[Ovmsdev] Transition to new esp-idf
Tue Jan 16 09:19:48 HKT 2018
I’m looking into the ‘server response is incomplete’ message now. Seems something broken in the socket layer / memory corruption.
> On 16 Jan 2018, at 5:41 AM, Michael Balzer <dexter at expeedo.de> wrote:
> More issues:
> a) changing log levels only works without specifying a tag
> b) getting frequent logs like these:
> I (8324105) ovms-server-v2: Server response is incomplete (0 bytes)
> E (8324105) ovms-server-v2: Status: Error: Server response is incomplete
> …resulting in a server reconnect.
> V (8415335) simcom: rx: f9 05 ff 33 24 47 4e 47 4e 53 2c 2c 2c 2c 2c 2c | ...3$GNGNS,,,,,,
> V (8415335) simcom: rx: 4e 4e 2c 2c 2c 2c 2c 2c 2a 35 33 0d 0a 84 f9 f9 | NN,,,,,,*53.....
> V (8415335) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
> V (8415345) gsm-mux: ChanProcessFrame(CHAN=1, ADDR=05, CTRL=ff, LEN=28, IFP=3)
> V (8415355) gsm-nmea: IncomingLine: $GNGNS,,,,,,NN,,,,,,*53
> V (8415355) simcom: rx: 05 ff 33 24 47 50 52 4d 43 2c 2c 56 2c 2c 2c 2c | ..3$GPRMC,,V,,,,
> V (8415355) simcom: rx: 2c 2c 2c 2c 2c 2c 4e 2a 35 33 0d 0a 84 f9       | ,,,,,,N*53....
> V (8415355) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
> V (8415355) gsm-mux: ChanProcessFrame(CHAN=1, ADDR=05, CTRL=ff, LEN=28, IFP=3)
> V (8415355) gsm-nmea: IncomingLine: $GPRMC,,V,,,,,,,,,,N*53
> V (8416335) simcom: rx: f9 05 ff 33 24 47 4e 47 4e 53 2c 2c 2c 2c 2c 2c | ...3$GNGNS,,,,,,
> V (8416335) simcom: rx: 4e 4e 2c 2c 2c 2c 2c 2c 2a 35 33 0d 0a 84 f9 f9 | NN,,,,,,*53.....
> V (8416335) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
> V (8416345) gsm-mux: ChanProcessFrame(CHAN=1, ADDR=05, CTRL=ff, LEN=28, IFP=3)
> V (8416345) gsm-nmea: IncomingLine: $GNGNS,,,,,,NN,,,,,,*53
> V (8416345) simcom: rx: 05 ff 33 24 47 50 52 4d 43 2c 2c 56 2c 2c 2c 2c | ..3$GPRMC,,V,,,,
> V (8416345) simcom: rx: 2c 2c 2c 2c 2c 2c 4e 2a 35 33 0d 0a 84 f9       | ,,,,,,N*53....
> V (8416345) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
> V (8416345) gsm-nmea: IncomingLine: $GPRMC,,V,,,,,,,,,,N*53
> I (8416515) ovms-server-v2: Server response is incomplete (0 bytes)
> V (8416515) gsm-ppp: tx: 7e 21 45 00 00 28 00 6c 00 00 ff 06 e5 3c 0a aa | ~!E..(.l.....<..
> V (8416515) gsm-ppp: tx: c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 4d d6 3f f5 | ....K.. at ....M.?.
> V (8416515) gsm-ppp: tx: f4 17 50 11 16 2a 38 8b 00 00 b9 4c 7e          | ..P..*8....L~
> V (8416515) simcom: tx: f9 09 ff 5b 7e 21 45 00 00 28 00 6c 00 00 ff 06 | ...[~!E..(.l....
> V (8416515) simcom: tx: e5 3c 0a aa c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 | .<......K.. at ....
> V (8416515) simcom: tx: 4d d6 3f f5 f4 17 50 11 16 2a 38 8b 00 00 b9 4c | M.?...P..*8....L
> V (8416515) simcom: tx: 7e 45 f9                                        | ~E.
> E (8416525) ovms-server-v2: Status: Error: Server response is incomplete
> V (8417315) simcom: rx: f9 09 ff 5b 7e 21 45 00 00 28 b7 32 40 00 2d 06 | ...[~!E..(.2 at .-.
> V (8417315) simcom: rx: c0 76 bc 8a 4b e5 0a aa c3 0d 1a d3 ee 40 3f f5 | .v..K........@?.
> V (8417315) simcom: rx: f4 17 00 00 4d d7 50 11 39 08 15 ac 00 00 f2 89 | ....M.P.9.......
> V (8417325) simcom: rx: 7e 45 f9                                        | ~E.
> V (8417325) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=45, LEN=51)
> V (8417325) gsm-mux: ChanProcessFrame(CHAN=2, ADDR=09, CTRL=ff, LEN=48, IFP=3)
> V (8417325) gsm-ppp: rx: 7e 21 45 00 00 28 b7 32 40 00 2d 06 c0 76 bc 8a | ~!E..(.2 at .-..v..
> V (8417325) gsm-ppp: rx: 4b e5 0a aa c3 0d 1a d3 ee 40 3f f5 f4 17 00 00 | K........@?.....
> V (8417335) gsm-ppp: rx: 4d d7 50 11 39 08 15 ac 00 00 f2 89 7e          | M.P.9.......~
> V (8417335) gsm-ppp: tx: 7e 21 45 00 00 28 00 6d 00 00 ff 06 e5 3b 0a aa | ~!E..(.m.....;..
> V (8417335) gsm-ppp: tx: c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 4d d7 3f f5 | ....K.. at ....M.?.
> V (8417335) gsm-ppp: tx: f4 18 50 10 16 29 38 8b 00 00 a9 af 7e          | ..P..)8.....~
> V (8417335) simcom: tx: f9 09 ff 5b 7e 21 45 00 00 28 00 6d 00 00 ff 06 | ...[~!E..(.m....
> V (8417335) simcom: tx: e5 3b 0a aa c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 | .;......K.. at ....
> V (8417335) simcom: tx: 4d d7 3f f5 f4 18 50 10 16 29 38 8b 00 00 a9 af | M.?...P..)8.....
> V (8417335) simcom: tx: 7e 45 f9                                        | ~E.
> V (8417345) simcom: rx: f9 05 ff 33 24 47 4e 47 4e 53 2c 2c 2c 2c 2c 2c | ...3$GNGNS,,,,,,
> V (8417345) simcom: rx: 4e 4e 2c 2c 2c 2c 2c 2c 2a 35 33 0d 0a 84 f9 f9 | NN,,,,,,*53.....
> Am 15.01.2018 um 19:21 schrieb Michael Balzer:
>> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
>> And…
>> OVMS > sd status
>> SD CARD is inserted
>> Type: SDHC/SDXC
>> Speed: default speed
>> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
>> SCR: sd_spec=2, bus_width=5
>> → me too (the minion) :)
>> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
>> After loading just the Twizy module & the v2 server, I'm now again down to…
>> OVMS > module memory
>> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
>> …so it crashes as soon as it needs to actually do anything, like sending a notification.
>> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
>> I'll now check the config again for any more options to save RAM…
>> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>>> In order for the the "module memory" and "module tasks" commands to
>>> work, the configuration needs to be changed from the sdk.default.hw30
>>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled.  I have
>>> attached a diff for the sdkconfig.  That diff also includes a section
>>> for enabling telnet, which some of you may be using.
>>> Please also note that in this revised implementation of "module
>>> memory" the block address is now the address that is returned from
>>> malloc, not the address of the header that precedes it, and the length
>>> of the block is now exclusive of the debugging overhead.
>>>                                                         -- Steve
>>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>>> All committed and pushed now.
>>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>>> Check
>>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>>> I hope this goes smoothly for you.
>>>> Regards, Mark.
>>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net>
>>>> Date:   Mon Jan 15 07:56:45 2018 +0800
>>>>     Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>>> Merge: e58c5b6 b28db5e
>>>> Date:   Mon Jan 15 07:49:13 2018 +0800
>>>>     Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>>>     OVMS developers should now:
>>>>     1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>>>     2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>>>     3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>>>        been provided. That can be merged/copied to sdkconfig as appropriate.
>>>>     4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>>>        been provided in the next update.
>>>>     5] It is recommended that developers perform at least one full 'make flash'
>>>>        with this version, to update the bootloader to latest. Note that the
>>>>        sdkconfig.default.* files are now set to require bootloader at least v2.1
>>>>        (or later), and bootloader v2.0 is no longer supported.
>>>>     Enjoy.
>>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net> wrote:
>>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>>> Regards, Mark
>>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> <mailto:casner at acm.org> wrote:
>>>>>> Mark,
>>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>>> as you planned?
>>>>>>                                                       -- Steve
>>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>>> make sure your stuff is still ok?
>>>>>>> I have just now done this.  I had already done a rebase a few days ago
>>>>>>> before committing the improved version of the OS changes so I could
>>>>>>> issue a pull request.  There were a few commits since then, which I
>>>>>>> have now merged.  My code still runs correctly.
>>>>>>>> I guess steps for developers will be:
>>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>>> Sounds right.
>>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>>>                                                       -- Steve
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180116/c662d8c4/attachment.htm>
