[Ovmsdev] Missing File?
Stephen Casner
casner at acm.org
Sat Jan 20 04:32:13 HKT 2018
While I assume everyone will want to follow Mark's instructions here,
it was a bug that the extra include from our fork was not gated by a
conditional. That is fixed now.
On Fri, 19 Jan 2018, Mark Webb-Johnson wrote:
> Can you check 'git branch'. Make sure you are on 'master' branch (not 2.1).
> Also make sure you've done the Submodule update command.
> > On 19 Jan 2018, at 6:58 PM, Tom Parker <tom at carrott.org> wrote:
> > I just updated to the latest IDF and I'm getting this error:
> > CXX build/main/ovms_module.o
> > /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:40:28: fatal error: esp_heap_debug.h: No such file or directory
> > compilation terminated.
> > /home/ubuntu/esp/esp-idf/make/component_wrapper.mk:273: recipe for target 'ovms_module.o' failed
> > make[1]: *** [ovms_module.o] Error 1
> > If I delete line 40 of ovms_module.cpp to avoid trying to import this file then everything compiles.
> > Well it compiles if I turn off the mdns server in menuconfig. If I leave that as the sdkconfig.default.hw30 values then I get this error:
> > CXX build/ovms_mdns/src/ovms_mdns.o
> > In file included from /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_mdns/src/ovms_mdns.cpp:36:0:
> > /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_mdns/src/ovms_mdns.h:48:5: error: 'mdns_server_t' does not name a type
> > mdns_server_t *m_mdns;
> > OvmsDev mailing list
> > OvmsDev at lists.teslaclub.hk
