[Ovmsdev] Nissan Leaf remote Climate issue
Tom Parker
tom at carrott.org
Fri Jun 22 18:54:18 HKT 2018
On 15/06/18 19:02, Stein Arne Sordal wrote:
> I have attached a capture from the 2014-model when starting climate
> control. I see that the “stop after 15 min frame” actually is sent
> multiple times. I always send it one time and thats ok.
On my 2016 car if I send the 0x46 frame once, after the last 0x4e frame,
the car wakes up and then goes back to sleep without enabling climate
control. I adjusted things to send it a couple of seconds after the 0x4e
frame and this made it work. Climate control came on and then turned off
again after about 15 minutes (I removed the old code so this was the car
switching itself off).
Do you happen to have a capture of everything on the bus with timestamps
for the whole remote climate control start up sequence?
I'm guessing that the TCU is waiting for something from the car before
switching to the next step. I suspect this is the same with locking, the
ovms is blindly sending the remote command message a fixed number of
times and the lock message causes my car to try to lock multiple times.
> The "stop after 15 min frame" for pre-2016 looks like this:
> data[0] =0x46;
Nice, the existing code to support new and old will work on this too.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180622/660800a3/attachment.htm>
