[Ovmsdev] Transition to new esp-idf
    Tue Jan 16 03:35:52 HKT 2018
I've found the missing RAM. It's allocated for the SD card:
OVMS > module memory
Free 8-bit 117364/286352, 32-bit 17972/45144, SPIRAM 0/0
I (34235) sdcard: SD CARD has been inserted. Auto-mounting...
Free 8-bit 89348/286352, 32-bit 17972/45144, SPIRAM 0/0
--Task--     Total DRAM D/IRAM   IRAM SPIRAM   +/- DRAM D/IRAM   IRAM SPIRAM
Tmr Svc               4  27804      0      0         +4 +27804     +0     +0
I (68065) sdcard: SD CARD has been removed.
Free 8-bit 117332/286352, 32-bit 17972/45144, SPIRAM 0/0
Tmr Svc               0     12      0      0         -4 -27792     +0     +0
…again…
I (114985) sdcard: SD CARD has been inserted. Auto-mounting...
Tmr Svc               4  27804      0      0         +4 +27792     +0     +0
E (141205) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
E (141205) diskio_sdmmc: sdmmc_read_blocks failed (263)
I (141515) sdcard: SD CARD has been removed.
Btw, I think the RAM usage of the telnet server is also higher than before:
OVMS > wifi mode client
Starting WIFI as a client for any defined SSID
I (380175) wifi: wifi firmware version: 403db1d
I (380175) wifi: config NVS flash: enabled
I (380175) wifi: config nano formating: disabled
I (380185) wifi: Init dynamic tx buffer num: 16
I (380185) wifi: Init data frame dynamic rx buffer num: 16
I (380185) wifi: Init management frame dynamic rx buffer num: 16
I (380185) wifi: wifi driver task: 3ffe3db4, prio:23, stack:4096
I (380185) wifi: Init static rx buffer num: 4
I (380185) wifi: Init dynamic rx buffer num: 16
I (380195) wifi: wifi power manager task: 0x3ffe846c prio: 21 stack: 2560
I (380195) wifi: mode : sta (30:ae:a4:37:25:88)
W (390205) wifi: incorrect scan type: 1073534024
I (392615) esp32wifi: Found SSID devolo-f4068d73a03e - trying to connect
I (393945) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
I (394595) wifi: state: init -> auth (b0)
I (394605) wifi: state: auth -> assoc (0)
I (394605) wifi: state: assoc -> run (10)
I (394625) wifi: connected with devolo-f4068d73a03e, channel 11
I (394665) esp32wifi: WiFi UP with SSID: devolo-f4068d73a03e, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.101, mask: 255.255.255.0, gw: 192.168.2.1
I (394665) telnet: Launching Telnet Server
I (397615) wifi: pm start, type:0
Free 8-bit 89700/286352, 32-bit 17972/45144, SPIRAM 0/0
tiT                 128    716      0      0         +0   +484     +0     +0
*AsyncConsole          0  16552  26404      0         +0 +16356     +0     +0*
NetManTask            8    488      0      0         +8   +488     +0     +0
wifi                  0   1600      0      0         +0  +1600     +0     +0
eventTask             0   7564      0      0         +0  +7564     +0     +0
…but I'm not sure about that, haven't tested that in a while.
So, SD cards now work, and I'll not be able to use them due to the RAM usage… :(
Am 15.01.2018 um 19:21 schrieb Michael Balzer:
> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
> And…
> OVMS > sd status
> SD CARD is inserted
> Type: SDHC/SDXC
> Speed: default speed
> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
> SCR: sd_spec=2, bus_width=5
> → me too (the minion) :)
> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
> After loading just the Twizy module & the v2 server, I'm now again down to…
> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
> …so it crashes as soon as it needs to actually do anything, like sending a notification.
> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
> I'll now check the config again for any more options to save RAM…
> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>> In order for the the "module memory" and "module tasks" commands to
>> work, the configuration needs to be changed from the sdk.default.hw30
>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled.  I have
>> attached a diff for the sdkconfig.  That diff also includes a section
>> for enabling telnet, which some of you may be using.
>> Please also note that in this revised implementation of "module
>> memory" the block address is now the address that is returned from
>> malloc, not the address of the header that precedes it, and the length
>> of the block is now exclusive of the debugging overhead.
>>                                                         -- Steve
>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>> All committed and pushed now.
>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>> Check
>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>> I hope this goes smoothly for you.
>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>> Author: Mark Webb-Johnson <mark at webb-johnson.net>
>>> Date:   Mon Jan 15 07:56:45 2018 +0800
>>>     Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>> Merge: e58c5b6 b28db5e
>>> Date:   Mon Jan 15 07:49:13 2018 +0800
>>>     Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>>     OVMS developers should now:
>>>     1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>>     2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>>     3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>>        been provided. That can be merged/copied to sdkconfig as appropriate.
>>>     4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>>        been provided in the next update.
>>>     5] It is recommended that developers perform at least one full 'make flash'
>>>        with this version, to update the bootloader to latest. Note that the
>>>        sdkconfig.default.* files are now set to require bootloader at least v2.1
>>>        (or later), and bootloader v2.0 is no longer supported.
>>>     Enjoy.
>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>> Regards, Mark
>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> wrote:
>>>>> Mark,
>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>> as you planned?
>>>>>                                                       -- Steve
>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>> make sure your stuff is still ok?
>>>>>> I have just now done this.  I had already done a rebase a few days ago
>>>>>> before committing the improved version of the OS changes so I could
>>>>>> issue a pull request.  There were a few commits since then, which I
>>>>>> have now merged.  My code still runs correctly.
>>>>>>> I guess steps for developers will be:
>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>> Sounds right.
>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>>                                                       -- Steve
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180115/d557b7db/attachment.htm>
