[Ovmsdev] Stack overflow: What is task "itT"?
Fri Mar 2 13:20:17 HKT 2018
I think that is the TCP/IP task. Maybe CONFIG_TCPIP_TASK_STACK_SIZE?
Have a look in menuconfig and see what you have those stack sizes set to (/STACK to show them all). A ‘module tasks’ can show you the current running values. My tiT is 3072bytes in size (but max level is 696 bytes).
CONFIG_TCPIP_TASK_STACK_SIZE=2560
> On 2 Mar 2018, at 12:55 PM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi folks,
> I just updated to the latest (7 commits), and am having trouble with a
> stack overflow in a task named "tiT". Not sure if that's real, or if
> the task name has been corrupted.
> My startup script enables both simcom and wifi. Turning off wifi
> doesn't prevent the crash. Turning off simcom does (I get all the way
> to the server connecting), so it's apparently somehow related to the
> modem and ppp stack.
> Thoughts?
> Greg
> W (10404) wifi: incorrect scan type: 1073533448
> I (11404) simcom: State timeout, transition to 2
> I (11404) simcom: State: Enter PoweringOn state
> I (11404) simcom: Power Cycle
> I (11894) housekeeping: System considered stable, auto init re-enabled
> I (17034) simcom: State: Enter PoweredOn state
> I (36404) simcom: State: Enter MuxStart state
> I (36404) gsm-mux: Start MUX
> I (36414) gsm-mux: Channel #0 is open
> I (36424) gsm-mux: Channel #1 is open
> I (36424) gsm-mux: Channel #2 is open
> I (36434) gsm-mux: Channel #3 is open
> I (36434) gsm-mux: Channel #4 is open
> I (37404) simcom: State: Enter NetWait state
> I (47484) simcom: CREG Network Registration: RegisteredRoaming
> I (48404) simcom: State: Enter NetStart state
> I (49494) simcom: PPP Connection is ready to start
> I (50404) simcom: State: Enter NetMode state
> I (50404) gsm-ppp: Initialising...
> W (50404) wifi: incorrect scan type: 1073533448
> OVMS > ***ERROR*** A stack overflow in task tiT has been detected.
> abort() was called at PC 0x4008f024 on core 1
> 0x4008f024: vApplicationStackOverflowHook at
> /home/greg/esp/esp-idf/components/esp32/./panic.c:648
> Backtrace: 0x4008ee34:0x3ffca170 0x4008f00b:0x3ffca190
> 0x4008f024:0x3ffca1b0 0x4008b52c:0x3ffca1d0 0x4008d534:0x3ffca1f0
> 0x4008d4ea:0x3ffb15dc
> 0x4008ee34: invoke_abort at
> 0x4008f00b: abort at /home/greg/esp/esp-idf/components/esp32/./panic.c:648
> 0x4008b52c: vTaskSwitchContext at
> /home/greg/esp/esp-idf/components/freertos/./tasks.c:4837
> 0x4008d534: _frxt_dispatch at
> /home/greg/esp/esp-idf/components/freertos/./portasm.S:406
> 0x4008d4ea: _frxt_int_exit at
> /home/greg/esp/esp-idf/components/freertos/./portasm.S:206
> Rebooting...
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180302/be260f2f/attachment.html>
