[Ovmsdev] MDNS crash
Mon Mar 19 11:42:47 HKT 2018
It is a task mutex lock, so for mdns I have used them in ‘wait forever’ mode.
This is for the code I just submitted a few minutes ago.
Looking at the esp-idf mdns code, I think using AP or CLIENT modes would have been ok. Only one interface coming up/down then. But for APCLIENT mode, or when switch between AP and CLIENT modes, the fault will be triggered.
> On 19 Mar 2018, at 11:40 AM, Greg D. <gregd2350 at gmail.com> wrote:
> I wonder if those locks are the cause of the hangs I'm getting.  Do they have timers on them, or will they wait forever?
> Greg
> Mark Webb-Johnson wrote:
>> Messy. The issue is the restarting of mdns, coupled with AP/STA coming up/down in different threads. That could result in a mdns_free while another mdns_free or mdns_init is in progress. The mdns library is not thread safe. In particular, they mutex protect some internal stuff but not all of mdns_free or any of mdns_init.
>> I introduced an ovms_mutex library to main. This contains some helpful wrapper functions to make mutexes easy and safe to use:
>> class OvmsMutex
>> Encapsulates a mutex.
>> Provides Lock() and Unlock() functions to access it.
>> class OvmsMutexLock
>> Encapsulates a mutex lock in a safer manner.
>> Constructor locks it, and destructor unlocks it.
>> Using this is as simple as creating a mutex for the object to be protected, and then creating a OvmsMutexLock(&mutex) over that. When the OvmsMutexLock comes in scope, it will lock the mutex, and when it goes out of scope it will unlock it.
>> I’ve done this in other projects, with great success. Using OvmsMutexLock objects means you never forget to unlock the mutex (no matter how weird and wonderful your code paths are).
>> I then used OvmsMutex and OvmsMutexLock in ovms_mdns. The mdns stuff seems ok for me now.
>>> On 19 Mar 2018, at 9:51 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>> It seems that mdns_free is being called, while mdns_free is running…
>>> It is trivial to fix it in the timer deletion code, but that just delays the problem until a bit later (the hostname free).
>>> I am looking at this now.
>>>> On 19 Mar 2018, at 9:40 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>> On Sun, 18 Mar 2018, Michael Balzer wrote:
>>>>> From a first look at the mdns code in your backtrace, I would guess
>>>>> that's a double free() for the timer, it seems the timer_handle
>>>>> never gets NULLed.
>>>> That may be a bug (deficiency) in the esp-idf mDNS code.
>>>> Perhaps I hit it because OvmsMDNS::StopMDNS was called without
>>>> everything coming up correctly first?
>>>>                                                       -- Steve
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180319/0b3e6234/attachment.htm>
