[Ovmsdev] Test results of latest changes
Wed Mar 21 02:54:24 HKT 2018
Julien,
you're loading too much on hw3.0. You cannot start both v2 and v3 server, even if you exclude optional components.
See here:
1.
I (7011) ovms-server-v3: Tx(all) metric ovms/TWAXXV3/m/m.freeram=14284
2.
…you've barely booted and your RAM is already gone.
You've also enabled the wolfssh stuff and the obd2ecu component, I recommend disabling both to save RAM. I also have disabled every car except Twizy, but I
think that doesn't make much difference on RAM usage.
Also, did you disable the FATFS per file cache?
Am 20.03.2018 um 19:39 schrieb Julien “JaXX” Banchet:
> On 20 Mar 2018 at 19:19 +0100, Julien “JaXX” Banchet <jaxx at jaxx.org>, wrote:
>> On 20 Mar 2018 at 18:31 +0100, Michael Balzer <dexter at expeedo.de>, wrote:
>>> Commit a9bfcc761e8853a5ad1e7cee4b966d012fc33895
>>> …every (!) mode is working now! :-)
>> Gonna give that a shot :-) I love apclient mode, too bad it needs an SSID set (I thought there where limitations, like channel selection for instance which
>> could have been logic, but I don’t really see any reason in fact)
> Set apclient, so wifi comes online pretty fast …
> But getting crash looped very fast (I usually have time to "config set” stuff)
> https://pastebin.com/ricmTJf7
> I did manage to enable and server v3 stop (as it seems to either get disconnected from mqtt then crash after a handful of seconds, or crash during mqtt
> publishing) and now it sits still.
> GSM looks dead on the other hand and wifi has hiccups (‘wifi' knows it’s IP, ‘network' doesn’t) :-)
> OVMS# network
> Interface#2: ap2 (ifup=1 linkup=1)
> IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
> Interface#1: st1 (ifup=1 linkup=1)
> IPv4: 10.33.92.20/255.255.255.0 gateway 10.33.92.1
> Interface#0: lo0 (ifup=1 linkup=1)
> IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
> DNS: 10.33.33.251 10.33.33.252
> Default Interface: st1 (10.33.92.20/255.255.255.0 gateway 10.33.92.1)
> I (171010) simcom: State timeout, transition to 2
> I (171010) simcom: State: Enter PoweringOn state
> I (171010) simcom: Power Cycle
> I (174670) simcom: State: Enter PoweredOn state
> I (194010) simcom: State: Enter MuxStart state
> I (194010) gsm-mux: Start MUX
> I (194020) gsm-mux: Channel #0 is open
> I (194030) gsm-mux: Channel #1 is open
> I (194030) gsm-mux: Channel #2 is open
> I (194040) gsm-mux: Channel #3 is open
> I (194040) gsm-mux: Channel #4 is open
> I (195010) simcom: State: Enter NetWait state
> I (195010) gsm-nmea: Startup
> I (199990) wifi: bcn_timout,ap_probe_send_start
> I (202490) wifi: ap_probe_send over, resett wifi status to disassoc
> I (202490) wifi: state: run -> init (1)
> I (202500) wifi: n:9 0, o:9 0, ap:9 2, sta:9 0, prof:9
> I (202500) netmanager: WIFI client down (with MODEM down): network connectivity has been lost
> I (202500) time: Stopping SNTP client
> I (203010) ovms-server-v2: Status: Server is ready to start
> I (205030) simcom: CREG Network Registration: RegisteredHome
> I (206010) simcom: State: Enter NetStart state
> I (207050) simcom: PPP Connection is ready to start
> I (208010) simcom: State: Enter NetMode state
> I (208010) gsm-ppp: Initialising...
> E (208010) gsm-ppp: Error init pppos <<< bummer
> OVMS# simcom
> SIMCOM
> State: NetMode
> Ticker: 92
> User Data: 0
> Mux
> Status: up
> Open Channels: 4
> Framing Errors: 0
> Last RX frame: 1 sec(s) ago
> RX frames: 219
> TX frames: 11
> PPP
> Not Connected
> Last Error: Undefined
> GPS
> Status: enabled, required
> Time: enabled, required
> NMEA: GPS/GLONASS Connected on channel: #1
> OVMS# network
> Interface#1: st1 (ifup=0 linkup=1)
> IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 <<<<<< bye bye
> Default Interface: ap2 (192.168.4.1/255.255.255.0 gateway 192.168.4.1)
> I (317690) event: station ip lost
> OVMS# wifi
> WiFi
> Power: on
> Mode: Access-Point + Client mode
> STA SSID: JaXX
> MAC: 30:ae:a4:37:25:54
> IP: 10.33.92.20/255.255.255.0 <<<<<<< here
> GW: 10.33.92.1
> AP SSID: TwaXX
> MAC: 30:ae:a4:37:25:55
> IP: 192.168.4.1
> AP Stations: 0
> OVMS# network
> IPv4: 0.0.0.0/0.0.0.0 gateway 0.0.0.0 <<<<<< not here
> OVMS#
> JaXX./.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180320/aa0be3ec/attachment-0001.html>
