > > DNS: None
> > > > Default Interface: None
> > > > OVMS #
> > > > My laptop is connected to Revelstoke, so I know it is working.
> > > > Is there some aspect of auto-start that I need now to have this work?
> > > > -- Steve
> > > > > That is not correct, at all.
> > > > > For a case where you have a wifi STA connection, but no IP address yet, you should see the 'st' network interface, but without an IP. In fact, the 'st' interface should appear as soon as you start the wifi client. What does 'wifi status' show you?
> > > > > Trying to catch mine, between STA connected and IP assigned, this is what I get:
> > > > > OVMS # wifi mode client STA
> > > > > Starting WIFI as a client to STA...
> > > > > I (27218) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
> > > > > I (27108) wifi: wifi firmware version: ebd3e5d
> > > > > I (27118) wifi: config NVS flash: enabled
> > > > > I (27118) wifi: config nano formating: disabled
> > > > > I (27118) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
> > > > > I (27128) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
> > > > > I (27128) wifi: Init dynamic tx buffer num: 16
> > > > > I (27128) wifi: Init data frame dynamic rx buffer num: 16
> > > > > I (27138) wifi: Init management frame dynamic rx buffer num: 16
> > > > > I (27138) wifi: wifi driver task: 3ffe5f94, prio:23, stack:4096
> > > > > I (27138) wifi: Init static rx buffer num: 4
> > > > > I (27148) wifi: Init dynamic rx buffer num: 16
> > > > > I (27148) wifi: wifi power manager task: 0x3ffea128 prio: 21 stack: 2560
> > > > > I (27218) wifi: mode : sta (re:da:ct:ed:da:ta)
> > > > > OVMS # network
> > > > > Interface#1: st1 (ifup=0 linkup=1)
> > > > > IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0
> > > > > DNS: None
> > > > > I (30268) wifi: n:11 0, o:1 0, ap:255 255, sta:11 0, prof:1
> > > > > I (30938) wifi: state: init -> auth (b0)
> > > > > I (30948) wifi: state: auth -> assoc (0)
> > > > > I (30958) wifi: state: assoc -> run (10)
> > > > > I (30978) wifi: connected with STA, channel 11
> > > > > OVMS # network
> > > > > DNS: None
> > > > > Default Interface: st1 (0.0.0.0/0.0.0.0 gateway 0.0.0.0)
> > > > > I (33968) wifi: pm start, type:0
> > > > > I (34288) event: sta ip: x.x.x.56, mask: 255.255.255.0, gw: x.x.x.62
> > > > > I (34288) netmanager: Set DNS#0 8.8.8.8
> > > > > I (34298) netmanager: Set DNS#1 8.8.4.4
> > > > > I (34298) netmanager: Interface priority is st1 (x.x.x.56/255.255.255.0 gateway x.x.x.62)
> > > > > I (34308) time: Starting SNTP client
> > > > > I (34318) ovms-mdns: Starting MDNS service
> > > > > I (34318) esp32wifi: WiFi UP with SSID: STUBBY, MAC: re:da:ct:ed:da:ta, IP: x.x.x.56, mask: 255.255.255.0, gw: x.x.x.62
> > > > > I (34348) webserver: Launching Web Server
> > > > > I (34358) ssh: Launching SSH Server
> > > > > OVMS # network
> > > > > IPv4: x.x.x.56/255.255.255.0 gateway x.x.x.62
> > > > > DNS: 8.8.8.8 8.8.4.4
> > > > > Default Interface: st1 (x.x.x.56/255.255.255.0 gateway x.x.x.62)
> > > > > D (40248) time: ntp (stratum 1 trusted 1) provides time Mon Mar 19 01:03:25 2018 (535294us) UTC
> > > > > OVMS # wifi status
> > > > > WiFi
> > > > > Power: on
> > > > > Mode: Client mode
> > > > > STA SSID: STUBBY
> > > > > IP: x.x.x.56/255.255.255.0
> > > > > GW: x.x.x.62
> > > > > Regards, Mark.
> > > > > > On 19 Mar 2018, at 8:52 AM, Stephen Casner <casner at acm.org> wrote:
> > > > > > When I start wifi client, it looks like it has acquired the link, but
> > > > > > not done DHCP to get an address?
> > > > > > -- Steve
> > > > > > I (742914) wifi: wifi firmware version: ebd3e5d
> > > > > > I (742914) wifi: config NVS flash: enabled
> > > > > > I (742914) wifi: config nano formating: disabled
> > > > > > I (742914) wifi: Init dynamic tx buffer num: 16
> > > > > > I (742914) wifi: Init data frame dynamic rx buffer num: 16
> > > > > > I (742914) wifi: Init management frame dynamic rx buffer num: 16
> > > > > > I (742914) wifi: wifi driver task: 3fff1044, prio:23, stack:4096
> > > > > > I (742914) wifi: Init static rx buffer num: 4
> > > > > > I (742914) wifi: Init dynamic rx buffer num: 16
> > > > > > I (742914) wifi: wifi power manager task: 0x3ffe81d8 prio: 21 stack: 2560
> > > > > > I (742924) wifi: mode : sta (30:ae:a4:37:1b:84)
> > > > > > I (745344) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
> > > > > > I (745994) wifi: state: init -> auth (b0)
> > > > > > I (746004) wifi: state: auth -> assoc (0)
> > > > > > I (746014) wifi: state: assoc -> run (10)
> > > > > > I (746054) wifi: connected with Revelstoke, channel 1
> > > > > > I (749014) wifi: pm start, type:0
> > > > > > OVMS # net
> > > > > > DNS: None
> > > > > > OVMS #
> > > > > > _______________________________________________
> > > > > > OvmsDev mailing list
> > > > > > OvmsDev at lists.teslaclub.hk
> > > > > > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180319/8e18fe7f/attachment.htm>
