[Ovmsdev] OBDII ECU Documentation, and a request for help
Greg D.
gregd2350 at gmail.com
Wed Mar 28 05:19:37 HKT 2018
Hi folks
In a fit of prose, if not Shakespeare, I took a pass at creating the
documentation chapter for the OBD2ECU task. Comments, corrections, and
general feedback is requested. Is there anything significant missing?
Mark, if this looks acceptable, can it be posted to the Google Doc, or
send me an invite such that I can do so?
Note that I don't have any reference material on the OBDII-to-DB26
cable, other than the wiring. If we eventually have a purchase source,
that should get referenced, or lacking that, perhaps pointers to where
the connectors can be purchased? Placeholders are noted, but only
that. For the EEs in the group, a question: I have both signal and
chassis grounds connected together on the OBDII connector; should they
be, or just signal ground?
I think it would also be helpful to include a table of what metrics are
available (supported) on what vehicles, as an aid to those who want to
remap things for monitoring on an OBDII HUD or Dongle. A glance at the
available documentation didn't turn up anything, so I took a first pass
at the table. See the attached, which includes what I know of the
Roadster's implementation (since I have one and have studied the code a
bit). I would rather not try to guess at the other cars. Could the
various vehicle authors contribute their columns to the table? Send me
an updated spreadsheet, and I will do the merge.
Thanks!
Greg
Name: OVMS Metrics Table.xlsx
Type: application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180327/c5be63a9/attachment-0001.bin>
OBDII ECU
Purpose
The OBDII interface is a connector, electrical specification, and protocol used for viewing the operation and status of a car. It is mandated in all light duty vehicles sold in North America beginning in 1996, and while the focus of the information it provides is for monitoring the emissions of Internal Combustion Engines, it has proven to be a handy port for connecting a variety of aftermarket displays and monitors to a car. Electric Vehicles have no need for emissions monitoring, so often omit the port from the car, thus making the these aftermarket devices incompatible. The OBDII ECU capability of the OVMSv3 is used to create a simulated OBDII port, which can be used to attach many of these aftermarket devices to the car.
Cabling
The cable and OBDII connector are not provided with the OVMSv3 module, but may be ordered from XXXXX, or built using the following diagram:
DB26 OBDII Female Signal name
6 14 CAN3-L
16 6 CAN3-H
8 4 & 5 Chassis & Signal Grounds
18 16 +12v switched output to HUD / Dongle
Also place a 120 ohm resistor between OBDII pins 14 & 6 for bus termination
Setup
From the Web Interface, check the "Start OBD2ECU" box, and select CAN3 from the dropdown menu (if using the wiring diagram above). This will enable the OBDII ECU Task to run the next time the OVMSv3 module is powered on or reset. Also check the "Power on external 12V" box in order to feed 12v power through to the device. Click on Save at the bottom of the page.
From the command line, the following commands are available
obdii ecu start can3 Starts the OBDII ECU task.
obdii ecu stop Stops the OBDII ECU task
obdii ecu list Displays the parameters being served, and their current value
obdii ecu reload Reloads the map of parameters, after a config change
power ext12v on Turns on power feed to the device
power ext12v off Turns off power feed to the device
Operation
During operation, an OBDII device, for example, a Head-Up Display (HUD) or OBDII Diagnostic module, will make periodic requests, usually a few times per second, for a set of parameters. The OVMSv3 module will reply to those parameters with the metric if configured to do so, on an individual basis. These parameters can be common items such as vehicle speed, engine RPM, and engine coolant temperature, but because of the differences between ICE and EV vehicles, many of the parameters do not have equivalent values in an EV. Speed and engine (motor) RPM can be directly mapped, but there is typically no "engine coolant". That parameter (in fact, most parameters) can be mapped to some other value of interest. For example, the Engine Coolant display on the HUD can be configured to display motor or battery temperature instead. Engine Load (PID 4, a percentage value), is mapped by default to battery State of Charge (also a percentage). However, note that not all vehicle metrics may be supported by all vehicles.
Parameters requested by the OBDII device are referred to by "PID value". Note that each PID has a specific range of allowed values, and that it is not possible to directly represent values outside that range. For example, PID 5 (Engine coolant temperature) has a range of -40 to +215; it would not be possible to map the full range of motor RPMs to this parameter. Values outside the allowed range are limited to the range boundary value. The complete table of possible parameters are described here: https://en.wikipedia.org/wiki/OBD-II_PIDs#Mode_01
Vehicle metrics are referred to by name. See table [??] for metrics and which vehicles report them.
Defaults and customization
By default, the following mapping of PID value to OVMSv3 metric is used:
PID Requested Mapped
Dec Hex Parameter Metric value Metric name
4 (0x04) Engine Load Battery SOC v.b.soc
5 (0x05) Coolant Temp Motor temp v.m.temp
12 (0x0c) Motor RPM Motor RPM v.m.rpm
13 (0x0d) Vehicle Speed Vehicle Speed v.p.speed
16 (0x10) MAF Air Flow 12v battery v.b.12v.voltage
The OBDII ECU task supports the remapping and reporting of PIDs 4-18, 31, 33, 47, and 51 (all decimal). PIDs #0 and 32 are used by the OBDII protocol for management, and not available for assignment. Other PIDs return zero.
PIDs requested for which no mapping has been established are ignored by the OBDII ECU task. As an aid for discovering which PIDs are being requested, the configuration parameter 'autocreate' may be used to populate entries into the obdii ecu list display. ('config set obd2ecu autocreate yes'). Such autocreated entried are marked as "Unimplemented", and return zero to the device. They are not added to the configured (saved) obd2ecu.map, and get cleared at each boot or reset. They may be mapped to a supported metric, if desired, using:
config set obd2ecu.map <PID> <metric name>
Example:
OVMS> config set obd2ecu.map 5 v.b.temp (map battery temp to engine coolant temp)
OVMS> vfs edit /store/obd2ecu/10 (script for fuel pressure PID; see below)
OVMS> obdii ecu reload
OBDII ECU pid map reloaded
OVMS> obdii ecu list
PID Type Value Metric
0 (0x00) internal 0.000000
4 (0x04) internal 95.000000 v.b.soc
5 (0x05) metric 16.000000 v.b.temp
10 (0x0a) script 0.000000
11 (0x0b) unimplemented 0.000000
12 (0x0c) internal 0.000000 v.m.rpm
13 (0x0d) internal 0.000000 v.p.speed
16 (0x10) internal 13.708791 v.b.12v.voltage
32 (0x20) internal 0.000000
Types:
"internal" means default internal handling of the PID.
"metric" means a user-set mapping of PID to the named metric
"unimplemented" are PIDs requested by the device, but for which no map has been set
"script" means the user has configured a script to handle the PID
Special handling
Several PIDs are handled specially by the OBDII ECU task.
PIDs 0 and 32 are bit masks that indicate what other PIDs are being reported by the OBDII ECU task. These are maintained internally based on the default, mapped, and scripted PID table. Note that some OBDII devices use PID 0 as a test for ECU presence and operating mode (standard or extended), and ignore the returned values. The OBDII ECU task supports both modes.
PID 12, Engine RPM, is often monitored by the OBDII device to detect when the car is turned off. Since an EV's motor is not rotating when the car is stopped, a HUD may decide to power down when it sees the RPM drop below a particular value, or if there is no variation (jitter) in its value. To prevent this, the OBDII ECU task will source a fake value of 500 rpm, plus a small periodic variation, if the car is not moving (vehicle speed is less than 1). To actually let the device turn off, see "External Power Control", below.
PID 16, MAF Air Flow, is commonly used by OBDII devices to display fuel flow, by measuring the amount of air entering the engine in support of combustion. Since this is irrelevant to an EV, the OBDII ECU task maps this metric to a simple integer. Most HUDs displays limit this to a range of 0-19.9 liter/hr, which is acceptable to display the +12v battery voltage. Since the conversion factors are complicated, this value is at best approximate, in spite of its implied precision.
Mode 9, PID 2, VIN, is used to report the car's DMV VIN to the attached OBDII device. Since the rest of the parameters reported by the OBDII ECU task are simulated, and some OBDII devices may use the VIN for tracking purposes, the reporting of the VIN may be turned off by setting the pirvacy flag to "yes". The command is 'config set obd2ecu privacy yes'. Setting it to 'no', which is the default, allows the reporting of the VIN.
Mode 9, PID 10, ECU Name, is statically mapped to report the OVMSv3's Vehicle ID field (vehicle name, not VIN). This string may be customized to any printable string of up to 20 characters, if not used with the OVMS v2 or v3 mobile phone applications.
Metric Scripts
Should one desire to return a value not directly available by a single named metric, it is possible to map a PID to a short script, where combinations of metrics, constants, etc. may be used to create a custom value. Note that the restrictions on PID value ranges still applies. Also note that the special handling for PID 12 (engine RPM) is not applied.
Scripts should be placed in the directory /store/obd2ecu/PID, where PID is the decimal value of the PID to be processed. Example for creating a "kw per km" sort of metric:
ret1=OvmsMetricFloat("v.p.speed");
ret2=OvmsMetricFloat("v.b.power");
out=0.0;
if(ret1 > 0) { out=ret2/ret1; }
out;
Put this text in a file /store/obd2ecu/4 to map it to the "Engine Load" PID. See "Simple Editor" chapter for file editing, or use 'vfs append' commands (tedious). Note however, that Vehicle Power (v.b.power) is not supported on all cars (which is why this is not the default mapping for this PID).
One warning: The error handling of the scripting engine is very crude at this writing, and will typically cause a module reboot if anything goes wrong in a script.
Since the OVMSv3 module remains powered at all times, and the normal means for deducing that a car has been turned off don't work on an EV (see PID #12, above), an external OBDII device needs to be explicitly turned on and off. This is currently done with short event scripts. The following commands configure the OVMSv3 to make the external 12v feed follow the vehicle on/off state, or use the vfs edit command to create or modify the files:
vfs mkdir /store/events
vfs mkdir /store/events/vehicle.on
vfs mkdir /store/events/vehicle.off
vfs append 'power ext12v on' /store/events/vehicle.on/myevent
vfs append 'power ext12v off' /store/events/vehicle.off/myevent
