Mon Jan 29 21:17:11 HKT 2018
The bind has to occur in the network.mgr.init handler. That is the point between mg_mgr_init and mg_mgr_poll.
Perhaps in the handler we can check m_connected_wifi and only bind if wifi is up? But would also need to pickup network.reconfigured and check m_connected_wifi there as well.
> On 29 Jan 2018, at 6:11 PM, Michael Balzer <dexter at expeedo.de> wrote:
> mg_bind() fails with "failed to open listener". I haven't traced it further yet, assumed it's the bind() that fails.
> Mongoose (now?) uses the standard socket API, so does not need to handle LWIP details, or does it?
> I can do some more debugging to get the exact point of failure.
> Am 29.01.2018 um 02:28 schrieb Stephen Casner:
>> Mark,
>> Back in November we discussed this problem of the client's half of the
>> connection being left open.  Then as now, you commented that mongoose
>> sends a close event (MG_EV_CLOSE) for each open connection when the
>> interface went down.
>> It does send a close event, but not until after the wifi is already
>> shut down so closing the socket at that point does not send any packet
>> to the client.  I decided to punt on that issue, though, because
>> manually shutting down wifi is not an important use case.  The more
>> likely case is that wifi connectivity is lost due to motion or other
>> causes and in that case no close packet can be delivered anyway.
>> I interpreted Michael's message to be referring to a problem with
>> ports on the server (OVMS) end.  That is, to say that mongoose didn't
>> clean up LWIP state properly.  Michael, can you explain a bit more?
>>                                                         -- Steve
>> On Mon, 29 Jan 2018, Mark Webb-Johnson wrote:
>>> I suspect that this is timing related:
>>> OVMS > wifi mode client XXX
>>> Starting WIFI as a client to XXX…
>>>>>> I (337100) ssh: Launching SSH Server
>>> V (338830) ssh: Event MG_EV_ACCEPT conn 0x3ffee8b4, data 0x3ffee8cc
>>> V (338840) ssh: Event MG_EV_RECV conn 0x3ffee8b4, data received 21
>>> V (338840) ssh: Event MG_EV_SEND conn 0x3ffee8b4, data 0x3ffe5d90
>>> V (338840) ssh: Event MG_EV_RECV conn 0x3ffee8b4, data received 1024
>>> V (338850) ssh: Event MG_EV_RECV conn 0x3ffee8b4, data received 408
>>>>>> OVMS > wifi mode off
>>> Stopping wifi station...
>>> I (350580) ovms-mdns: Stopping MDNS service
>>> I (350580) wifi: state: run -> init (0)
>>> I (350590) wifi: pm stop, total sleep time: 0/11930449
>>> I (350590) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
>>> I (350600) wifi: flush txq
>>> I (350600) wifi: stop sw txq
>>> I (350600) wifi: lmac stop hw txq
>>> I (350600) wifi: Deinit lldesc rx mblock:4
>>> I (351340) webserver: Stopping Web Server
>>> I (351340) ssh: Stopping SSH Server
>>> V (351540) ssh: Event MG_EV_CLOSE conn 0x3ffee8b4, data 0x0
>>> V (351540) ssh: Event MG_EV_CLOSE conn 0x3ffeb468, data 0x0
>>> I (357570) event: station ip lost
>>> But ssh client connection is still up on my workstation. Looks like
>>> the MG_EV_CLOSE events came in after the SSH server was stopped.
>>> I repeated the test, but with event logging on:
>>> I (34171) events: Signal(system.wifi.down)
>>> I (34171) events: Signal(network.wifi.down)
>>> I (34171) ovms-mdns: Stopping MDNS service
>>> I (34171) events: Signal(network.reconfigured)
>>> I (34171) events: Signal(network.down)
>>> I (34171) wifi: state: run -> init (0)
>>> I (34181) wifi: pm stop, total sleep time: 0/9603569
>>> I (34181) wifi: n:11 0, o:11 0, ap:255 255, sta:11 0, prof:1
>>> I (34191) wifi: flush txq
>>> I (34191) wifi: stop sw txq
>>> I (34191) wifi: lmac stop hw txq
>>> I (34191) wifi: Deinit lldesc rx mblock:4
>>> I (34191) events: Signal(system.wifi.sta.disconnected)
>>> I (34191) events: Signal(system.wifi.sta.stop)
>>> I (35131) events: Signal(network.mgr.stop)
>>> I (35131) webserver: Stopping Web Server
>>> I (35131) ssh: Stopping SSH Server
>>> V (35331) ssh: Event MG_EV_CLOSE conn 0x3ffec138, data 0x0
>>> V (35331) ssh: Event MG_EV_CLOSE conn 0x3ffeb768, data 0x0
>>> MDNS exits quicker because it responds to the network.wifi.down message, while ssh uses the network.mgr.stop event. In a clean shutdown there is a difference.
>>> Perhaps we should issue network.mgr.stop earlier? However, even if we close the connections from our end, I’m not sure if the packet would make it through to the other end before the wifi disconnects.
>>>> On 29 Jan 2018, at 2:13 AM, Stephen Casner <casner at acm.org> <mailto:casner at acm.org> wrote:
>>>> I handled wifi shutdowns cleanly when I first implemented telnet and
>>>> ssh as their own tasks.  Now that they are under Mongoose, it is out
>>>> of my control.  The socket is owned by the Mongoose code.
>>>>                                                        -- Steve
>>>> On Sun, 28 Jan 2018, Michael Balzer wrote:
>>>>> I've begun working on the webserver and noticed something that may
>>>>> be correlated to this: sockets don't get closed when losing the
>>>>> connection. The effect is visible on both web and telnet server (ssh
>>>>> not tested). To reproduce, switch the Wifi network with an open
>>>>> connection, the port will not be available until timeout.
>>>>> Regards,
>>>>> Michael
>>>>> OvmsDev mailing list
>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180129/03dc6cae/attachment.htm>
