Tom Parker tom at carrott.org
Tue Mar 6 17:51:34 HKT 2018
I had some time to put the data logger in my car and examine the results.
It turns out I spoke too soon when I said that the framing errors had
gone away. I've seen this pattern of disconnection several times now
with the large number of framing errors and the long time since the last
RX frame in the Mux statistics. I'm not really sure what is salient in
the log leading up to the disconnection, please see attached for a
couple of examples.
The ovms_2018-03-04T19_43_10+0000.log is particularly interesting
because the gsm-ppp and server-v2 processes are still working, but no
data is being sent and the normal gsm-mux chatter is missing.
The server logs for this one indicate that
I (2085209) ovms-server-v2: Send MP-0 F3.0.990-30-g613bfd2/factory/main
build (idf v3.1-dev-453-g0f978bc) Mar  2 2018 06:35:40,,5,1,NL,
2degrees
was the last message received. I stopped the data logger before
rebooting the ovms, so there's no record of the reconnection from the
ovms module's point of view.
Server Logs, note 8 minute gap (I was driving so waited to reboot it)
2018-03-04 21:16:05,61446,'#74 C rx msg F
3.0.990-30-g613bfd2/factory/main build (idf v3.1-dev-453-g0f978bc) Mar
2 2018 06:35:40,,5,1,NL,2degrees'
2018-03-04 21:17:29,61640,'#15 A rx msg A '
2018-03-04 21:22:33,62318,'#15 A rx msg A '
2018-03-04 21:23:37,62442,'#9 C got login'
2018-03-04 21:23:37,62443,'#74 C error - duplicate car login - clearing
first connection'
2018-03-04 21:23:50,62467,'#9 C error - Unable to decode message -
aborting connection'
2018-03-04 21:24:12,62523,'#66 C got login'
2018-03-04 21:24:40,62597,'#66 C rx msg S
74,K,0,0,stopped,standard,62,0,0,0,0,0,13,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,384.50,0'
This is an extract from ovms_2018-03-05T05_40_29+0000.log.bz2 where the
disconnection seems like it was detected and we're left with the modem
status queries in a loop. When I tried to power off the simcom modem,
the ovms locked up and wouldn't respond to the serial console. I
rebooted the modem with the button and it immediately reconnected (not
shown but it's in the attached log).
OVMS > V (35194199) simcom: tx: f9 0d ff 3b 41 54 2b 43 52 45 47 3f 3b
2b 43 43 | ...;AT+CREG?;+CC
V (35194199) simcom: tx: 4c 4b 3f 3b 2b 43 53 51 3b 2b 43 4f 50 53 3f 0d
| LK?;+CSQ;+COPS?.
V (35194199) simcom: tx: 0a cf f9
V (35194219) simcom: rx: 41 54 2b 43 52 45 47 3f 3b 2b 43 43 4c 4b 3f 3b
| AT+CREG?;+CCLK?;
V (35194219) simcom: rx: 2b 43 53 51 3b 2b 43 4f 50 53 3f 0d
| +CSQ;+COPS?.
V (35194279) simcom: rx: 0d 0a 2b 43 52 45 47 3a 20 30 2c 31 0d 0a 0d 0a
| ..+CREG: 0,1....
V (35194279) simcom: rx: 2b 43 43 4c 4b 3a 20 22 31 38 2f 30 33 2f 30 35
| +CCLK: "18/03/05
V (35194279) simcom: rx: 2c 31 39 3a 30 39 3a 30 35 2b 35 32 22 0d 0a 0d
| ,19:09:05+52"...
V (35194279) simcom: rx: 0a 2b 43 53 51 3a 20 33 2c 39 39 0d 0a 0d 0a 2b
| .+CSQ: 3,99....+
V (35194279) simcom: rx: 43 4f 50 53 3a 20 30 2c 30 2c 22 32 64 65 67 72
| COPS: 0,0,"2degr
V (35194279) simcom: rx: 65 65 73 22 2c 32 0d 0a 0d 0a 4f 4b 0d 0a
| ees",2....OK..
OVMS > V (35224199) simcom: tx: f9 0d ff 3b 41 54 2b 43 52 45 47 3f 3b
V (35224199) simcom: tx: 4c 4b 3f 3b 2b 43 53 51 3b 2b 43 4f 50 53 3f 0d
| LK?;+CSQ;+COPS?.
V (35224199) simcom: tx: 0a cf f9
V (35224209) simcom: rx: 41 54 2b 43 52 45 47 3f 3b 2b 43 43 4c 4b 3f 3b
| AT+CREG?;+CCLK?;
V (35224219) simcom: rx: 2b 43 53 51 3b 2b 43 4f 50 53 3f 0d 0d 0a 2b 43
| +CSQ;+COPS?...+C
V (35224219) simcom: rx: 52 45 47 3a 20 30 2c 31 0d 0a 0d 0a 2b 43 43 4c
| REG: 0,1....+CCL
V (35224219) simcom: rx: 4b 3a 20 22 31 38 2f 30 33 2f 30 35 2c 31 39 3a
| K: "18/03/05,19:
V (35224219) simcom: rx: 30 39 3a 33 35 2b 35 32 22 0d 0a 0d 0a 2b 43 53
| 09:35+52"....+CS
V (35224219) simcom: rx: 51 3a 20 33 2c 39 39 0d 0a 0d 0a 2b 43 4f 50 53
| Q: 3,99....+COPS
V (35224219) simcom: rx: 3a 20 30 2c 30 2c 22 32 64 65 67 72 65 65 73 22
| : 0,0,"2degrees"
V (35224219) simcom: rx: 2c 32 0d 0a 0d 0a 4f 4b 0d 0a
| ,2....OK..
OVMS > a simcom status
SIMCOM
   Network Registration: RegisteredHome
   State: NetMode
   Ticker: 1235
   User Data: 0
   Mux
     Status: up
     Open Channels: 4
     Framing Errors: 5103
     Last RX frame: 1222 sec(s) ago
     RX frames: 2512
     TX frames: 2500
   PPP
     Not Connected
     Last Error: Connection Lost
   GPS
     Status: disabled
     Time: disabled
     NMEA: GPS/GLONASS Not Connected
OVMS > simcom      power simcom off
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 156795334, SPIWP:0xee
Type: application/x-bzip
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180306/2922a085/attachment-0004.bin>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180306/2922a085/attachment-0005.bin>
