[Ovmsdev] Command security
Sun Mar 18 17:13:53 HKT 2018
Full ack.
Metrics contain even more sensitive information like the GPS position of the car.
Is there a reason to a) keep "echo" open and b) not move it into the "test" framework?
The "help" command in its current form has a very precise view of itself :)
How about something like this:
Enter a single "?" to get the root command list.
Commands can have multiple levels of subcommands.
Use "command […] ?" to get the list of subcommands and parameters.
Commands can be abbreviated, push <TAB> for auto completion at any level.
Use "enable" to enter secure (admin) mode.
Am 18.03.2018 um 09:43 schrieb Mark Webb-Johnson:
> Steve,
> Thanks for this. Very helpful at this critical stage.
> In general, I think your criteria is correct:
>> My assumption going in is that all someone should be able to do before
>> enabling is to look at status that does not include sensitive info.
> When not in secure mode, only very basic stuff should be usable. So, boot, enable, echo, exit, help, etc, are all ok. The ‘time status’ is fine, but no ‘time
> set’. etc.
> The others should not be visible, imho. Metrics, Module, obdii; all should be secure mode only.
> To answer your specific questions:
>> 1. obdii, server and simcom appear to allow their full functionality,
>> including starting and stopping operations, in non-secure mode. That
>> seems wrong.
> The “simcom status”, “server v2 status”, “server v3 status” are fine, but the others should be secure only.
>> 2. event, metrics and notify all allow tracing to be turned on or
>> off. Is that safe?
> I think these should be secure only.
> Metrics should probably be secure only as there is some private information shown there (such as ICCID, etc).
>> 3. time allows setting the time in non-secure mode. That may not be
>> critical in this system, but could mess up timed activities.
> The “time status” is fine, but “time set” is secure mode only.
>> 4. Setting the vehicle module should require being enabled, no?
> Yes. Secure mode only.
>> 5. Is it OK to list the metrics in non-secure mode? Is any of that
>> information sensitive enough that it should be prevented? (We don't
>> have the option to show some metrics and not others at this point.)
> No. Better not. Secure mode only.
>> 6. The module command only allowed the subcommand 'factory' which did
>> not allow any subcommand, so the right fix there is to just make the
>> whole command require secure mode. This observation exposed a bug in
>> the code to construct the usage string, which I fixed.
> Yes. Secure mode for the whole thing.
> Regards, Mark
>> On 18 Mar 2018, at 3:23 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>> Mark asked me to check whether the 'secure' flag is set appropriately
>> in the various command invocation contexts. I began with the console
>> command list where there are a number of questionable settings. My
>> However, there are several commands that do more.
>> All of these commands are at least partially enabled in non-secure
>> mode:
>> OVMS > ?
>> boot BOOT framework
>> echo Test getchar
>> enable Enter secure mode
>> event EVENT framework
>> exit End console session
>> help Ask for help
>> metrics METRICS framework
>> module MODULE framework
>> network NETWORK framework
>> notify NOTIFICATION framework
>> obdii OBDII framework
>> server OVMS Server Connection framework
>> simcom SIMCOM framework
>> time TIME framework
>> vehicle Vehicle framework
>> The harmless ones are 'boot', which just shows status, 'echo', 'exit'
>> and 'help'. Of course, 'enable' needs to be here to change state.
>> But I have questions about all the others:
>> seems wrong.
>> off. Is that safe?
>> So, basically, the question is what do we want someone to be able to
>> do in non-secure mode?
>> -- Steve
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180318/a3983fe9/attachment-0001.html>
