[Ovmsdev] Wifi: Support APCLIENT mode (for Access-Point + Client)
Fri Mar 16 07:12:08 HKT 2018
Very cool indeed, thanks! :)
And everything perfect on the web UI & auto init.
Am 14.03.2018 um 04:29 schrieb Mark Webb-Johnson:
> I’ve added support for a new wifi mode ‘apclient’. This takes AP and STA mode SSIDs, and sets up as both an access point and a client.
> Some caveats:
> 1. There seems to be a problem coming out of the mode (wifi mode off, etc). The network interfaces are not torn down correctly every time. Symptom is the
> client comes up, wifi shows an IP address on it, but the address is not set correctly on the ’st’ network interface. Reproducibility is random (maybe
> interface order related?). Not sure if this is my fault, or a bug in the framework. A 'module reset’ works around the problem ;-)
> 2. I updated Michael’s webserver, and the auto framework, to support this, but I’m not too familiar with that so might have got it wrong.
> 3. Wifi sclient style mode (scanning for known SSIDs to join without knowing the _exact_ SSID) is not currently supported. I’m not sure if this can ever be
> supported properly. The apclient mode works by locking the channel for both the AP and STA to be the same - if we are locked like that, how can we scan
> across channels?
> 4. I’m guessing that ‘wifi scan’ will be similarly restricted, when in ap or apclient modes.
> 5. This is not a router. Setting the gateway on the ’st’ interface would be trivial, but I don’t think packets can travel AP -> STA. Doing that would require
> source-nat, plus packet routing, etc. Routing would be easy, SNAT very nasty.
> It does look pretty cool, and seems to work well:
> OVMS > network
> Interface#2: ap
> IPv4: 192.168.4.1/255.255.255.0 gateway 192.168.4.1
> Interface#1: st
> IPv4: 10.x.x.x/255.255.255.0 gateway 10.x.x.x
> Interface#0: lo
> IPv4: 127.0.0.1/255.0.0.0 gateway 127.0.0.1
> DNS: 8.8.8.8 8.8.4.4
> OVMS > wifi
> WiFi
> Power: on
> Mode: Access-Point + Client mode
> STA SSID: MY-STA-SSID
> MAC: re:da:ct:ed:da:ta
> IP: 10.x.x.x/255.255.255.0
> GW: 10.x.x.x
> AP SSID: MY-AP-SSID
> MAC: da:ta:re:da:ct:ed
> IP: 10.x.x.x
> AP Stations: 1
> 1: MAC: da:ta:re:da:ct:ed, IP: 192.168.4.2
> Enjoy, Mark.
>> Begin forwarded message:
>> *Subject: **[openvehicles/Open-Vehicle-Monitoring-System-3] ee023a: Wifi: Support APCLIENT mode (for Access-Point + Cl...*
>> *Date: *14 March 2018 at 11:09:21 AM HKT
>> Branch: refs/heads/master
>> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
>> Commit: ee023a5c8383901da2b190e3a42e94ad49724b07
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/ee023a5c8383901da2b190e3a42e94ad49724b07
>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>> Date: 2018-03-14 (Wed, 14 Mar 2018)
>> Changed paths:
>> M vehicle/OVMS.V3/changes.txt
>> M vehicle/OVMS.V3/components/esp32wifi/src/esp32wifi.cpp
>> M vehicle/OVMS.V3/components/esp32wifi/src/esp32wifi.h
>> M vehicle/OVMS.V3/components/ovms_webserver/src/web_cfg.cpp
>> Log Message:
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180316/97f70f98/attachment.html>
