[Ovmsdev] Transition to new esp-idf
Wed Jan 17 09:23:22 HKT 2018
Note also that the memory debugging option adds a bit of overhead.
With debugging enabled (heap: light impact):
OVMS > module memory
Free 8-bit 79868/282496, 32-bit 17660/44832, SPIRAM 0/0
--Task--     Total DRAM D/IRAM   IRAM SPIRAM   +/- DRAM D/IRAM   IRAM SPIRAM
no task            5312      0      0      0      +5312     +0     +0     +0
esp_timer         49568      0    644      0     +49568     +0   +644     +0
main              39444      0      0      0     +39444     +0     +0     +0
ipc0              11096      0      0      0     +11096     +0     +0     +0
Housekeeping      24740  19956      0      0     +24740 +19956     +0     +0
tiT                 132      0      0      0       +132     +0     +0     +0
Tmr Svc               4  27800      0      0         +4 +27800     +0     +0
ipc1                 12      0      0      0        +12     +0     +0     +0
AsyncConsole          0     36  26404      0         +0    +36 +26404     +0
OVMS > metrics list m.freeram
m.freeram                                79868
With debugging enabled (heap: comprehensive):
Free 8-bit 79728/282320, 32-bit 17968/45140, SPIRAM 0/0
Housekeeping      24644  20056      0      0     +24644 +20056     +0     +0
AsyncConsole          0     20  26404      0         +0    +20 +26404     +0
I (15614) simcom: State timeout, transition to 13
I (15614) simcom: State: Enter PoweredOff state
m.freeram                                79728
With debugging disabled:
To use these debugging tools, must set CONFIG_HEAP_TASK_TRACKING=y
and have updated openvehicles/esp-idf
m.freeram                                99956
I think we’ve still got some stuff we can look at to lighten the impact on internal memory. Once we can get the 3.1 hardware out, I can focus on that. The memory tools Steve has built are really complete and usable now. They let us see exactly what is going on.
If we had known going in that the 520KB SRAM of the ESP32 would be 80% used by the system, and only 20% for us, perhaps things would have been done differently. Anyway, we are where we are, and the WROVER module should be able to move a bunch of stuff off to PSRAM.
> On 17 Jan 2018, at 12:59 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Bluetooth is disabled. Has been for a while, I don't see a chance to enable it with the 3.0 module.
> I've also disabled Javascript support (duktape), Wolf, the web server and MDNS and the OBD2ECU. Telnet is enabled as I sometimes use that parallel to the async console.
> That config gives me…
> Free 8-bit 117364/286352, 32-bit 17972/45144, SPIRAM 0/0
> …after reboot (without SD card), and with Wifi, modem, Twizy & server v2 running & connected…
> Free 8-bit 23436/286352, 32-bit 17972/45144, SPIRAM 0/0
> …when idle, will drop further with transmissions pending etc.
> Opening a telnet session then results in:
> Free 8-bit 18372/286352, 32-bit 17972/45144, SPIRAM 0/0
> …and still stable.
> Am 16.01.2018 um 01:11 schrieb Mark Webb-Johnson:
>> I’m seeing this:
>> Free 8-bit 79812/282268, 32-bit 17816/44988, SPIRAM 0/0
>> OVMS > sd unmount
>> Unmounted SD CARD
>> Free 8-bit 107768/282268, 32-bit 17816/44988, SPIRAM 0/0
>> Tmr Svc               0     20      0      0         -4 -27780     +0     +0
>> I guess it is FAT fs stuff, but we use that for /store as well so not sure why so much. I will look into it.
>> With wifi client, ovms server v2, tesla roadster vehicle module, I get this:
>> Free 8-bit 54224/282268, 32-bit 17816/44988, SPIRAM 0/0
>> With the OBDII HUD, that drops to 45KB.
>> Do you have bluetooth enabled (in menuconfig)?
>>> On 16 Jan 2018, at 3:35 AM, Michael Balzer <dexter at expeedo.de> <mailto:dexter at expeedo.de> wrote:
>>> I've found the missing RAM. It's allocated for the SD card:
>>> I (34235) sdcard: SD CARD has been inserted. Auto-mounting...
>>> Free 8-bit 89348/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> Tmr Svc               4  27804      0      0         +4 +27804     +0     +0
>>> I (68065) sdcard: SD CARD has been removed.
>>> Free 8-bit 117332/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> Tmr Svc               0     12      0      0         -4 -27792     +0     +0
>>> …again…
>>> I (114985) sdcard: SD CARD has been inserted. Auto-mounting...
>>> Tmr Svc               4  27804      0      0         +4 +27792     +0     +0
>>> E (141205) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
>>> E (141205) diskio_sdmmc: sdmmc_read_blocks failed (263)
>>> I (141515) sdcard: SD CARD has been removed.
>>> Btw, I think the RAM usage of the telnet server is also higher than before:
>>> OVMS > wifi mode client
>>> Starting WIFI as a client for any defined SSID
>>> I (380175) wifi: wifi firmware version: 403db1d
>>> I (380175) wifi: config NVS flash: enabled
>>> I (380175) wifi: config nano formating: disabled
>>> I (380185) wifi: Init dynamic tx buffer num: 16
>>> I (380185) wifi: Init data frame dynamic rx buffer num: 16
>>> I (380185) wifi: Init management frame dynamic rx buffer num: 16
>>> I (380185) wifi: wifi driver task: 3ffe3db4, prio:23, stack:4096
>>> I (380185) wifi: Init static rx buffer num: 4
>>> I (380185) wifi: Init dynamic rx buffer num: 16
>>> I (380195) wifi: wifi power manager task: 0x3ffe846c prio: 21 stack: 2560
>>> I (380195) wifi: mode : sta (30:ae:a4:37:25:88)
>>> W (390205) wifi: incorrect scan type: 1073534024
>>> I (392615) esp32wifi: Found SSID devolo-f4068d73a03e - trying to connect
>>> I (393945) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
>>> I (394595) wifi: state: init -> auth (b0)
>>> I (394605) wifi: state: auth -> assoc (0)
>>> I (394605) wifi: state: assoc -> run (10)
>>> I (394625) wifi: connected with devolo-f4068d73a03e, channel 11
>>> I (394665) esp32wifi: WiFi UP with SSID: devolo-f4068d73a03e, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.101, mask: 255.255.255.0, gw: 192.168.2.1
>>> I (394665) telnet: Launching Telnet Server
>>> I (397615) wifi: pm start, type:0
>>> Free 8-bit 89700/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> tiT                 128    716      0      0         +0   +484     +0     +0
>>> AsyncConsole          0  16552  26404      0         +0 +16356     +0     +0
>>> NetManTask            8    488      0      0         +8   +488     +0     +0
>>> wifi                  0   1600      0      0         +0  +1600     +0     +0
>>> eventTask             0   7564      0      0         +0  +7564     +0     +0
>>> …but I'm not sure about that, haven't tested that in a while.
>>> So, SD cards now work, and I'll not be able to use them due to the RAM usage… :(
>>> Am 15.01.2018 um 19:21 schrieb Michael Balzer:
>>>> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
>>>> And…
>>>> OVMS > sd status
>>>> SD CARD is inserted
>>>> Type: SDHC/SDXC
>>>> Speed: default speed
>>>> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
>>>> SCR: sd_spec=2, bus_width=5
>>>> → me too (the minion) :)
>>>> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
>>>> After loading just the Twizy module & the v2 server, I'm now again down to…
>>>> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
>>>> …so it crashes as soon as it needs to actually do anything, like sending a notification.
>>>> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
>>>> I'll now check the config again for any more options to save RAM…
>>>> Regards,
>>>> Michael
>>>> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>>>>> In order for the the "module memory" and "module tasks" commands to
>>>>> work, the configuration needs to be changed from the sdk.default.hw30
>>>>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>>>>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>>>>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled.  I have
>>>>> attached a diff for the sdkconfig.  That diff also includes a section
>>>>> for enabling telnet, which some of you may be using.
>>>>> Please also note that in this revised implementation of "module
>>>>> memory" the block address is now the address that is returned from
>>>>> malloc, not the address of the header that precedes it, and the length
>>>>> of the block is now exclusive of the debugging overhead.
>>>>>                                                         -- Steve
>>>>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>>>>> All committed and pushed now.
>>>>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>>>>> Check
>>>>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>>>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>>>>> I hope this goes smoothly for you.
>>>>>> Regards, Mark.
>>>>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net> <mailto:mark at webb-johnson.net> <mailto:mark at webb-johnson.net>
>>>>>> Date:   Mon Jan 15 07:56:45 2018 +0800
>>>>>>     Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>>>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>>>>> Merge: e58c5b6 b28db5e
>>>>>> Date:   Mon Jan 15 07:49:13 2018 +0800
>>>>>>     Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>>>>>     OVMS developers should now:
>>>>>>     1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>>>>>     2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>>>>>     3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>>>>>        been provided. That can be merged/copied to sdkconfig as appropriate.
>>>>>>     4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>>>>>        been provided in the next update.
>>>>>>     5] It is recommended that developers perform at least one full 'make flash'
>>>>>>        with this version, to update the bootloader to latest. Note that the
>>>>>>        sdkconfig.default.* files are now set to require bootloader at least v2.1
>>>>>>        (or later), and bootloader v2.0 is no longer supported.
>>>>>>     Enjoy.
>>>>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net> <mailto:mark at webb-johnson.net> <mailto:mark at webb-johnson.net> wrote:
>>>>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>>>>> Regards, Mark
>>>>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> <mailto:casner at acm.org> <mailto:casner at acm.org> <mailto:casner at acm.org> wrote:
>>>>>>>> Mark,
>>>>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>>>>> as you planned?
>>>>>>>>                                                       -- Steve
>>>>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>>>>> make sure your stuff is still ok?
>>>>>>>>> I have just now done this.  I had already done a rebase a few days ago
>>>>>>>>> before committing the improved version of the OS changes so I could
>>>>>>>>> issue a pull request.  There were a few commits since then, which I
>>>>>>>>> have now merged.  My code still runs correctly.
>>>>>>>>>> I guess steps for developers will be:
>>>>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>>>>> Sounds right.
>>>>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>>>>>                                                       -- Steve
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk> <mailto:OvmsDev at lists.teslaclub.hk> <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev> <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev> <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180117/176fa209/attachment.htm>
