[Ovmsdev] Development on FreeBSD
Sun Jun 24 19:20:18 HKT 2018
Craig, welcome :)
I've added your updates to the developer doc.
Am 23.06.2018 um 21:49 schrieb Craig Leres:
> Initially I got a build environment up on a spare ubuntu system. But I wanted to work under FreeBSD so I wrote FreeBSD port for the tool chain:
> https://www.freshports.org/devel/xtensa-esp32-elf/
> My ubuntu system says:
> sea 1 % xtensa-esp32-elf-gcc --version
> xtensa-esp32-elf-gcc (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a) 5.2.0
> And FreeBSD says:
> ice 250 % xtensa-esp32-elf-gcc --version
> xtensa-esp32-elf-gcc (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 5.2.0
> So I believe I have the same version. To make the tool chain available I used:
> mkdir ~/esp
> ln -s ../../../../../usr/local/xtensa-esp32-elf ~/esp
> A bonus of having the toolchain under FreeBSD is that (with a little work) it should be possible to build esp32 arduino sketches (which BTW is where all of my
> previous esp8266 and esp32 experience is).
> In the process of getting this up I ran into a few rough edges.
> First, on FreeBSD libintl.a is part of the gettext-runtime and installs with /usr/local as the PREFIX. Attached is the change I made to
> esp-idf/tools/kconfig/Makefile. It makes more sense to me to use -I and -L based on what files are found rather than keying off OS/OSNAME but I can't easily
> test this change on Windows. If this looks ok I can generate a pull request.
> I had trouble getting a working copy esp-idf. The developer guide says to check out remotes/origin/release/v2.1 but that version was giving C errors.
> Eventually I diff'ed against the copy I had on ubuntu and found this to be a good set of instructions:
> git clone https://github.com/openvehicles/esp-idf.git
> cd esp-idf
> git submodule update --init
> I assume the v2.1 step is obsolete. When I need to update it I use:
> git pull
> (If correct) I think this would worth adding to the developers guide. (I have to admit I'm pretty inexperienced with git; a majority of the work I do is with
> subversion.)
> The developers guid says to:
> cp sdkconfig.default sdkconfig
> This should be updated to
> cp support/sdkconfig.default.hw31 sdkconfig
> And there are a lot of new options missing from support/sdkconfig.default.hw31. Maybe the guide should say, "using the defaults is usually safe." (Would it be
> possible to automatically generate a version of sdkconfig using the defaults and not asking any questions?)
> I cloned Open-Vehicle-Monitoring-System-3 and to update it I've been using:
> git fetch upstream
> git checkout master
> git merge upstream/master
> git push
> My module is currently running:
> 3.1.007-2-gc3e62cc-dirty/ota_0/main (build idf v3.1-dev-987-g55d915e9-dirty Jun 23 2018 12:04:27)
> built on a FreeBSD 11.1-RELEASE system.
> Craig
> P.S. Thanks to Steve for all the offline help.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180624/e4e55dfa/attachment.htm>
