[Ovmsdev] MDNS crash
Tue Mar 20 05:46:17 HKT 2018
Too tired to analyse code today, but I've done some bisecting that may be helpful:
- commit 2bcbc8e995977c904f5346c44221e07413e56a62 has broken the AP mode (network completely lost on ppp init)
- commit 17a528bbe4e021768e28251984ad4532e9b745bb has then additionally broken the client mode (same effect, network lost on ppp init)
AP and client mode fully work last in commit b9e57cef60e240745bd93a1b542158d89b878ec2, client mode also with fallback to ppp on losing wifi. With MDNS disabled
of course.
AP+Client mode starts correctly in b9e57cef60e240745bd93a1b542158d89b878ec2 but crashes on losing wifi.
Am 19.03.2018 um 18:06 schrieb Michael Balzer:
> Disabled mDNS again, "module memory" again working without crashes.
> Wifi modes client and apclient working again, but mode ap still with the effect of a broken network after ppp init.
> Server v2 does not connect, and "ota flash http …" just hangs.
> Am 19.03.2018 um 17:49 schrieb Michael Balzer:
>> Just pulled the latest version, reenabled mDNS.
>> Server v2 again does not connect, and the module crashes immediately on "module memory" (related?):
>> I (1239) housekeeping: Auto init wifi (free: 134556 bytes)
>> I (1249) wifi: wifi firmware version: ebd3e5d
>> I (1249) wifi: config NVS flash: enabled
>> I (1259) wifi: config nano formating: disabled
>> I (1259) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
>> I (1269) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
>> I (1279) wifi: Init dynamic tx buffer num: 16
>> I (1279) wifi: Init data frame dynamic rx buffer num: 16
>> I (1279) wifi: Init management frame dynamic rx buffer num: 16
>> I (1289) wifi: wifi driver task: 3ffdf3a8, prio:23, stack:4096
>> I (1289) wifi: Init static rx buffer num: 4
>> I (1299) wifi: Init dynamic rx buffer num: 16
>> I (1299) wifi: wifi power manager task: 0x3ffdfe24 prio: 21 stack: 2560
>> I (2019) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
>> I (2019) wifi: mode : softAP (30:ae:a4:37:25:89)
>> I (2029) housekeeping: Auto init modem (free: 113884 bytes)
>> I (2029) housekeeping: Auto init vehicle (free: 113300 bytes)
>> I (2029) esp32wifi: AP started with SSID: OVMS, MAC: 30:ae:a4:37:25:89, IP: 192.168.4.1
>> I (2029) webserver: Launching Web Server
>> I (2039) v-twizy: Renault Twizy vehicle module
>> I (2049) v-twizy: battmon subsystem init
>> I (2059) v-twizy: pwrmon subsystem init
>> I (2059) v-twizy: charge subsystem init
>> I (2059) canopen: Worker started on can1
>> I (2059) telnet: Launching Telnet Server
>> I (2059) v-twizy: sevcon subsystem init
>> I (2069) simcom: State: Enter PoweringOn state
>> I (2069) simcom: Power Cycle
>> I (2069) simcom: State: Enter PoweredOn state
>> I (3069) gsm-nmea: Startup
>> I (3079) housekeeping: Auto init server v2 (free: 71748 bytes)
>> I (3079) ovms-server-v2: OVMS Server V2 registered metric modifier is #2
>> I (3079) ovms-server-v2: Status: Starting
>> I (3089) ovms-server-v2: OVMS Server v2 running
>> I (3089) housekeeping: Auto init server v3 (free: 67436 bytes)
>> I (3099) housekeeping: Auto init done (free: 67436 bytes)
>> I (3099) housekeeping: Starting USB console...
>> I (3109) uart: queue free spaces: 30
>> I (3109) ovms-mdns: Starting MDNS
>> Welcome to the Open Vehicle Monitoring System (OVMS) - Async Console
>> I (3149) version: Set version
>> I (12139) simcom: State timeout, transition to 2
>> I (12139) simcom: State: Enter PoweringOn state
>> I (12139) simcom: Power Cycle
>> I (13149) housekeeping: System considered stable (free: 46388 bytes)
>> I (18139) simcom: State: Enter PoweredOn state
>> OVMS> enable dee4shi!
>> Secure mode
>> I (38159) simcom: State: Enter MuxStart state
>> I (38159) gsm-mux: Start MUX
>> I (38169) gsm-mux: Channel #0 is open
>> I (38179) gsm-mux: Channel #1 is open
>> I (38179) gsm-mux: Channel #2 is open
>> I (38189) gsm-mux: Channel #3 is open
>> I (38199) gsm-mux: Channel #4 is open
>> I (39139) simcom: State: Enter NetWait state
>> I (39139) gsm-nmea: Startup
>> OVMS# mo m
>> Free 8-bit 38380/283224, 32-bit 27544/55820, SPIRAM 0/0
>> --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM
>> no task 5312 0 0 0 +5312 +0 +0 +0
>> esp_timer 50120 0 644 0 +50120 +0 +644 +0
>> main 24624 0 0 0 +24624 +0 +0 +0
>> ipc0 10848 0 0 0 +10848 +0 +0 +0
>> Housekeeping 35976 61772 0 0 +35976 +61772 +0 +0
>> tiT 128 1016 0 0 +128 +1016 +0 +0
>> ipc1 12 0 0 0 +12 +0 +0 +0
>> NetManTask 16 692 0 0 +16 +692 +0 +0
>> wifi 32 3392 0 0 +32 +3392 +0 +0
>> eventTask 0 7532 0 0 +0 +7532 +0 +0
>> SIMCOMTask 0 4400 0 0 +0 +4400 +0 +0
>> Tmr Svc 0 2136 0 0 +0 +2136 +0 +0
>> AsyncConsole 0 20 27488 0 +0 +20 +27488 +0
>> I (49159) simcom: CREG Network Registration: RegisteredRoaming
>> OVMS# wifi status
>> WiFi
>> Power: on
>> Mode: Access-Point mode
>> AP SSID: OVMS
>> IP: 192.168.4.1
>> AP Stations: 0
>> I (50139) simcom: State: Enter NetStart state
>> I (51169) simcom: PPP Connection is ready to start
>> I (52139) simcom: State: Enter NetMode state
>> I (52139) gsm-ppp: Initialising...
>> I (54569) gsm-ppp: StatusCallBack: None
>> I (54569) gsm-ppp: status_cb: Connected
>> I (54569) gsm-ppp: our_ipaddr = 10.170.195.13
>> I (54569) gsm-ppp: his_ipaddr = 10.64.64.64
>> I (54569) gsm-ppp: netmask = 255.255.255.255
>> I (54569) gsm-ppp: our6_ipaddr = ::
>> I (54569) netmanager: Set DNS#0 8.8.8.8
>> I (54569) netmanager: Set DNS#1 8.8.4.4
>> I (54579) netmanager: Interface priority is pp2 (10.170.195.13/255.255.255.255 gateway 10.64.64.64)
>> I (54579) time: Starting SNTP client
>> I (54579) ovms-server-v2: Network is up, so attempt network connection
>> I (54579) ovms-server-v2: Connection is ovms.dexters-web.de:6867 test1/aeL1aN9j
>> I (54579) ovms-server-v2: Status: Connecting...
>> OVMS# server v2 status
>> Connecting...
>> OVMS# network status
>> Interface#2: pp2 (ifup=1 linkup=1)
>> IPv4: 10.170.195.13/255.255.255.255 gateway 10.64.64.64
>> Interface#1: ap1 (ifup=1 linkup=1)
>> IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
>> Interface#0: lo0 (ifup=1 linkup=1)
>> IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
>> DNS: 8.8.8.8 8.8.4.4
>> Default Interface: pp2 (10.170.195.13/255.255.255.255 gateway 10.64.64.64)
>> OVMS# mo m
>> CORRUPT HEAP: Bad head at 0x3ffcccf0. Expected 0xabba1234 got 0xab003335
>> assertion "head != NULL" failed: file "/home/balzer/esp/esp-idf/components/heap/./multi_heap_poisoning.c", line 272, function: multi_heap_get_allocated_size
>> abort() was called at PC 0x400f82af on core 1
>> 0x400f82af: __assert_func at
>> /Users/ivan/e/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/stdlib/../../../.././newlib/libc/stdlib/assert.c:63 (discriminator 8)
>> Backtrace: 0x4008f698:0x3fff2c60 0x4008f83b:0x3fff2c80 0x400f82af:0x3fff2ca0 0x4008f39f:0x3fff2cd0 0x40197139:0x3fff2cf0 0x400e7125:0x3fff2d30
>> 0x400e77c7:0x3fff2d50 0x400ed17a:0x3fff2de0 0x400ed271:0x3fff2e10 0x400ed263:0x3fff2e40 0x400ed299:0x3fff2e70 0x400e3074:0x3fff2e90 0x400f0791:0x3fff2eb0
>> 0x400f07f8:0x3fff2f10 0x400e30a3:0x3fff2f50 0x401ca06b:0x3fff2f70 0x400e36b5:0x3fff2f90 0x400e8005:0x3fff2fc0 0x400e81f1:0x3fff2ff0 0x400e3561:0x3fff3010
>> 0x400e3570:0x3fff3030 0x400e6c31:0x3fff3050
>> 0x4008f698: invoke_abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:648
>> 0x4008f83b: abort at /home/balzer/esp/esp-idf/components/esp32/./panic.c:648
>> 0x4008f39f: multi_heap_get_allocated_size at /home/balzer/esp/esp-idf/components/heap/./multi_heap_poisoning.c:326
>> 0x40197139: heap_caps_get_per_task_info at /home/balzer/esp/esp-idf/components/heap/./heap_task_info.c:78
>> 0x400e7125: get_memory(void**, unsigned int) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:751
>> 0x400e77c7: module_memory(int, OvmsWriter*, OvmsCommand*, int, char const* const*) at
>> 0x400ed17a: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:94
>> 0x400ed271: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at
>> 0x400ed263: OvmsCommand::Execute(int, OvmsWriter*, int, char const* const*) at
>> 0x400ed299: OvmsCommandApp::Execute(int, OvmsWriter*, int, char const* const*) at
>> 0x400e3074: Execute(microrl*, int, char const* const*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:47
>> 0x400f0791: new_line_handler at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:620
>> 0x400f07f8: microrl_insert_char at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:668
>> 0x400e30a3: OvmsShell::ProcessChar(char) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:70
>> 0x401ca06b: OvmsShell::ProcessChars(char const*, int) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:77
>> (discriminator 2)
>> 0x400e36b5: ConsoleAsync::HandleDeviceEvent(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:169
>> 0x400e8005: OvmsConsole::Poll(unsigned int, void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:150
>> 0x400e81f1: OvmsConsole::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:130 (discriminator 1)
>> 0x400e3561: ConsoleAsync::Service() at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:80
>> 0x400e3570: non-virtual thunk to ConsoleAsync::Service() at ??:?
>> 0x400e6c31: TaskBase::Task(void*) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./task_base.cpp:156
>> Entering gdb stub now.
>> $T0b#e6GNU gdb (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 7.10
>> Copyright (C) 2015 Free Software Foundation, Inc.
>> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
>> This is free software: you are free to change and redistribute it.
>> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
>> and "show warranty" for details.
>> This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
>> Type "show configuration" for configuration details.
>> For bug reporting instructions, please see:
>> <http://www.gnu.org/software/gdb/bugs/>.
>> Find the GDB manual and other documentation resources online at:
>> <http://www.gnu.org/software/gdb/documentation/>.
>> For help, type "help".
>> Type "apropos word" to search for commands related to "word"...
>> Reading symbols from /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/build/ovms3.elf...done.
>> Remote debugging using /dev/ttyUSB0
>> 0x4008f698 in invoke_abort () at /home/balzer/esp/esp-idf/components/esp32/./panic.c:139
>> 139 *((int *) 0) = 0;
>> (gdb) bt
>> #0 0x4008f698 in invoke_abort () at /home/balzer/esp/esp-idf/components/esp32/./panic.c:139
>> #1 0x4008f83e in abort () at /home/balzer/esp/esp-idf/components/esp32/./panic.c:148
>> #2 0x400f82b2 in __assert_func (file=0x3ffb3720 "/home/balzer/esp/esp-idf/components/heap/./multi_heap_poisoning.c", line=272, func=<optimized out>,
>> failedexpr=0x3ffb3710 "head != NULL")
>> at ../../../.././newlib/libc/stdlib/assert.c:63
>> #3 0x4008f3a2 in multi_heap_get_allocated_size (heap=0x3ffbbe88, p=0x3ffcccfc) at /home/balzer/esp/esp-idf/components/heap/./multi_heap_poisoning.c:272
>> #4 0x4019713c in heap_caps_get_per_task_info (params=0x40098af4) at /home/balzer/esp/esp-idf/components/heap/./heap_task_info.c:78
>> #5 0x400e7128 in get_memory (tasks=0x40098ab8, taskslen=0) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:500
>> #6 0x400e77ca in module_memory (verbosity=<optimized out>, writer=<optimized out>, cmd=<optimized out>, argc=<optimized out>, argv=<optimized out>)
>> at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:550
>> #7 0x400ed17d in OvmsCommand::Execute (this=0x3ffc6a44, verbosity=65535, writer=0x3ffef9e4, argc=0, argv=0x0) at
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:281
>> #8 0x400ed274 in OvmsCommand::Execute (this=0x3ffc69b0, verbosity=65535, writer=0x3ffef9e4, argc=1, argv=0x3fff2eb4) at
>> /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:326
>> #9 0x400ed266 in OvmsCommand::Execute (this=0x3ffb413c <MyCommandApp+4>, verbosity=65535, writer=0x3ffef9e4, argc=2, argv=0x3fff2eb4)
>> at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:322
>> #10 0x400ed29c in OvmsCommandApp::Execute (this=0x3ffb4138 <MyCommandApp>, verbosity=65535, writer=0x3ffef9e4, argc=2, argv=0x3fff2eb0)
>> at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_command.cpp:648
>> #11 0x400e3077 in Execute (rl=0x3ffef9f8, argc=2, argv=0x3fff2eb0) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_shell.cpp:47
>> #12 0x400f0794 in new_line_handler (pThis=0x3ffef9f8) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/microrl/./microrl.c:620
>> #13 0x400f07fb in microrl_insert_char (pThis=0x3ffef9f8, ch=10) at
>> #14 0x400e30a6 in OvmsShell::ProcessChar (this=0x3ffef9e4, c=<optimized out>) at
>> #15 0x401ca06e in OvmsShell::ProcessChars (this=0x3ffef9e4, buf=0x3fff01a5 "a ", '\376' <repeats 198 times>..., len=1) at
>> #16 0x400e36b8 in ConsoleAsync::HandleDeviceEvent (this=0x3ffef9e4, pEvent=<optimized out>) at
>> #17 0x400e8008 in OvmsConsole::Poll (this=0x3ffef9e4, ticks=4294967295, queue=0x3fff0918) at
>> #18 0x400e81f4 in OvmsConsole::Service (this=0x3ffef9e4) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_console.cpp:130
>> #19 0x400e3564 in ConsoleAsync::Service (this=0x3ffef9e4) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./console_async.cpp:80
>> #20 0x400e3573 in non-virtual thunk to ConsoleAsync::Service() ()
>> #21 0x400e6c34 in TaskBase::Task (object=0x3fff0190) at /home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./task_base.cpp:156
>> (gdb)
>> Am 19.03.2018 um 15:34 schrieb Mark Webb-Johnson:
>>> And MDNS is back.
>>> I looked through the source code and found a mdns_handle_system_event() call that is used to pass all the system events through to MDNS. That then
>>> dynamically adds/removed wifi STA and AP interfaces as they come up/down. No need to init and free the mdns system the whole time. Went back to the
>>> documentation, and found it right at the bottom… Good grief.
>>> Anyway, I migrated the code to use that. Now, MDNS starts at boot time and stays up all the time. Seems reliable to me, so I committed it.
>>> Regards, Mark
>>>> On 19 Mar 2018, at 12:57 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>> There seems to be something going on internally in lwip regarding this. It is such a dumb implementation anyway, with a separate task and static
>>>> initialisation of the interface list at the time of startup; really not ideal for a dynamically changing environment. It would be much more sensible to
>>>> just have a timer and every N seconds iterate through the current interface list to send out MDNS broadcasts on each active one that is suitable for MDNS
>>>> (wifi only, really).
>>>> I think safest for the moment to just disable MDNS. I’ve done that now, and it is running live. That seems to be pretty good for me. Can you see if that
>>>> works better for you?
>>>> I’m still seeing some issues with ssh/telnet startup that I’m looking at now.
>>>> Given where we are, I’m going to tell China that we need another 48 hours to confirm the firmware, before I send to them. That buys us some time to get
>>>> this as stable as we can.
>>>> Regards, Mark.
>>>>> On 19 Mar 2018, at 12:27 PM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>> Stephen Casner wrote:
>>>>>> Greg, the async console is a separate task that should be able to look
>>>>>> at some things as long as they don't depend upon the networking tasks
>>>>>> or objects. Is it hung also?
>>>>> Async console? So, not USB. Don't have a connection for that.
>>>>> So, tried it again... Note that the wifi connection gets dropped in the middle, but I didn't turn off the hotspot!
>>>>> Network status, however, says that it's still connected. That's wrong.
>>>>> Stop the server, then start, and this time instead of a hang I get a crash.
>>>>> Greg
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> I (4185) wifi: n:1 1, o:1 0, ap:1 1, sta:1 0, prof:1
>>>>> I (4835) wifi: state: init -> auth (b0)
>>>>> I (4845) wifi: state: auth -> assoc (0)
>>>>> I (4855) wifi: state: assoc -> run (10)
>>>>> I (4875) wifi: connected with gregnet3, channel 1
>>>>> I (4985) simcom: State: Enter PoweredOn state
>>>>> I (5915) event: sta ip: 192.168.43.49, mask: 255.255.255.0, gw: 192.168.43.1
>>>>> I (5915) netmanager: Set DNS#0 9.9.9.9
>>>>> I (5915) netmanager: Set DNS#1 8.8.8.8
>>>>> I (5915) netmanager: Interface priority is st1 (192.168.43.49/255.255.255.0 <http://192.168.43.49/255.255.255.0> gateway 192.168.43.1)
>>>>> I (5915) time: Starting SNTP client
>>>>> I (5925) ovms-server-v2: Network is up, so attempt network connection
>>>>> I (5925) ovms-server-v2: Connection is tmc.openvehicles.com:6867 <http://tmc.openvehicles.com:6867/> ROADSTER_834/Gdbkt2017server
>>>>> I (5925) ovms-server-v2: Status: Connecting...
>>>>> I (5935) ovms-mdns: Stopped MDNS service
>>>>> I (5935) ovms-mdns: Started MDNS service
>>>>> I (5955) esp32wifi: WiFi UP with SSID: gregnet3, MAC: 30:ae:a4:37:1b:64, IP: 192.168.43.49, mask: 255.255.255.0, gw: 192.168.43.1
>>>>> I (6395) ovms-server-v2: Connection successful
>>>>> I (6395) ovms-server-v2: Status: Logging in...
>>>>> I (6395) ovms-server-v2: Sending server login: MP-C 0 gDAm8Tas7ISVuhmQ8zGDfh hygW8au7zuXDV5qkWYvMIA== ROADSTER_834
>>>>> I (6635) ovms-server-v2: Got server response: MP-S 0 ubeiHXgCpUtGX1f6XRXlQK BB2JuaR9oc8TL6Ame7qkEg==
>>>>> I (6645) ovms-server-v2: Server token is ubeiHXgCpUtGX1f6XRXlQK and digest is BB2JuaR9oc8TL6Ame7qkEg==
>>>>> I (6645) ovms-server-v2: Status: Server auth ok. Now priming crypto.
>>>>> I (6645) ovms-server-v2: Shared secret key is ubeiHXgCpUtGX1f6XRXlQKgDAm8Tas7ISVuhmQ8zGDfh (44 bytes)
>>>>> I (6645) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
>>>>> I (6655) ovms-server-v2: Incoming Msg: MP-0 Z0
>>>>> I (7445) ovms-server-v2: Send MP-0 S0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>>>>> I (7445) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,7,0,0,0,0,0.269231,0,0,0,0,0
>>>>> I (7445) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0
>>>>> I (7445) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0
>>>>> I (7445) ovms-server-v2: Send MP-0 F3.0.991-87-g60cd970/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 18 2018 20:29:03,,0,1,TR,gregnet3
>>>>> I (12625) housekeeping: System considered stable (free: 37872 bytes)
>>>>> I (22225) ovms-server-v2: Incoming Msg: MP-0 Z1
>>>>> I (22225) ovms-server-v2: One or more peers have connected
>>>>> I (22445) ovms-server-v2: Send MP-0 S0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>>>>> I (22445) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,22,0,0,0,0,0.351648,0,0,0,0,0
>>>>> I (22445) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0
>>>>> I (22445) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0
>>>>> I (22445) ovms-server-v2: Send MP-0 F3.0.991-87-g60cd970/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 18 2018 20:29:03,,9,1,TR,gregnet3
>>>>> I (24475) simcom: State: Enter MuxStart state
>>>>> I (24475) gsm-mux: Start MUX
>>>>> I (24485) gsm-mux: Channel #0 is open
>>>>> I (24495) gsm-mux: Channel #1 is open
>>>>> I (24505) gsm-mux: Channel #2 is open
>>>>> I (24515) gsm-mux: Channel #3 is open
>>>>> I (24525) gsm-mux: Channel #4 is open
>>>>> I (25445) simcom: State: Enter NetWait state
>>>>> I (25745) ovms-server-v2: Incoming Msg: MP-0 Z0
>>>>> OVMS> metric set v.b.soc 44
>>>>> Metric set
>>>>> I (35485) simcom: CREG Network Registration: RegisteredRoaming
>>>>> I (36445) simcom: State: Enter NetStart state
>>>>> I (37585) simcom: PPP Connection is ready to start
>>>>> I (38445) simcom: State: Enter NetMode state
>>>>> I (38445) gsm-ppp: Initialising...
>>>>> I (40145) ovms-server-v2: Incoming Msg: MP-0 Z1
>>>>> I (40145) ovms-server-v2: One or more peers have connected
>>>>> I (40445) ovms-server-v2: Send MP-0 S44.0,K,0,0,stopped,standard,0,0,0,0,0,0,0,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>>>>> I (40445) ovms-server-v2: Send MP-0 D0,0,5,0,0,0,0,0,0,40,0,0,0,0,0.28022,0,0,0,0,0
>>>>> I (40445) ovms-server-v2: Send MP-0 L0,0,0,0,0,0,0,0,0,0,0
>>>>> I (40445) ovms-server-v2: Send MP-0 W0,0,0,0,0,0,0,0,0
>>>>> I (40445) ovms-server-v2: Send MP-0 F3.0.991-87-g60cd970/factory/main build (idf v3.1-dev-429-g7f6161cd) Mar 18 2018 20:29:03,,9,1,TR,T-Mobile Hologram
>>>>> E (40645) ovms-server-v2: Status: Error: Disconnected from OVMS Server V2
>>>>> I (41895) gsm-ppp: StatusCallBack: None
>>>>> I (41895) gsm-ppp: status_cb: Connected
>>>>> I (41895) gsm-ppp: our_ipaddr = 10.170.146.142
>>>>> I (41895) gsm-ppp: his_ipaddr = 10.64.64.64
>>>>> I (41895) gsm-ppp: netmask = 255.255.255.255
>>>>> I (41895) gsm-ppp: our6_ipaddr = ::
>>>>> I (41895) netmanager: Set DNS#0 9.9.9.9
>>>>> I (41895) netmanager: Set DNS#1 8.8.8.8
>>>>> I (41895) netmanager: Interface priority is st1 (192.168.43.49/255.255.255.0 <http://192.168.43.49/255.255.255.0> gateway 192.168.43.1)
>>>>> I (41895) time: Starting SNTP client
>>>>> I (41895) ovms-server-v2: Network is up, so attempt network connection
>>>>> I (41895) ovms-server-v2: Connection is tmc.openvehicles.com:6867 <http://tmc.openvehicles.com:6867/> ROADSTER_834/Gdbkt2017server
>>>>> I (41895) ovms-server-v2: Status: Connecting...
>>>>> I (60445) ovms-server-v2: Connection is tmc.openvehicles.com:6867 <http://tmc.openvehicles.com:6867/> ROADSTER_834/Gdbkt2017server
>>>>> I (60445) ovms-server-v2: Status: Connecting...
>>>>> I (62565) wifi: bcn_timout,ap_probe_send_start
>>>>> I (65065) wifi: ap_probe_send over, resett wifi status to disassoc
>>>>> I (65065) wifi: state: run -> init (1)
>>>>> I (65065) wifi: n:1 0, o:1 1, ap:1 1, sta:1 0, prof:1
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS>
>>>>> OVMS> server v2 status
>>>>> Connecting...
>>>>> OVMS> network
>>>>> Interface#3: pp3 (ifup=1 linkup=1)
>>>>> IPv4: 10.170.146.142/255.255.255.255 <http://10.170.146.142/255.255.255.255> gateway 10.64.64.64
>>>>> Interface#2: ap2 (ifup=1 linkup=1)
>>>>> IPv4: 192.168.4.1/255.255.255.0 <http://192.168.4.1/255.255.255.0> gateway 192.168.4.1
>>>>> Interface#1: st1 (ifup=1 linkup=1)
>>>>> IPv4: 192.168.43.49/255.255.255.0 <http://192.168.43.49/255.255.255.0> gateway 192.168.43.1
>>>>> IPv4: 127.0.0.1/255.0.0.0 <http://127.0.0.1/255.0.0.0> gateway 127.0.0.1
>>>>> DNS: 9.9.9.9 8.8.8.8
>>>>> Default Interface: st1 (192.168.43.49/255.255.255.0 <http://192.168.43.49/255.255.255.0> gateway 192.168.43.1)
>>>>> OVMS> simcom
>>>>> SIMCOM
>>>>> State: NetMode
>>>>> Ticker: 22
>>>>> User Data: 0
>>>>> Mux
>>>>> Status: up
>>>>> Open Channels: 4
>>>>> Framing Errors: 0
>>>>> Last RX frame: 19 sec(s) ago
>>>>> RX frames: 18
>>>>> TX frames: 18
>>>>> PPP
>>>>> Connected on channel: #2
>>>>> Last Error: None
>>>>> GPS
>>>>> Status: disabled
>>>>> Time: disabled
>>>>> NMEA: GPS/GLONASS Not Connected
>>>>> OVMS> wifi
>>>>> WiFi
>>>>> Power: on
>>>>> Mode: Access-Point + Client mode
>>>>> STA SSID: gregnet3
>>>>> IP: 192.168.43.49/255.255.255.0 <http://192.168.43.49/255.255.255.0>
>>>>> GW: 192.168.43.1
>>>>> AP SSID: ovms
>>>>> MAC: 30:ae:a4:37:1b:65
>>>>> IP: 192.168.4.1
>>>>> AP Stations: 0
>>>>> OVMS> server v2 stop
>>>>> Stopping OVMS Server V2 connection (oscv2)
>>>>> OVMS v2 server has not been started
>>>>> OVMS> server v2 start
>>>>> Launching OVMS Server V2 connection (oscv2)
>>>>> Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
>>>>> . Exception was unhandled.
>>>>> Core 1 register dump:
>>>>> PC : 0x400ee17d PS : 0x00060630 A0 : 0x800ef642 A1 : 0x3fff5020
>>>>> A2 : 0xffffffff A3 : 0x3fff2540 A4 : 0x00000000 A5 : 0x3fff5100
>>>>> A6 : 0x3fff50e0 A7 : 0x0000000c A8 : 0x800ee179 A9 : 0x3fff4ff0
>>>>> A10 : 0xffffffff A11 : 0x3f411528 A12 : 0x3fff5100 A13 : 0x3fff50e0
>>>>> A14 : 0x0000000c A15 : 0x3fff1ea4 SAR : 0x00000004 EXCCAUSE: 0x0000001c
>>>>> EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
>>>>> Backtrace: 0x400ee17d:0x3fff5020 0x400ef63f:0x3fff5060 0x400f04c5:0x3fff50a0 0x40082c71:0x3fff50d0 0x40115696:0x3fff5120 0x401161ef:0x3fff5140
>>>>> 0x40116a7d:0x3fff5330 0x40116aa5:0x3fff5960 0x400eeeb2:0x3fff5980 0x400eefa9:0x3fff59b0 0x400eef9b:0x3fff59e0 0x400eef9b:0x3fff5a10 0x400eefd1:0x3fff5a40
>>>>> 0x400e534c:0x3fff5a60 0x400f1809:0x3fff5a80 0x400f1870:0x3fff5ae0 0x400e537b:0x3fff5b20 0x401eb64f:0x3fff5b40 0x400f0575:0x3fff5b60 0x400ebf8d:0x3fff5b90
>>>>> 0x400ec179:0x3fff5bc0 0x400f0421:0x3fff5be0 0x400f0430:0x3fff5c00 0x400e3295:0x3fff5c20
>>>>> Rebooting...
>>>>> ets Jun 8 2016 00:22:57
>>>>> rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
>>>>> configsip: 156795334, SPIWP:0xee
>>>>> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
>>>>> mode:DIO, clock div:2
>>>>> load:0x3fff0018,len:4
>>>>> load:0x3fff001c,len:4560
>>>>> ho 0 tail 12 room 4
>>>>> load:0x40078000,len:0
>>>>> load:0x40078000,len:13176
>>>>> entry 0x40078d38
>>>>> I (647) cpu_start: Pro cpu up.
>>>>> I (647) cpu_start: Starting app cpu, entry point is 0x40081300
>>>>> I (632) cpu_start: App cpu up.
>>>>> I (651) heap_init: Initializing. RAM available for dynamic allocation:
>>>>> I (657) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
>>>>> I (664) heap_init: At 3FFBBAC0 len 00024540 (145 KiB): DRAM
>>>>> I (670) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
>>>>> I (676) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
>>>>> I (684) heap_init: At 40091FDC len 0000E024 (56 KiB): IRAM
>>>>> I (689) cpu_start: Pro cpu start user code
>>>>> I (35) ovms_main: Set default logging level for * to INFO
>>>>> I (35) command: Initialising COMMAND (1000)
>>>>> I (36) boot: Initialising BOOT (1100)
>>>>> I (40) boot: Boot #1 reasons for CPU0=12 and CPU1=12
>>>>> E (46) boot: Crash #1 detected
>>>>> I (49) events: Initialising EVENTS (1200)
>>>>> I (54) config: Initialising CONFIG (1400)
>>>>> I (59) time: Initialising TIME (1500)
>>>>> I (64) script: Initialising SCRIPTS (1600)
>>>>> I (68) script: Using DUKTAPE javascript engine
>>>>> I (74) metrics: Initialising METRICS (1810)
>>>>> I (78) metrics: OvmsMetric is 28 bytes
>>>>> I (82) metrics: OvmsMetricBool is 32 bytes
>>>>> I (87) metrics: Expanding DUKTAPE javascript engine
>>>>> I (97) notify: Initialising NOTIFICATIONS (1820)
>>>>> I (99) notify: Registered notification type info
>>>>> I (103) notify: Registered notification type error
>>>>> I (109) notify: Registered notification type alert
>>>>> I (114) notify: Registered notification type data
>>>>> I (120) location: Initialising LOCATIONS (1900)
>>>>> I (126) location: Expanding DUKTAPE javascript engine
>>>>> I (131) vehicle: Initialising VEHICLE Factory (2000)
>>>>> I (137) pcp: Initialising POWER (4000)
>>>>> I (141) max7317: Initialising MAX7317 EGPIO (4200)
>>>>> I (146) sdcard: Initialising SD CARD (4400)
>>>>> I (151) ota: Initialising OTA (4400)
>>>>> I (156) can: Initialising CAN (4500)
>>>>> I (161) simcom: Initialising SIMCOM (4600)
>>>>> I (165) test: Initialising TEST (5000)
>>>>> I (169) ovms-module: Initialising MODULE (5100)
>>>>> I (174) vfs: Initialising VFS (5200)
>>>>> I (179) ovms-server: Initialising OVMS Server (6000)
>>>>> I (184) ovms-server-v2: Initialising OVMS V2 Server (6100)
>>>>> I (190) ovms-server-v3: Initialising OVMS V3 Server (6200)
>>>>> I (196) obd2ecu: Initialising OBD2ECU (7000)
>>>>> I (202) canopen: Initialising CANopen (7000)
>>>>> I (207) esp32wifi: Initialising ESP32WIFI (8000)
>>>>> I (212) ovms-mdns: Initialising MDNS (8100)
>>>>> I (217) webserver: Initialising WEBSERVER (8200)
>>>>> I (223) telnet: Initialising Telnet (8300)
>>>>> I (227) ssh: Initialising SSH (8300)
>>>>> I (231) re: Initialising RE Tools (8800)
>>>>> I (236) netmanager: Initialising NETMANAGER (8999)
>>>>> I (242) v-track: Registering Vehicle: TRACK (9000)
>>>>> I (246) v-teslaroadster: Registering Vehicle: Tesla Roadster (9000)
>>>>> I (253) v-teslamodels: Registering Vehicle: Tesla Model S (9000)
>>>>> I (260) v-obdii: Registering Vehicle: OBDII (9000)
>>>>> I (265) v-none: Registering Vehicle: NONE (9000)
>>>>> I (271) v-demo: Registering Vehicle: DEMO (9000)
>>>>> I (276) version: Initialising Versioning (9900)
>>>>> I (285) cpu_start: Starting scheduler on PRO CPU.
>>>>> I (0) cpu_start: Starting scheduler on APP CPU.
>>>>> I (331) ovms_main: Executing on CPU core 0
>>>>> I (331) ovms_main: Mounting CONFIG...
>>>>> W (381) webserver: UpdateGlobalAuthFile: no password set => no auth for web console
>>>>> I (391) ovms_main: Registering default configs...
>>>>> I (391) ovms_main: Starting HOUSEKEEPING...
>>>>> I (391) housekeeping: Initialising HOUSEKEEPING Framework...
>>>>> I (451) housekeeping: Executing on CPU core 1
>>>>> I (451) housekeeping: reset_reason: cpu0=12, cpu1=12
>>>>> I (451) housekeeping: Starting PERIPHERALS...
>>>>> I (461) peripherals: Initialising OVMS Peripherals...
>>>>> I (461) peripherals: TCP/IP Adaptor
>>>>> I (471) peripherals: ESP32 system
>>>>> I (471) peripherals: SPI bus
>>>>> I (471) peripherals: MAX7317 I/O Expander
>>>>> I (481) peripherals: ESP32 CAN
>>>>> I (481) peripherals: ESP32 WIFI
>>>>> I (491) peripherals: ESP32 BLUETOOTH
>>>>> I (491) peripherals: ESP32 ADC
>>>>> I (491) peripherals: MCP2515 CAN 1/2
>>>>> I (511) peripherals: MCP2515 CAN 2/2
>>>>> I (521) peripherals: SD CARD
>>>>> I (521) peripherals: SIMCOM MODEM
>>>>> I (521) gpio: GPIO[16]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
>>>>> I (531) gpio: GPIO[17]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
>>>>> I (541) uart: queue free spaces: 10
>>>>> I (541) ext12v: Powering off external 12V devices
>>>>> I (551) housekeeping: Auto init ext12v (free: 112436 bytes)
>>>>> I (551) ext12v: Powering on external 12V devices
>>>>> I (561) housekeeping: Auto init wifi (free: 112436 bytes)
>>>>> I (561) wifi: wifi firmware version: ebd3e5d
>>>>> I (571) wifi: config NVS flash: enabled
>>>>> I (571) wifi: config nano formating: disabled
>>>>> I (571) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
>>>>> I (581) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
>>>>> I (601) wifi: Init dynamic tx buffer num: 16
>>>>> I (601) wifi: Init data frame dynamic rx buffer num: 16
>>>>> I (601) wifi: Init management frame dynamic rx buffer num: 16
>>>>> I (601) wifi: wifi driver task: 3ffe61dc, prio:23, stack:4096
>>>>> I (611) wifi: Init static rx buffer num: 4
>>>>> I (611) wifi: Init dynamic rx buffer num: 16
>>>>> I (611) wifi: wifi power manager task: 0x3ffe8974 prio: 21 stack: 2560
>>>>> I (1331) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
>>>>> I (1331) wifi: mode : sta (30:ae:a4:37:1b:64) + softAP (30:ae:a4:37:1b:65)
>>>>> I (1341) housekeeping: Auto init modem (free: 90292 bytes)
>>>>> I (1351) simcom: State: Enter PoweringOn state
>>>>> I (1351) simcom: Power Cycle
>>>>> I (1351) ovms-mdns: Started MDNS service
>>>>> I (1381) webserver: Launching Web Server
>>>>> I (1381) esp32wifi: AP started with SSID: ovms, MAC: 30:ae:a4:37:1b:65, IP: 192.168.4.1
>>>>> I (1461) simcom: State: Enter PoweredOn state
>>>>> I (2351) housekeeping: Auto init vehicle (free: 75064 bytes)
>>>>> I (2351) v-teslaroadster: Tesla Roadster v1.x, v2.x and v3.0 vehicle module
>>>>> I (2361) housekeeping: Auto init obd2ecu (free: 69332 bytes)
>>>>> I (2561) housekeeping: Auto init server v2 (free: 60676 bytes)
>>>>> I (2561) ovms-server-v2: OVMS Server V2 registered metric modifier is #1
>>>>> I (2571) ovms-server-v2: Status: Starting
>>>>> I (2571) ovms-server-v2: OVMS Server v2 running
>>>>> I (2581) housekeeping: Auto init server v3 (free: 56364 bytes)
>>>>> I (2581) housekeeping: Auto init done (free: 56364 bytes)
>>>>> I (2591) housekeeping: Starting USB console...
>>>>> I (2591) uart: queue free spaces: 30
>>>>> I (2601) version: Set version
>>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180319/f6f13103/attachment-0001.html>
