[Ovmsdev] Mongoose update & dev merge
Sat Mar 17 05:54:52 HKT 2018
Greg,
you need to do the git submodule update in the OVMS directory. Mongoose is a submodule of our tree, not the idf.
Am 16.03.2018 um 22:36 schrieb Greg D.:
> Build isn't working here. git submodule update from the esp-idf directory just returned without making any apparent changes; did things get pushed to
> remote/master?
> I'm getting a build error. This is after a make clean. What did I miss?
> /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_webserver/src/ovms_webserver.cpp:
> In member function 'user_session* OvmsWebServer::GetSession(http_message*)':
> /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_webserver/src/ovms_webserver.cpp:584:84:
> error: 'mg_http_parse_header2' was not declared in this scope
> mg_http_parse_header2(cookie_header, SESSION_COOKIE_NAME, &ssid, sizeof(ssid_buf));
> make[1]: *** [/home/greg/esp/esp-idf/make/component_wrapper.mk:274 <http://component_wrapper.mk:274>: src/ovms_webserver.o] Error 1
> make: *** [/home/greg/esp/esp-idf/make/project.mk:450 <http://project.mk:450>: component-ovms_webserver-build] Error 2
> greg at linux-0rpb:~/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3>
> Greg
> Michael Balzer wrote:
>> Just pushed the update, so you'll need to do…
>> …after your next pull.
>> I've excluded the dev branch changes for now as mg_broadcast() isn't usable yet for us anyway, at least not for my purpose.
>> Everything OK in my environment, but please test yours.
>> Am 11.03.2018 um 03:34 schrieb Mark Webb-Johnson:
>>> Fine by me. Just let us know when done so we know to submodule update.
>>>> On 11 Mar 2018, at 2:34 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>>> Mark, Steve,
>>>> I'm about to update our mongoose submodule to the latest changes _including_ the latest additions to the "dev" branch.
>>>> That's because I want to use the mg_broadcast() function, which doesn't work on the ESP32 until this fix from the dev branch:
>>>> https://github.com/cesanta/mongoose/commit/780077d1187ff632bdcbf33d65207a084027aba9
>>>> Quickly found that in the mongoose issues once I knew what to look for… ;)
>>>> My local checkout builds & runs. I've checked through the commits, there is no API change (except a minor one on HTTP header parsing). None of the commits looks
>>>> like it could break something and there are some clear fixes included, so I think we can just merge the dev branch.
>>>> I'll do some general tests before pushing the change, if you'd like me to wait with the update or do some specific tests, tell me.
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180316/79fb8d4d/attachment.htm>
