[Ovmsdev] Web frontend
Tue Jan 30 02:36:49 HKT 2018
Param registration is fixed.
Am 29.01.2018 um 10:48 schrieb Michael Balzer:
> Oops, I moved the param registration to /dev/null -- I'll fix that this evening.
> File downloads are handled in chunks by the mongoose system. I've implemented chunked transfer for the embedded assets as well, so RAM usage
> should be acceptable even with the 3.0 module.
> Performance of file downloads is affected by the FAT buffer configuration, especially with a browser doing parallel fetches. But it's OK for
> single file downloads with a global buffer.
> Am 29.01.2018 um 01:31 schrieb Mark Webb-Johnson:
>> Very very cool. Love the clean layout, and very usable as is.
>> One comment: I don’t think the http.server config parameter is registered. I couldn’t set any configs on it. I was interested in trying out the vfs directory access functions - to download can bus dumps, etc. Wondering how mongoose handles that (and hoping it doesn’t consume all the ram for big files).
>>> On 29 Jan 2018, at 3:10 AM, Michael Balzer <dexter at expeedo.de> wrote:
>>> A first usable web frontend version is now in the hub.
>>> There are two new mongoose config options to enable serving from file space and list directory contents. I recommend enabling them, if you want to exclude
>>> access to the filesystem, you can do so by configuration params "http.server":
>>> // "http.server"Instances:
>>> // Name Default Function
>>> // enable.files yes Enable file serving from docroot
>>> // enable.dirlist yes Enable directory listings
>>> // docroot /sd File server document root
>>> // auth.domain ovms Default auth domain (digest realm)
>>> // auth.file .htpasswd Per directory auth file (Note: no inheritance from parent dir!)
>>> // auth.global yes Use global auth for files (user "admin", module password)
>>> File access is not needed for the web frontend though, just an option to be able to access i.e. CAN logs. The docroot can be set to "/store", but I don't
>>> recommend that. The config path is protected, but this relies on mongoose delivering correct paths -- a bug would open access to the config. If you want to
>>> serve from /store, use a sub directory like "/store/www" as the docroot.
>>> Global and web session authentication is bound to the module password (config set password module "…").
>>> The frontend is AJAX based using Bootstrap & jQuery, with currently a very basic (functional) design. I've implemented a first home & status screen (just
>>> command outputs), a simple shell and config pages for the password and the basic vehicle setup (just type & id for now). I'll add config pages for wifi, modem,
>>> server & ota during the next days.
>>> The frontend is usable on a small screen, just the shell could need full screen support -- I'll have a look at that later on.
>>> The framework provides a page registration and page context utilities to enable custom / vehicle specific extensions with few effort. I'll add an example /
>>> template for this.
>>> Feedback is welcome.
