[Ovmsdev] wifi not coming all the way up?
Mon Mar 19 08:52:39 HKT 2018
When I start wifi client, it looks like it has acquired the link, but
not done DHCP to get an address?
OVMS # wifi mode client Revelstoke
Starting WIFI as a client to Revelstoke...
I (742914) wifi: wifi firmware version: ebd3e5d
I (742914) wifi: config NVS flash: enabled
I (742914) wifi: config nano formating: disabled
I (742914) wifi: Init dynamic tx buffer num: 16
I (742914) wifi: Init data frame dynamic rx buffer num: 16
I (742914) wifi: Init management frame dynamic rx buffer num: 16
I (742914) wifi: wifi driver task: 3fff1044, prio:23, stack:4096
I (742914) wifi: Init static rx buffer num: 4
I (742914) wifi: Init dynamic rx buffer num: 16
I (742914) wifi: wifi power manager task: 0x3ffe81d8 prio: 21 stack: 2560
I (742924) wifi: mode : sta (30:ae:a4:37:1b:84)
I (745344) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (745994) wifi: state: init -> auth (b0)
I (746004) wifi: state: auth -> assoc (0)
I (746014) wifi: state: assoc -> run (10)
I (746054) wifi: connected with Revelstoke, channel 1
I (749014) wifi: pm start, type:0
OVMS # net
Interface#0: lo0 (ifup=1 linkup=1)
  IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
DNS: None
Default Interface: None
OVMS #
