[Ovmsdev] CAN-3 broken again?
Mon Jan 15 04:11:35 HKT 2018
Greg,
ah yes, the esp-idf currently doesn't implement oneshot interrupts on levels, we need to do that ourselves.
Something along the base line of this:
https://github.com/espressif/esp-idf/issues/1234#issuecomment-342320583
…just with reversed logic, as we get triggered on low.
Am 14.01.2018 um 20:36 schrieb Greg D.:
> hi Michael,
> Good try, but the whole system hangs, so I'm guessing that we're stuck in an infinite interrupt loop. But that suggests that the issue is related to
> unbalanced interrupt processing somehow.
> I'm going to try for some diagnostic logging once it gets stuck, and see if I can identify its state. The absolute reproducibility of the base issue leads me
> to think the reported empty interrupt issue (your prior email) is probably not it, but rather the driver is not handling some confluence of events properly.
> I have no trouble running the HUD display, for example, but it doesn't produce the rapid transmit frames of the OBDWiz dongle. Something about the transmit
> side is messing up the receive... I wonder if we're getting an interrupt for both the last Tx frame being sent and the VIN request PID being received at the
> same time? Transmit interrupts don't check for receive, and vice-versa.
> Will report back later today...
> Greg
> Michael Balzer wrote:
>> Greg,
>> here's another report of level triggering solving the issue: https://community.nxp.com/thread/456907
>> Can you please give that a try? I.e. change line 77 to:
>> gpio_set_intr_type((gpio_num_t)m_intpin, GPIO_INTR_LOW_LEVEL);
>> I'll also get a DB9 plug to implement Marks test solution.
>> Am 14.01.2018 um 17:52 schrieb Michael Balzer:
>>>> Hmmmm, I think level triggered interrupt would help here.
>>> We currently let the interrupt trigger on the negative edge (line 77). Maybe GPIO_INTR_LOW_LEVEL can help?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180114/661d8003/attachment.htm>
