[Ovmsdev] Moving to a production cycle
Sun Mar 4 12:35:10 HKT 2018
Plan is as follows:
Serial numbers are of the form:
YYYYBBNNNNN
* YYYY is four digit year. For example; 2018
* BB is two digit batch. For example; 00, 01, 02, etc
* NNNN is four digit sequence. For example; 0001, 0002, etc
First production batch is 2018010001 - 2018010120.
That would be 10 digits. Not the most secure, and pretty predictable, but better than a simple “OVMS”.
I’m asking if the software they have can generate random characters. If it can, then will add four random letters onto the end.
> On 4 Mar 2018, at 11:23 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi Mark,
> WPA2 PSK passphrases for WiFi need to be at least 8 characters. Do the serial numbers have leading zeros?
> Greg
> Mark Webb-Johnson wrote:
>> They’ll do pretty much whatever we ask them to do.
>> To try to formalise this, so everyone can see, I’ve created a production/qc/production_notes.txt file with the production notes that will be given to the China side. This should document all the production and QC steps they should do.
>> What I have at the moment is:
>> ** TOOLS
>> 1] DB9 CAN Bus QC tool
>> DB9 Female with:
>> * Pins 2, 4, and 6 connected (all CAN-L signals)
>> * Pins 5, 7, and 8 connected (all CAN-H signals)
>> * R120 between pins 2 and 5
>> * External 12V power connector
>> * GND on pin 3
>> * +12V on pin 9
>> ** PRODUCTION STEPS
>> 1] Default wifi AP and module passwords
>> OVMS> config set wifi.ap OVMS <serialnumber>
>> OVMS> config set password module <serialnumber>
>> Where <serialnumber> is the serial number from the label on the enclosure.
>> I think that should set both the module default and auto wifi AP passwords to the serial number of the module. That will be on a label on the underside of the module.
>> You are correct: this is a connected car, with possibly disastrous consequences should somebody malicious gain access. Best to err on the side of caution.
>>> On 3 Mar 2018, at 4:07 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Mark,
>>> Am 26.02.2018 um 07:28 schrieb Mark Webb-Johnson:
>>>> I’ve asked the China side. Specifically:
>>>> Can you print serial number stickers for these modules? I can provide design - and we can print a large batch.
>>>> Then, during manufacturing, have one step to enter serial number as password into module, like:
>>>> Flash
>>>> Connect terminal
>>>> QC checks
>>>> New step to type: config set wifi.ap OVMS <serialnumber>
>>> Just to double check: so we won't set the module password, only the AP pass phrase?
>>> Has setting the module password any drawbacks?
>>> I'm asking because I assume the SMS channel -as soon as implemented- will also provide command access, which would be open by default as well without a module password.
>>> Setting the module password would secure the webserver as well.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180304/eb6b1c58/attachment.html>
