[Ovmsdev] CAN-3 broken again?
Sun Jan 14 01:42:07 HKT 2018
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180113/e1d400a0/attachment.htm>
OVMS > can can3 status
CAN:       can3
Mode:      Active
Speed:     500000
Rx pkt:                       0
Rx err:                       0
Rx ovrflw:                    0
Tx pkt:                       0
Tx delays:                    0
Tx err:                       0
Tx ovrflw:                    0
Err flags: 0
OVMS > Guru Meditation Error of type LoadProhibited occurred on core  1. Exception was unhandled.
Register dump:
PC      : 0x400d3cfa  PS      : 0x00060730  A0      : 0x800d3d62  A1      : 0x3ffdef60
0x400d3cfa: _ZN3can8LogFrameE14CAN_LogEntry_tPK11CAN_frame_t at /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/./can.cpp:502
A2      : 0x3ffb31e4  A3      : 0x00000001  A4      : 0x3ffdf14c  A5      : 0x3ffdf030
A6      : 0xffffffff  A7      : 0x00000000  A8      : 0x800f65e5  A9      : 0x3ffdef10
A10     : 0x00000000  A11     : 0x00000000  A12     : 0x3ffd1530  A13     : 0x00000000
A14     : 0x00000000  A15     : 0x00060623  SAR     : 0x00000008  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000018  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0xffffffff
Backtrace: 0x400d3cfa:0x3ffdef60 0x400d3d5f:0x3ffdefd0 0x400dad41:0x3ffdeff0 0x400e9c0b:0x3ffdf070 0x400ea1ee:0x3ffdf1b0
0x400d3d5f: _ZN6canbus5WriteEPK11CAN_frame_tj at /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/./can.cpp:397
0x400dad41: _ZN7mcp25155WriteEPK11CAN_frame_tj at /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/mcp2515/./mcp2515.cpp:220 (discriminator 4)
0x400e9c0b: _ZN7obd2ecu13IncomingFrameEP11CAN_frame_t at /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/obd2ecu/src/obd2ecu.cpp:533
0x400ea1ee: _ZL12OBD2ECU_taskPv at /home/greg/greg/ovms/Open-Vehicle-Monitoring-System-3-master/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/obd2ecu/src/obd2ecu.cpp:158 (discriminator 1)
Rebooting...
