[Ovmsdev] MDNS crash
Stephen Casner
casner at acm.org
Mon Mar 19 12:14:30 HKT 2018
Greg, the async console is a separate task that should be able to look
at some things as long as they don't depend upon the networking tasks
or objects. Is it hung also?
On Sun, 18 Mar 2018, Greg D. wrote:
> Ok, so not *in* SNTP, but related to SNTP. After a minute's wait, I saw a pair of
> records get "sent" to the v2 server. They never arrived. After that, I tried the
> stop/start of the server, and that's where it hung. Sounds like a missing mutex
> unlock somewhere. What resources does starting the server make use of, that might
> have also been used by SNTP?
> Greg
> Greg D. wrote:
> Ok, but I'm in ap+client mode, but don't have anything attaching to the AP
> side of things.
> AP+Client, hotspot running. Boot. Client gets an IP address, server
> connects, metrics sent.
> Some time later (minutes or so), the modem finally connects. Wifi is
> still connected, and is still the primary interface, but the server is no
> longer getting updates from module. server stop, server start, hang. The
> last thing to the console this past time before the phone client no longer
> got updates was "starting SNTP client"
> Not 100% repeatable, but close to it. I think partly it depends on the
> modem's luck in getting a good cell connection; it's kind of iffy here.
> Or, is the deadlock in the SNTP client instead of MDNS?
> Greg
> Mark Webb-Johnson wrote:
> It is a task mutex lock, so for mdns I have used them in ‘wait
> forever’ mode.
> This is for the code I just submitted a few minutes ago.
> Looking at the esp-idf mdns code, I think using AP or CLIENT modes would
> have been ok. Only one interface coming up/down then. But for APCLIENT
> mode, or when switch between AP and CLIENT modes, the fault will be
> triggered.
> On 19 Mar 2018, at 11:40 AM, Greg D. <gregd2350 at gmail.com>
> wrote:
> I wonder if those locks are the cause of the hangs I'm getting. Do
> they have timers on them, or will they wait forever?
> Greg
> Messy. The issue is the restarting of mdns, coupled with
> AP/STA coming up/down in different threads. That could
> result in a mdns_free while another mdns_free or
> mdns_init is in progress. The mdns library is not thread
> safe. In particular, they mutex protect some internal
> stuff but not all of mdns_free or any of mdns_init.
> I introduced an ovms_mutex library to main. This contains some
> helpful wrapper functions to make mutexes easy and safe to
> use:
> class OvmsMutex
> Encapsulates a mutex.
> Provides Lock() and Unlock() functions to access
> it.
> class OvmsMutexLock
> Encapsulates a mutex lock in a safer
> manner.
> Constructor locks it, and destructor
> unlocks it.
> Using this is as simple as creating a
> mutex for the object to be protected,
> and then creating a
> OvmsMutexLock(&mutex) over that. When
> the OvmsMutexLock comes in scope, it
> will lock the mutex, and when it goes
> out of scope it will unlock it.
> I’ve done this in other projects, with great
> success. Using OvmsMutexLock objects means you
> never forget to unlock the mutex (no matter how
> weird and wonderful your code paths are).
> I then used OvmsMutex and OvmsMutexLock in ovms_mdns. The mdns
> stuff seems ok for me now.
> On 19 Mar 2018, at 9:51 AM, Mark Webb-Johnson
> <mark at webb-johnson.net> wrote:
> It seems that mdns_free is being called, while mdns_free
> is running…
> It is trivial to fix it in the timer deletion code, but
> that just delays the problem until a bit later (the
> hostname free).
> I am looking at this now.
> On 19 Mar 2018, at 9:40 AM, Stephen Casner
> <casner at acm.org> wrote:
> On Sun, 18 Mar 2018, Michael Balzer wrote:
> From a first look at the mdns
> code in your backtrace, I would
> guess
> that's a double free() for the
> timer, it seems the timer_handle
> never gets NULLed.
> That may be a bug (deficiency) in the
> esp-idf mDNS code.
> Perhaps I hit it because OvmsMDNS::StopMDNS
> was called without
> everything coming up correctly first?
> Steve
