[Ovmsdev] Size limit on scp
Sun Mar 25 23:56:15 HKT 2018
Mark,
Yes, that limit can definitely be made larger.  It is just part of the
code validating the command received from the scp client.  I modeled
that validation code after the scp code in openssh where the size
validation was checking for the value to fit in off_t, but my mindset
at the time was that only small files like scripts and configs would
be transferred.  I wasn't sure about an appropriate off_t definition
in esp-idf.
What size limit do you think would be appropriate?
On Sun, 25 Mar 2018, Mark Webb-Johnson wrote:
> @Steve
> Is there any particular reason for this:
> $ scp build/ovms3.bin mark at ev914.local:/sd/ovms3.new
> scp: size unacceptable: 1841760
> Can we increase to allow firmware copies to SD?
