[Ovmsdev] Command prompt in secure mode
Mon Mar 19 02:20:31 HKT 2018
Greg,
you need to set the secure flag as required on your command registration:
OvmsCommand* OvmsCommand::RegisterCommand(const char* name, const char* title, void (*execute)(int, OvmsWriter*, OvmsCommand*, int, const char* const*),
                                          const char *usage, int min, int max, *bool secure*)
Everything else is handled by the system.
Am 18.03.2018 um 17:47 schrieb Greg D.:
> Colored banner is fine.  Nice touch.
> Do I need to do anything in the obdii code to fix the security issues,
> or is that taken care of in the command parser?
> Greg
> Stephen Casner wrote:
>> I'm fine with not setting a color on the prompts.  Perhaps the color
>> should also be removed from the welcome banner?
>>                                                         -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180318/9c4994f4/attachment.htm>
