[Ovmsdev] webserver (?) crash
Tue Mar 20 15:21:46 HKT 2018
Ha, interesting.  I've been running the module mostly from the high
power port on my laptop, with 12v applied only when I was driving the
external CAN bus dongle things.  I don't recall framing errors being a
problem in the past, but I connected the 12v and it appears that the
framing errors have stopped.  I'll let it run the night, and see what
happens by morning.
Greg
Mark Webb-Johnson wrote:
> Framing errors would be indicative of a mux issue, not really RF
> signal. Are you sure the modem is not browning out from lack of power?
> Are you seeing any ..START.. messages in the log (which is a modem
> restart)? I was getting a lot of these until I switched to a powered
> USB hub. How are you powering this - 5v usb or 12v?
