[Ovmsdev] CAN-3 broken again?
Wed Jan 17 01:59:25 HKT 2018
Greg, Mark,
I'm having two basic issues with this:
a) This will limit the TX speed achievable on the mcp interfaces. I generally hate not fully utilizing available hardware capabilities. And this is SPI, filling
a TX buffer is expensive.
b) It again feels like fixing without understanding. I really think we should first understand how the reported race condition of the mcp interrupt signal
affects our driver design, and we should check the effect of level interrupts before resorting to limiting the speed.
The mcp SPI interface is running at 1 MHz, so a TX will … wait a moment, why is it running at 1 MHz? According to the data sheet, it can do 10 MHz?
Mark, is there some scaling done in the spinodma module, or is there a reason (other than typo / copy-paste) for this?
Am 16.01.2018 um 09:47 schrieb Greg D.:
> Hi Mark,
> Yes, absolutely. In fact, I just thought of a corner case while nodding
> off to sleep (hate it when that happens!). Fixed, verified, and pushed
> to my branch. Anxiously awaiting review from Michael...
> Greg
> Mark Webb-Johnson wrote:
>> I think best for @michael to review. A single tx buffer is certainly easier to manage.
>>>> In vino veritas.
>>> Indeed!
>>> Fixes look good (can't seem to kill it). Pushed to my fork on Git Hub,
>>> along with removal of the delays in the obd2ecu.cpp code.
>>> This was done on the older tool chain; wanted to be sure the fix was
>>> real before upgrading and potentially hiding the issue with a slight
>>> change in timing. Will upgrade the toolchain tomorrow and verify.
>>> Greg
