[Ovmsdev] ota questions
Sun Mar 18 00:06:31 HKT 2018
Looks good!
I've switched wifi and modem on and off a couple times, it always correctly reconfigured, with priority for wifi, and ota flash was usable on all connections.
I'll do some road tests later on.
Am 17.03.2018 um 16:49 schrieb Mark Webb-Johnson:
> I found and fixed an issue with wifi not attempting STA reconnections in APCLIENT mode. That may have been the cause of some of Greg’s issues.
> Regarding Wifi and Modem co-existing, I think this is a similar issue to what I saw with APCLIENT. Sometimes wifi doesn’t remove the interface. There is also
> a race condition where an interface is ‘up’, but has not yet been assigned an IP address (as is the case with the ‘pp’ interface you show below).
> I remain convinced that the correct way to deal with this is to bind our source address to the preferred interface, whenever we want to make an outgoing call.
> But, looking at the mongoose library code they simply don’t seem to offer that option. The standard socket API does, of course, have the bind option after
> socket creation but before connect.
> LWIP does, however, seem to have an alternative: netif_set_default(). That function supposedly sets the default interface to be used, unless one is specified
> manually (presumably by binding the socket). I think we can have net manager use that whenever modem/wifi comes up or goes down.
> Going down that route, I added it, but then found some messy handling (in netmanager) of m_connected_wifi. That would be set if either a STA or AP wifi came
> up, but that doesn’t seem right. We don’t want to set default routes out an AP link. So, I refactored that, and added a separate m_wifi_ap flag in netmanager
> to track AP being up/down. Then, that introduced a problem into MDNS as it was listening on the network.wifi.up event (as it needs to come up both in AP and
> STA modes), so I fixed MDNS to work like the others. I may re-visit this tomorrow, as perhaps two new events ‘wifi.any.up’ and ‘wifi.any.down’ may be a better
> way to do this (rather than the generic network manager messages we are using at the moment, with the client then checking the flags to see which one came up
> - wifi or modem).
> There is a new Info level output from ‘netmanager’ to show if it changes the default interface, and I extended ‘network status’ to show link status on
> interfaces, interface numbers, and default interface status. This should give us some more visibility as to what is going on.
> I haven’t managed to find the issue with wifi AP not bringing down interfaces correctly.
> Overall, this was a fairly large re-factor, and I am concerned about unintended consequences. I do, however, think that the approach is right. I haven’t got
> cellular coverage at home (almost midnight here) so can’t test modem connections. I’ll take it for a drive tomorrow and try then.
> This is what it looks like for me, tonight:
>     OVMS > wifi mode apclient AP STA
>     Starting WIFI as Access Point and Client...
>     I (21957) wifi: mode : sta (re:da:ct:ed:da:ta) + softAP (al:so:re:da:ct:ed)
>     I (21967) events: Signal(system.wifi.sta.start)
>     I (21977) events: Signal(system.wifi.ap.start)
>     I (21987) esp32wifi: AP started with SSID: STA, MAC: al:so:re:da:ct:ed, IP: 192.168.4.1
>     I (21987) events: Signal(network.mgr.init)
>     I (22027) ovms-mdns: Launching MDNS service
>     OVMS > network
>     Interface#2: ap2 (ifup=1 linkup=1)
>       IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
>     Interface#1: st1 (ifup=0 linkup=1)
>       IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0
>     Interface#0: lo0 (ifup=1 linkup=1)
>       IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
>     DNS: None
>     Default Interface: ap2 (192.168.4.1/255.255.255.0 gateway 192.168.4.1)
>     I (24377) wifi: connected with STA, channel 11
>     I (24387) events: Signal(system.wifi.sta.connected)
>     I (27737) event: sta ip: 10.x.x.212, mask: 255.255.255.0, gw: 10.x.x.64
>     I (27747) events: Signal(network.interface.up)
>     I (27747) netmanager: Set DNS#0 8.8.8.8
>     I (27757) netmanager: Set DNS#1 8.8.4.4
>     I (27757) events: Signal(system.wifi.sta.gotip)
>     I (27767) netmanager: Interface priority is st1 (10.x.x.212/255.255.255.0 gateway 10.x.x.64)
>     I (27767) events: Signal(network.wifi.up)
>     I (27777) events: Signal(network.up)
>     I (27787) time: Starting SNTP client
>     I (27787) esp32wifi: WiFi UP with SSID: STA, MAC: re:da:ct:ed:da:ta, IP: 10.x.x.212, mask: 255.x.x.0, gw: 10.x.x.64
>     D (27827) time: ntp (stratum 1 trusted 1) provides time Sat Mar 17 15:30:37 2018 (135125us) UTC
>     OVMS > network
>     Interface#1: st1 (ifup=1 linkup=1)
>       IPv4: 10.x.x.212/255.255.25.0 gateway 10.x.x.64
>     DNS: 8.8.8.8 8.8.4.4
>     Default Interface: st1 (10.x.x.212/255.255.255.0 gateway 10.x.x.64)
> All the above is committed, and pushed.
>> On 17 Mar 2018, at 7:40 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> New issue, possibly also routing related: powering down the modem to force using Wifi used to work before, I now get:
>> I (724597) gsm-ppp: status_cb: Connected
>> I (724597) gsm-ppp:    our_ipaddr  = 10.170.195.13
>> I (724597) gsm-ppp:    his_ipaddr  = 10.64.64.64
>> I (724597) gsm-ppp:    netmask     = 255.255.255.255
>> I (724597) gsm-ppp:    our6_ipaddr = ::
>> I (724597) netmanager: Set DNS#0 8.8.8.8
>> I (724597) netmanager: Set DNS#1 8.8.4.4
>> I (724597) time: Starting SNTP client
>> OVMS > network status *
>> Interface#2: pp
>>   IPv4: 10.170.195.13/255.255.255.255 gateway 10.64.64.64
>> Interface#1: st
>>   IPv4: 192.168.2.105/255.255.255.0 gateway 192.168.2.1
>> Interface#0: lo
>> OVMS > ota flash http ovms.dexters-web.de/g/spacer.gif <http://ovms.dexters-web.de/g/spacer.gif>*
>> Current running partition is: factory
>> Target partition is: ota_0
>> Download firmware from ovms.dexters-web.de/g/spacer.gif <http://ovms.dexters-web.de/g/spacer.gif> to ota_0
>> Expected file size is 67
>> Preparing flash partition...
>> Error: ESP32 error #5379 when writing to flash - state is inconsistent
>> E (763827) esp_ota_ops: OTA image has invalid magic byte (expected 0xE9, saw 0x47
>> OVMS > power simcom off*
>> Power mode of simcom is now off
>> I (782817) simcom: State: Enter PoweringOff state
>> I (782817) gsm-ppp: Shutting down (soft)...
>> I (782817) time: Restarting SNTP client
>> I (782827) gsm-nmea: Shutdown (direct)
>> I (782837) simcom: Power Cycle
>> Interface#2: pp
>>   IPv4: 0.0.0.0/255.255.255.255 gateway 0.0.0.0
>> Interface#1: st
>> Interface#0: lo
>> I (793147) simcom: State timeout, transition to 1
>> I (793147) simcom: State: Enter CheckPowerOff state
>> I (794657) gsm-ppp: StatusCallBack: User Interrupt
>> I (794657) gsm-ppp: PPP connection has been closed
>> *OVMS > network status *
>> Interface#2: pp
>> Interface#1: st
>> Interface#0: lo
>> *OVMS > ota flash http ovms.dexters-web.de/g/spacer.gif <http://ovms.dexters-web.de/g/spacer.gif>*
>> Error: Request failed
>> *W (807247) net: Error: Failed to connect server ovms.dexters-web.de <http://ovms.dexters-web.de> (error: 118)*
>> Error 118 = Host is unreachable.
>> Same with modem setstate. The problem occurs after the first ppp init.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180317/6c2ca553/attachment.htm>
