[Ovmsdev] Time, Apps, 3.1.007, and others
Julien “JaXX” Banchet jaxx at jaxx.org
Fri Jun 15 14:18:24 HKT 2018
Hi,
If you’re going that way:
- Using BT, to avoid a full-blown and BOM heavy display, maybe an nRF5 chip based display (there are ILI drivers for everything nowadays :-) ) It’s a different dev path, but it’s overall far less complexe than ESP
- Maybe stick to Wifi (the web socket is already there for streaming metrics) and pick an ESP8266 ? It’s marginally cheaper but still, could be easier
Jb./.
On 15 Jun 2018 at 07:01 +0200, Mark Webb-Johnson <mark at webb-johnson.net>, wrote:
> The original idea was for a companion display to work alongside OVMS (perhaps using bluetooth GATT to talk to OVMS v3.1 modules). But using the same firmware framework seems sensible, and it ends up being pretty similar to a full OVMS v3.1.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180615/bf9b07f8/attachment.htm>
