[Ovmsdev] 3.0.991
Thu Mar 8 23:33:01 HKT 2018
Greg,
there are better Apps than ZeroConf browser to list mDNS services, that also offer opening in a browser without needing to copy&paste the IP.
For example: https://play.google.com/store/apps/details?id=jp.deci.tbt.andro.bonjoursearch
Actually mDNS _is_ supported by the Android libs, it's just not in the resolver, so is not available for Apps that don't implement it explicitly. Stupid decision.
Am 07.03.2018 um 22:43 schrieb Greg D.:
> Hi Michael,
> Yes. ZeroConf Browser used to be my default mDNS scanner, but I thought to try another, and that one worked. The app is "Service Browser" by Andriy Druk.
> And, it's open source. But, I wouldn't call the system all that robust; tried it again today, and it took a long time for the new software to stop spinning
> and to reveal something. During that time, the old software was reporting no services, as it did when I first tried it. Overall, a lot quicker and more
> reliable to read the (presumed) OVMS documentation and follow the instructions to 192.168.4.1...
> But when it finally worked, it worked on both Android 7 & 8.1. I didn't try to go to the text name, only the revealed IP address, which the app conveniently
> can copy to the phone's clipboard for pasting into the browser address line. Trying"ovms.local" today didn't work at all, with either Chrome or Firefox.
> Neither could find it, and both ran off to search for it on the Web. {sigh}
> Greg
> Michael Balzer wrote:
>> Greg,
>> so you did get it to work on Android 7 & 8? Or was it just the ZeroConf App that showed the mDNS registry info?
>> ZeroConf shows the device on my Android phone (7) and tablet (6) as well, but both are unable to resolve the host name in all other Apps. Have you installed
>> something along with the App or done some additional config?
>> Without a moduleid, the mDNS hostname defaults to "ovms.local", which is of course much easier to type than an IP address. We need to mention both options in
>> the user guide, but we could recommend first trying "ovms.local" for the platforms supporting ZeroConf.
>> Am 07.03.2018 um 05:28 schrieb Greg D.:
>>> Ha! Change what I said... Must not have waited long enough. As you did, simply joining the AP, the 'Service Browser' app eventually did discover the
>>> module at 192.168.4.1, with my car's ID. The 'ZeroConf Browser' app had a problem with it (said there was something there, but no information). This on
>>> both my phone (Android 8.1) and tablet (Android 7.0).
>>> Of course, since my phone got a 192.168.4.2 IP Address, it wasn't too hard to guess where the module was.
>>> Greg
>>> Mark Webb-Johnson wrote:
>>>> It does work on my iOS devices.
>>>> For the module in my car, I’m currently using an iPad. I join the Access Point, then ssh to <vehicleid>.local. Web browsing to that address works as well.
>>>> Regards, Mark.
>>>>> On 7 Mar 2018, at 10:29 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>> Yeah, probably more complicated and proprietary than we need. Just need to put 192.168.4.1 in the manual, after all. Done.
>>>>> Greg
>>>>>> From my understanding, Zeroconf / mDNS rely on a pre-existing IP network. They don’t address the wifi side of things at all.
>>>>>> There are some approaches to dealing with simplifying wifi configuration (involving flashing lights, bluetooth adverts, etc), but they are all
>>>>>> proprietary. Espressif has one called ESP-TOUCH (aka Smart Config):
>>>>>> https://www.espressif.com/en/products/software/esp-touch/overview
>>>>>> Regards, Mark.
>>>>>>> On 7 Mar 2018, at 7:24 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>>>> Hi Michael,
>>>>>>> I trying to figure out how Zeroconf is supposed to work, given the
>>>>>>> networking services that the module currently supports. Perhaps I don't
>>>>>>> understand mDNS well enough, but don't we need some means to broadcast
>>>>>>> our presence, separate from the network?
>>>>>>> I was able to run the ZeroConf Browser on my Android phone (Google
>>>>>>> Pixel2, latest code), and it did discover the module. But that was only
>>>>>>> when the module and phone were both connected by wifi to the home
>>>>>>> network. When it was running in AP mode, with the phone connected to
>>>>>>> the home network, there is no way for the phone to see the mDNS service
>>>>>>> announcement packets.
>>>>>>> I did a wireless trace of the wifi beacons, thinking it might be
>>>>>>> broadcast in there, but didn't find anything service-oriented other than
>>>>>>> the usual stuff. The only wifi adapter that I could get to cooperate
>>>>>>> with me today was a really old one (11b-only), so perhaps there's
>>>>>>> something at an 11g/n level that I can't see?
>>>>>>> I'm thinking we need some out-of-band channel for the broadcasts, for
>>>>>>> example, Bluetooth. Isn't there a service there for this purpose? How
>>>>>>> is this supposed to work?
>>>>>>> Greg
>>>>>>>> Zeroconf / mDNS allows to address the module using the name "<moduleid>.local", but is not supported on all systems. It should work on iOS, but I can't
>>>>>>>> test
>>>>>>>> that. It doesn't work on Android 7, so is not usable as a general solution.
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180308/bc9538ac/attachment-0001.html>
