[Ovmsdev] System date set?
Sat Mar 3 17:24:02 HKT 2018
Although apparent in SNTP, I think the core issue here is in ovms_netmanager.
When wifi goes down, that issued a network.reconfigured event followed by a network.down event. The network.reconfigured causes a stop/start of sntp and I guess there is a race condition there.
Best fix is to change ovms_netmanager so that network.reconfigured is NOT issued if the network is down (only if say two networks were up, and one went down, so one is still up).
I’ve also moved the SNTP init code into module startup (rather than network availability) to try to work around the race condition in SNTP.
> On 3 Mar 2018, at 2:38 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Just fetched the latest updates, now getting a crash / reboot as soon as the ppp gets an IP:
> I (45514) gsm-ppp: StatusCallBack: None
> I (45514) gsm-ppp: status_cb: Connected
> I (45514) gsm-ppp: our_ipaddr = 10.170.195.13
> I (45514) gsm-ppp: his_ipaddr = 10.64.64.64assertion "Operating mode must not be set while SNTP client is running" failed: file "/home/balzer/esp/esp-idf/components/lwip/apps/sntp/sntp.c", line 604, function: sntp_setoperatingmode
> abort() was called at PC 0x400f6e2f on core 0
> Backtrace: 0x4008f64c:0x3ffcc770 0x4008f823:0x3ffcc790 0x400f6e2f:0x3ffcc7b0 0x401935f5:0x3ffcc7e0 0x400e237a:0x3ffcc800 0x400e2a5c:0x3ffcc820 0x400e6c45:0x3ffcc860 0x400e6ecc:0x3ffcc890 0x400e9249:0x3ffcc920 0x400e9ab8:0x3ffc
> c990 0x400e6c45:0x3ffcc9d0 0x400e6ecc:0x3ffcca00 0x40126a3a:0x3ffcca90 0x401a20ad:0x3ffccb00 0x401a2f46:0x3ffccb20 0x401a5fbb:0x3ffccb40 0x401a61b2:0x3ffccb60 0x401a2873:0x3ffccb80 0x401a1d71:0x3ffccba0 0x401a25e8:0x3ffccbd0 0
> x401a2735:0x3ffccbf0 0x4018f581:0x3ffccc10
> Rebooting...
> Switching esp-idf to the new branch origin/sntp-extension didn't help.
> Am 26.02.2018 um 08:54 schrieb Mark Webb-Johnson:
>> Not too bad, so long as you live in a sensible area without DST :-)
>> OVMS > config list vehicle
>> vehicle (readable writeable)
>> name:
>> timezone: HKT-8
>> units.distance: K
>> OVMS > time set 1519631172
>> Time set (at stratum 15)
>> OVMS > time
>> UTC Time: Mon Feb 26 07:46:13 2018
>> Local Time: Mon Feb 26 15:46:13 2018
>> Provider: time
>> PROVIDER STRATUM UPDATE TIME
>> *time 15 1 Mon Feb 26 07:46:13 2018
>> It is also mapped as parameter #23 for OVMS server v2.
>> Committed to github. I’ll look at SNTP next.
>>> On 26 Feb 2018, at 1:40 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>> I’ve extended ovms_time to also include suseconds_t timu, if available.
>>> I think NTP can be done within ovms_time, as an ‘ntp’ source in a similar way to the ‘time’ source for manual configuration. The issue I am hitting is finding out when the time has actually been set. It seems that LWIP SNTP doesn’t provide any facility to expose that. There is a macro SNTP_SET_SYSTEM_TIME_US that is defined in the Espressif LWIP options file as:
>>> #define SNTP_SET_SYSTEM_TIME_US(sec, us) \
>>> do { \
>>> struct timeval tv = { .tv_sec = sec, .tv_usec = us }; \
>>> settimeofday(&tv, NULL); \
>>> } while (0);
>>> but there is no easy way of overriding that from a client app. It seems I’m not the only one who found this:
>>> https://www.esp32.com/viewtopic.php?f=2&t=4695 <https://www.esp32.com/viewtopic.php?f=2&t=4695>
>>> by vonnieda <https://www.esp32.com/memberlist.php?mode=viewprofile&u=4952&sid=4f2bdf4eea4ed434cf38cf94a2df7709> » Tue Feb 13, 2018 11:48 pm
>>> It's working well, but I need to know when it has received a time update and set the time.
>>> by loboris <https://www.esp32.com/memberlist.php?mode=viewprofile&u=2849&sid=4f2bdf4eea4ed434cf38cf94a2df7709> » Wed Feb 14, 2018 8:34 am
>>> I've needed the same thing and ended up adding the global variable sntp_is_synced which is set to true before calling SNTP_SET_SYSTEM_TIME_US in "sntp.c".
>>> Not a very elegant solution because I've modified the file in the esp-idf, but it works fine.
>>> Urgh. But, the Laboris solution seems fairly neat and would meet our requirements.
>>> Time zones seem messy (without all those compiled zone files), but workable. I’ll add it.
>>>> On 25 Feb 2018, at 5:44 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
>>>> Mark,
>>>> Thanks for this. I've made a small change to make 'status' the
>>>> default argument for the command if you don't give one. (I made a
>>>> change to the command system this some months ago to enable this but
>>>> it hasn't been used much yet.)
>>>> I have a few comments on the time system:
>>>> - A full NTP daemon does much more than select among time sources by
>>>> stratum. Given multiple sources, it also has mechanisms to try to
>>>> detect "falsetickers" (a Dave Mills term) and strategies to choose
>>>> between stepping or slewing time depending upon which is more
>>>> appropriate for the way the time source is used.
>>>> - One of the ESP-IDF example programs is SNMP (simple NTP) using the
>>>> capability built into LwIP. It is easy to invoke -- as a test I
>>>> just added this to console_ssh to take advantage of its existing
>>>> event notification for wifi coming up:
>>>> @@ -32,6 +32,7 @@
>>>> #include <lwip/def.h>
>>>> #include <lwip/sockets.h>
>>>> #undef bind
>>>> +#include "apps/sntp/sntp.h"
>>>> #include "freertos/queue.h"
>>>> #include "ovms_log.h"
>>>> #include "ovms_events.h"
>>>> @@ -153,6 +155,11 @@ void OvmsSSH::NetManInit(std::string event, void* data)
>>>> // Only initialise server for WIFI connections
>>>> if (!MyNetManager.m_connected_wifi) return;
>>>> + ESP_LOGI(tag, "Initializing SNTP");
>>>> + sntp_setoperatingmode(SNTP_OPMODE_POLL);
>>>> + sntp_setservername(0, (char*)"pool.ntp.org <http://pool.ntp.org/>");
>>>> + sntp_init();
>>>> ESP_LOGI(tag, "Launching SSH Server");
>>>> int ret = wolfSSH_Init();
>>>> if (ret != WS_SUCCESS)
>>>> One problem with fitting this into the time scheme that you have
>>>> implemented is that it will be updating time in the background on
>>>> its own. The other operating mode is SNTP_OPMODE_LISTENONLY, which
>>>> I don't think would be useful. There are parameters defined in
>>>> components/lwip/include/lwip/apps/sntp/sntp_opts.h that might be
>>>> useful to change. The current update interval is one hour.
>>>> - Another aspect of the SNMP example program is the use of the
>>>> environment variable TZ to control the local timezone. Here is the
>>>> 'date' command I implemented as a test:
>>>> void date(int verbosity, OvmsWriter* writer, OvmsCommand* cmd, int argc, const char* const* argv)
>>>> time_t now;
>>>> struct tm timeinfo;
>>>> char strftime_buf[64];
>>>> setenv("TZ", "PST8PDT,M3.2.0/2,M11.1.0", 1);
>>>> tzset();
>>>> time(&now);
>>>> localtime_r(&now, &timeinfo);
>>>> strftime(strftime_buf, sizeof(strftime_buf), "%c", &timeinfo);
>>>> writer->printf("The current date/time in Sunnyvale is: %s\n", strftime_buf);
>>>> Perhaps we should have a config parameter for timezone?
>>>> -- Steve
>>>> On Sat, 24 Feb 2018, Mark Webb-Johnson wrote:
>>>>> I’ve done a very rough implementation of this:
>>>>> OVMS > time set 1519486746
>>>>> OVMS > time status
>>>>> UTC Time: Sat Feb 24 15:39:09 2018
>>>>> Local Time: Sat Feb 24 15:39:09 2018
>>>>> Provider: time
>>>>> *time 15 4 Sat Feb 24 15:39:10 2018
>>>>> OVMS > time status
>>>>> UTC Time: Sat Feb 24 15:39:14 2018
>>>>> Local Time: Sat Feb 24 15:39:14 2018
>>>>> Provider: time
>>>>> *time 15 9 Sat Feb 24 15:39:15 2018
>>>>> I’ll work on it some more tomorrow. As it is, components can now call MyTime.Set(…) to feed their opinion of time into the system.
>>>>> Regards, Mark.
>>>>>> On 24 Feb 2018, at 10:23 PM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>>>>>> I forgot about vehicles. Tesla Roadster is the same.
>>>>>> I’ll write an ovms_time component now. Then, we can all submit time to it appropriately.
>>>>>> class OvmsTime
>>>>>> public:
>>>>>> OvmsTime();
>>>>>> ~OvmsTime();
>>>>>> public:
>>>>>> void Set(char* provider, int stratum, bool trusted, time_t time);
>>>>>> extern OvmsTime MyTime;
>>>>>> Just follow the NTP stratum approach (distance from a zero-delay device). Trusted is a separate indication that just sets stratum level to 16. The provider is simply the logging TAG.
>>>>>> Internal implementation is like NTP. We track the last times from all providers, and pick the one with the lowest stratum that has reported within a reasonable time.
>>>>>> We can add the boot-time save/restore later (once Michael has done that code for safe boot, etc).
>>>>>> Regards, Mark.
>>>>>>> On 24 Feb 2018, at 9:19 PM, Geir Øyvind Vælidalo <geir at validalo.net <mailto:geir at validalo.net> <mailto:geir at validalo.net <mailto:geir at validalo.net>>> wrote:
>>>>>>> Sounds like a plan. I can get time from the car too, but the resolution is several seconds, so I think we need to have some sort of priority here. Maybe SNTP first, then GPS, cellular and finally “car”?
>>>>>>> Geir
>>>>>>> Sendt fra min iPhone
>>>>>>>> 24. feb. 2018 kl. 04:36 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net> <mailto:mark at webb-johnson.net <mailto:mark at webb-johnson.net>>>:
>>>>>>>> I don’t think so.
>>>>>>>> There are various sources for date/time. GPS. Cellular. SNTP. Need to ensure that they are not all fighting.
>>>>>>>> Another module to do this? Have components tell it their opinion of the time, then it centrally decides and updates system clock if necessary
>>>>>>>> Also store last clock in RTC ram so during a crash/reboot it can recover the last know time?
>>>>>>>> Regards, Mark
>>>>>>>>> On 24 Feb 2018, at 9:44 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org> <mailto:casner at acm.org <mailto:casner at acm.org>>> wrote:
>>>>>>>>> Does the sytem date get set anywhere (presumably from GPS)?
>>>>>>>>> This question occurred to me as I'm working on a side project using
>>>>>>>>> the DEVKIT-C module which won't have access to GPS so I added the code
>>>>>>>>> to set the data using SNTP.
>>>>>>>>> -- Steve
>>>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk> <mailto:OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>>
>>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180303/0d7931f8/attachment-0001.html>
