[Ovmsdev] Getting CONFIG_OVMS_HW_SPIMEM_AGGRESSIVE to work properly
Mon Jun 11 13:41:07 HKT 2018
I finally got CONFIG_OVMS_HW_SPIMEM_AGGRESSIVE working properly. It seems we need to include sdkconfig.h to access these CONFIG_* variables (if we don’t include other esp libraries that do that already). Other than that change, the rest was easy.
For my running config (a car, a v2 server connected, and wifi), I originally had this:
OVMS# module memory
Free 8-bit 87484/230708, 32-bit 7296/11532, SPIRAM 4079552/4194252
Now, with CONFIG_OVMS_HW_SPIMEM_AGGRESSIVE working properly, I get this:
OVMS# module memory
Free 8-bit 104640/230700, 32-bit 7296/11532, SPIRAM 4062400/4194252
OVMS# test spiram
Metrics (0x3f802024) are in SPI RAM
With that config option enabled, all the C++ allocations are by default in SPI RAM, and we gain about 17KB of conventional RAM.
A quick ‘fgrep -r alloc main components’ shows about 1,000 uses of calloc/malloc in our system. I’ve got a large number of them now done, but probably a few more still to do. For example, changing wolf ssh/ssl to use it means most of the incremental allocations are from SPI RAM. Duktape would be a good win (but non-trivial, I think).
Even with bluetooth compiled in, and running, I now have:
OVMS# module memory
Free 8-bit 76476/230696, 32-bit 7296/11532, SPIRAM 4033960/4194252
OVMS# module tasks
Number of Tasks = 21 Stack: Now Max Total Heap 32-bit SPIRAM
3FFCFF98 1 Blk esp_timer 388 628 4096 23928 644 44632
3FFD1C38 2 Blk eventTask 436 1876 4608 0 0 0
3FFD4158 3 Blk OVMS Events 436 3124 8192 73960 0 22128
3FFD56C0 4 Blk OVMS CanRx 428 476 1024 0 0 0
3FFBC3D4 5 Blk ipc0 400 480 1024 7776 0 0
3FFBC9D4 6 Blk ipc1 400 496 1024 12 0 0
3FFBD5E8 9 Rdy IDLE 372 548 1024 0 0 0
3FFBD768 10 Rdy IDLE 372 548 1024 0 0 0
3FFBD8E8 11 Blk Tmr Svc 344 888 3072 88 0 0
3FFBCCAC 16 Blk tiT 496 1504 3072 696 0 884
3FFB7A2C 17 Blk OVMS SIMCOM 464 512 4096 0 0 0
3FFB7D58 18 Blk wifi 432 2384 4096 360 0 1576
3FFDAD44 19 Blk OVMS Vehicle 460 508 6144 0 0 0
3FFDF718 20 Rdy OVMS Console 740 2612 6144 9072 3488 24044
3FFDFBC0 21 Blk mdns 456 1384 4096 108 0 4
3FFE37BC 22 Blk OVMS NetMan 728 2552 8192 104 0 1136
3FFE79B0 23 Blk btController 444 1980 4096 88 0 0
3FFE8CA0 24 Blk Btc_task 412 2572 3584 14924 0 1688
3FFE9EEC 25 Blk hciHostT 408 744 2560 0 0 0
3FFEAFF0 26 Blk hciH4T 412 604 2560 0 0 0
3FFEC854 27 Blk btuT 416 2016 4608 2760 0 23996
That seems very workable.
> Begin forwarded message:
> From: GitHub <noreply at github.com>
> Subject: [openvehicles/Open-Vehicle-Monitoring-System-3] c2d3f7: Add a test spiram command to show whether SPI RAM ...
> Date: 11 June 2018 at 12:51:21 PM HKT
> Branch: refs/heads/master
> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
> Commit: c2d3f7f7ae8655d9d2809e15ad6f989a3459c8df
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/c2d3f7f7ae8655d9d2809e15ad6f989a3459c8df
> Author: Mark Webb-Johnson <mark at webb-johnson.net>
> Date: 2018-06-11 (Mon, 11 Jun 2018)
> Changed paths:
> M vehicle/OVMS.V3/main/test_framework.cpp
> Log Message:
> Add a test spiram command to show whether SPI RAM is being globally used or not
> Commit: c1f96e71dd51c44f9aeff9cf5940982b939a8b24
> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/c1f96e71dd51c44f9aeff9cf5940982b939a8b24
> Changed paths:
> M vehicle/OVMS.V3/main/ovms.cpp
> M vehicle/OVMS.V3/main/ovms.h
> Log Message:
> Fix CONFIG_OVMS_HW_SPIMEM_AGGRESSIVE
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180611/ad8e26a4/attachment.html>
