[Ovmsdev] Making secure
Mon Mar 19 04:32:40 HKT 2018
Made changes for v2 server.  Pushed and pull request created.
But, a question and a problem:
Question:  Should the server status require secure mode?  I coded it
yes, but wonder if it's better left as not secure.
Problem:  Couldn't do much testing, as I can't get the v2 server to
connect.  Stays at "starting"...  Did something break in the network
connection stuff, or is there a problem with the server itself?  The
phone app seems to connect ok.
Possibly related, if I tell the server to stop, then to start again, the
start command never completes (never see an ovms prompt after).  This is
before I changed the security settings.
Greg
Stephen Casner wrote:
> I need to go to a concert now and have not done server yet.  Someone
> else can do it, or I'll be back about 5:30 PDT.
