[Ovmsdev] LWIP lock-up
Thu Mar 29 09:27:47 HKT 2018
Tom,
This seems clear, and about what I expected. Looks like the timer service is in 'pppapi_close’, and the tcp/ip task is in ‘pppapi_connect’. One is trying to connect, the other disconnect, and they are deadlocked.
I think the '0x400eec76: OvmsCommandApp::Log’ in Blk tiT is a false report - can’t see how that is called from there.
I’ve got to put some time into ‘day job’ now, but will have a look at it in detail later.
> On 29 Mar 2018, at 9:04 AM, Tom Parker <tom at carrott.org> wrote:
> On 29/03/18 00:02, Mark Webb-Johnson wrote:
>> I unplugged my antenna, then put it in a steel box. It still got signal :(
> lol
> I've got it hung up at the moment. Unfortunately it was during the one drive where I didn't use the datalogger so I don't have the logs leading up to the hang.
> Time is still advancing, but monotonic is not. I don't have it connected to the idf monitor so addr2line is a bit tricky.
> OVMS> tas   module tasks
> Number of Tasks = 13      Stack:  Now   Max Total    Heap 32-bit SPIRAM
> 3FFAFB10  1 Blk esp_timer         396   444  4096   55100 644      0
> 3FFBD584  2 Blk eventTask         448   448  4608       0 0      0
> 3FFC5C8C  3 Blk CanRxTask         424   824  4096       0 0      0
> 3FFCCE0C  4 Blk ipc0              392   504  1024   10848 0      0
> 3FFCD40C  5 Blk ipc1              392   504  1024      12 0      0
> 3FFCF234  8 Rdy IDLE              368   496  1024       0 0      0
> 3FFCF7C8  9 Rdy IDLE              356   692  1024       0 0      0
> 3FFD115C 10 Blk Tmr Svc          1512  3928  6144     744 0      0
> 3FFD3D6C 14 Blk Housekeeping      356  3444  6144   55792 0      0
> 3FFCECA0 16 Blk tiT               908  3852  4608   23968 0      0
> 3FFDD374 17 Blk SIMCOMTask        464  2528  4096    4404 0      0
> 3FFDF9B4 18 Rdy AsyncConsole      764  3068  5120     516 27488      0
> 3FFE3E28 19 Blk Vrx Task          456  3016  4096       0 0      0
> OVMS> module tasks stacks
>   0x400dc0e7  0x4008b981
>   0x4019bfa8  0x4008b981
>   0x400d3f41  0x4008b981
>   0x4008152b  0x4008b981  0x40081363
>   0x4008152b  0x4008b981  0x400813dc
>   0x4008ca40  0x4008bcf3  0x4008bcf3
>   0x4008ca40  0x40082197  0x4008c5bc  0x40082197
>   0x401e52d0  0x4008b981  0x401cbf90  0x40082d58  0x401cb468 0x4012b2d4  0x401299f3  0x40129900  0x40129f8c  0x4012a037 0x4014a76c  0x400e208a  0x401183a2  0x400e8fdc  0x400d4d68 0x400e8d4c  0x400e8fe8  0x400eaeb6  0x400eb07b  0x400eb07b 0x4008d7c9  0x40081f10  0x4008d818  0x40081f7e  0x4008d7fc 0x4008d90b
>   0x400eae77  0x4008c972  0x400e2170
>   0x401e52d0  0x4008b981  0x400eec76  0x401cbf90  0x401cb450 0x4012b7ec  0x4020118e  0x401e0672  0x401e53e1  0x4008b981 0x402011b6  0x401e7654  0x401e2920  0x401e3ea2  0x401d71a8 0x401cbdaa
>   0x40129909  0x4008b981  0x401299ac
> 3FFDF9B4 18 Rdy AsyncConsole     1148  3068  5120     516 27488      0
>   0x400e3f09  0x400e7438  0x400ee4b1  0x400ee5c8  0x400ee5ba 0x400ee5ba  0x400ee5f0  0x400e3a3b  0x400f130c  0x400f1373 0x400e3a6a  0x400e8240  0x4017cfb1  0x401fb752  0x400e4010 0x400e8274  0x400e8460  0x400e3ebc  0x400e3ecb  0x400e6c3c
>   0x4012e589  0x4008b981  0x401fc148
> Blk Tmr Svc and Blk tiT look suspect.
> Blk Tmr Svc
> ~/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-addr2line -pfiaC -e build/ovms3.elf  0x401e52d0  0x4008b981  0x401cbf90  0x40082d58 0x401cb468  0x4012b2d4  0x401299f3  0x40129900  0x40129f8c 0x4012a037  0x4014a76c  0x400e208a  0x401183a2  0x400e8fdc 0x400d4d68  0x400e8d4c  0x400e8fe8  0x400eaeb6  0x400eb07b 0x400eb07b  0x4008d7c9  0x40081f10  0x4008d818  0x40081f7e 0x4008d7fc  0x4008d90b
> 0x401e52d0: sys_arch_sem_wait at /home/ubuntu/esp/esp-idf/components/lwip/port/freertos/sys_arch.c:548
> 0x4008b981: xQueueGenericReceive at /home/ubuntu/esp/esp-idf/components/freertos/./queue.c:2037
> 0x401cbf90: tcpip_api_call at /home/ubuntu/esp/esp-idf/components/lwip/api/tcpip.c:474
> 0x40082d58: _free_r at /home/ubuntu/esp/esp-idf/components/newlib/./syscalls.c:42
> 0x401cb468: pppapi_close at /home/ubuntu/esp/esp-idf/components/lwip/api/pppapi.c:319
> 0x4012b2d4: GsmPPPOS::Shutdown(bool) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.cpp:219
> 0x401299f3: simcom::State1Ticker1() at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.cpp:531
> 0x40129900: simcom::Task() at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.cpp:88
> 0x40129f8c: simcom::Ticker(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.cpp:257
> 0x4012a037: std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_data() const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:135
>  (inlined by) std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_is_local() const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:170
>  (inlined by) std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_dispose() at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:179
>  (inlined by) std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string() at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:544
>  (inlined by) void std::_Mem_fn_base<void (simcom::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*), true>::operator()<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*, void>(simcom*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&) const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600
>  (inlined by) void std::_Bind<std::_Mem_fn<void (simcom::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (simcom*, std::_Placeholder<1>, std::_Placeholder<2>)>::__call<void, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&, 0u, 1u, 2u>(std::tuple<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&>&&, std::_Index_tuple<0u, 1u, 2u>) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1074
>  (inlined by) void std::_Bind<std::_Mem_fn<void (simcom::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (simcom*, std::_Placeholder<1>, std::_Placeholder<2>)>::operator()<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*, void>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1133
>  (inlined by) std::_Function_handler<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*), std::_Bind<std::_Mem_fn<void (simcom::*)(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)> (simcom*, std::_Placeholder<1>, std::_Placeholder<2>)> >::_M_invoke(std::_Any_data const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&&, void*&&) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1871
> 0x4014a76c: opendir at /home/ubuntu/esp/esp-idf/components/vfs/./vfs.c:540
> 0x400e208a: std::function<void (OvmsMetric*)>::operator()(OvmsMetric*) const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271
> 0x401183a2: void std::_Mem_fn_base<void (OvmsServerV2::*)(OvmsMetric*), true>::operator()<OvmsMetric*, void>(OvmsServerV2*, OvmsMetric*&&) const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:600
>  (inlined by) void std::_Bind<std::_Mem_fn<void (OvmsServerV2::*)(OvmsMetric*)> (OvmsServerV2*, std::_Placeholder<1>)>::__call<void, OvmsMetric*&&, 0u, 1u>(std::tuple<OvmsMetric*&&>&&, std::_Index_tuple<0u, 1u>) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1074
>  (inlined by) void std::_Bind<std::_Mem_fn<void (OvmsServerV2::*)(OvmsMetric*)> (OvmsServerV2*, std::_Placeholder<1>)>::operator()<OvmsMetric*, void>(OvmsMetric*&&) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1133
>  (inlined by) std::_Function_handler<void (OvmsMetric*), std::_Bind<std::_Mem_fn<void (OvmsServerV2::*)(OvmsMetric*)> (OvmsServerV2*, std::_Placeholder<1>)> >::_M_invoke(std::_Any_data const&, OvmsMetric*&&) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:1871
> 0x400e8fdc: OvmsEvents::SignalEvent(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_events.cpp:155
> 0x400d4d68: void std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<char*>(char*, char*, std::forward_iterator_tag) at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.tcc:236
> 0x400e8d4c: std::function<void (std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*)>::operator()(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/functional:2271
> 0x400e8fe8: std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_data() const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:135
>  (inlined by) OvmsEvents::SignalEvent(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, void*) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_events.cpp:155
> 0x400eaeb6: std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_data() const at /home/ubuntu/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.h:135
>  (inlined by) Housekeeping::Ticker1() at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_housekeeping.cpp:223
> 0x400eb07b: HousekeepingTicker1(void*) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_housekeeping.cpp:70
> 0x4008d7c9: prvProcessExpiredTimer at /home/ubuntu/esp/esp-idf/components/freertos/./timers.c:484
> 0x40081f10: esp_crosscore_int_send at /home/ubuntu/esp/esp-idf/components/esp32/./crosscore_int.c:103
> 0x4008d818: prvProcessTimerOrBlockTask at /home/ubuntu/esp/esp-idf/components/freertos/./timers.c:484
> 0x40081f7e: esp_crosscore_int_send_yield at /home/ubuntu/esp/esp-idf/components/esp32/./crosscore_int.c:112
> 0x4008d7fc: prvProcessTimerOrBlockTask at /home/ubuntu/esp/esp-idf/components/freertos/./timers.c:484
> 0x4008d90b: prvTimerTask at /home/ubuntu/esp/esp-idf/components/freertos/./timers.c:484
> Blk tiT
> $ ~/esp/xtensa-esp32-elf/bin/xtensa-esp32-elf-addr2line -pfiaC -e build/ovms3.elf 0x401e52d0  0x4008b981  0x400eec76  0x401cbf90 0x401cb450  0x4012b7ec  0x4020118e  0x401e0672  0x401e53e1 0x4008b981  0x402011b6  0x401e7654  0x401e2920  0x401e3ea2 0x401d71a8  0x401cbdaa
> 0x400eec76: OvmsCommandApp::Log(char const*, __va_list_tag) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94
> 0x401cb450: pppapi_connect at /home/ubuntu/esp/esp-idf/components/lwip/api/pppapi.c:266
> 0x4012b7ec: GsmPPPOS_StatusCallback(ppp_pcb_s*, int, void*) at /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.cpp:149
> 0x4020118e: ppp_link_end at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ppp.c:704
> 0x401e0672: pppos_disconnect at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/pppos.c:410
> 0x401e53e1: sys_arch_mbox_fetch at /home/ubuntu/esp/esp-idf/components/lwip/port/freertos/sys_arch.c:548
> 0x402011b6: ppp_link_terminated at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/ppp.c:704
> 0x401e7654: link_terminated at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/auth.c:643
> 0x401e2920: lcp_finished at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/lcp.c:2365
> 0x401e3ea2: fsm_timeout at /home/ubuntu/esp/esp-idf/components/lwip/netif/ppp/fsm.c:279
> 0x401d71a8: sys_timeouts_mbox_fetch at /home/ubuntu/esp/esp-idf/components/lwip/core/timers.c:575
> 0x401cbdaa: tcpip_thread at /home/ubuntu/esp/esp-idf/components/lwip/api/tcpip.c:474
