Tue Jan 30 11:45:02 HKT 2018
I’ve tried pulling manually. See if that fixes it.
Best way, in general, is for you to send a pull request to us. That way we see the changes you want to incorporate and can merge them in simply.
> On 30 Jan 2018, at 10:58 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Not the PC - it's fine, and in symc with my fork on Github. It's my fork on Github that says that it's 2 commits ahead. One of those is an empty remote-tracking commit from the last fetch; the other is the c_str() change to the v2 server... Did you actually sync my fork to Master, or just make the same changes locally?
> Same changes, I guess, but if my fork isn't formally sync'd, I seem to keep accumulating those remote tracking commits, which becomes rather annoying. Should I be pushing directly to Master instead? (It's admittedly safer to not change this...).
> Greg
> Mark Webb-Johnson wrote:
>> git diff, or git diff —staged, should tell you.
>>> On 30 Jan 2018, at 8:34 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>> Hi Mark,
>>> Looks like that did it. No more disconnects. Yea! The verbose logging is good now, too.
>>> Greg
>>> p.s. Just curious, why does Git think I'm still one commit ahead of Master?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180130/8dfb09dc/attachment.htm>
